Topic: Measuring Amperage (Read 3604 times) previous topic - next topic
JimboZA
#15
Jan 21, 2013, 04:54 pm Last Edit: Jan 21, 2013, 04:56 pm by JimboZA Reason: 1
One way to identify the printer's voltage might be to look inside the printer you took it out of, unless you trashed that. Maybe you could power it up and measure the voltage where the motor wires used to go.
Edit.... Or how about Googling for the printer model: you might find a schematic.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Drew Davis
I already trashed it but i will just use 12v and if it is to slow bump it up to 24v. Any ides on how to find the amperage?
Thanks!
majenko
Thanks!
Place an ammeter in series with the motor and measure it.
krupski
Thanks!
If it's from a printer, it may be a stepper motor......
Gentlemen may prefer Blondes, but Real Men prefer Redheads!
JimboZA
Yeah I suggested that and they think I'm from the steam age  ]:D
michael_x
It will take a higher current when motor has a load to move.
Max is called "stall" current. Motor and power supply should survive it, for a short period ;)
Drew Davis
Thanks for all the help!
Krupski/JimboZA: I believe we came to the conclusion that it is not a stepper because it only has two wires. Do steppers some times have only 2 wires? I don't really know I'm just going off what majenko said.
Michel: When testing it I will put some load on it.
I looked online and it did not say if my multimeter has a ammeter in it. What do you guys think? If it doesn't what brand do you recommend me buying?
Thanks !
http://www.sears.com/craftsman-digital-multimeter-with-ac-voltage-detector/p-03482146000P?prdNo=1&blockNo=1&blockType=G1
JimboZA
Yep it does... in the pic on that link, the grey switch segment at about 4 o'clock says "10A".
3 holes for the leads is also a giveaway, since current is usually (always?) measured on its own connection.
Edit... the left hand socket is colour coded grey and also says 10A
Drew Davis
Thanks! I will test it out later to day.
Do you think it will be accurate?
michael_x
#24
Jan 21, 2013, 05:30 pm Last Edit: Jan 21, 2013, 05:37 pm by michael_x Reason: 1
As you ask, it might be interesting to you that for current measurement the DMM has to be in series with the circuit.
So you have to put it between the +12V supply and one of the motor pins. The other motor pin then goes to the supply GND (or - Pin).
Accurate enough to multiply by 2 for some safety margin regarding which device should control and supply it finally.
You want results like (100mA, 200mA, 500mA, 1A, 2A, more ), both for high load and free running.
JimboZA
No idea... the maker's documentation should give the tolerances. My Fluke's manual says 1.5%, but then Sears isn't Fluke  8)
Drew Davis
JimboZA
On the stepper motor thing, yes we concluded that it wasn't one on account of just having two wires. Steppers do have more than two, because the windings kind of drag the motor round inside as the wires energise the various coils.
Drew Davis
JimboZA
More on your meter....
It looks to me as if the lower current readings (ADC: 2000u, 20m and 200m at 2-3 o'clock) are with the middle socket, but you'll need to read the manual or at least read what it says next to the middle socket: that's obscured in the pic.
