Loading...
Pages: [1]   Go Down
Author Topic: ESD Lining in my tool box?  (Read 327 times)
JoCo N.C. USA
Offline Offline
Jr. Member
Don't know jack, but want to know it all..... Let the journey begin!
View Profile
Hi there. I was wondering if I cut the ESD bags that stuff ships in to fit the cubbys in my school tool box and glue them in, will this provide ESD protection for Arduinos and other chips layed on them, or is it not worth doing? Thanks, Steve
Logged
The geeks shall inherit the Earth!
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Is the toolbox metal? If so, it will already dissipate static.
If not, the lining won't hurt.
Be sure to touch something metal before touching any chips.
Most parts seem pretty immune once mounted on a board.
Loose chips, different story.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
JoCo N.C. USA
Offline Offline
Jr. Member
View Profile
It is plastic with metal hinges. Will do, good to know. Thanks again! I will leave you more karma when the one hour wait is up. :-)
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
I stick down metallized Duct tape in the bottom of plastic boxes. Resistance measured
between 2 points 1" apart is just 1.5 ohms.
Logged
Kitchen-Sink Arduino-compatible boards
Offline Offline
Sr. Member
View Profile
There are high-density anti-static foam you can buy to line up the bottom of your container.
Back in the 80s, it was aluminum foil wrapped all over the pins of CMOS logic ICs smiley
You can also try copper tape.
Logged
JoCo N.C. USA
Offline Offline
Jr. Member
View Profile
Go ideas all. I have some of the metalized tape, it will work better then the ESD bags the stuff ships in?
Logged
Offline Offline
Sr. Member
View Profile
Quote
A sealed ESD bag also provide other kinds of protection, moisture for example.
I have chips that include a moisture detector inside the bag that changes color based on moisture %. I need to bake the parts if the colors turned pink, depending on moisture level.
Logged
JoCo N.C. USA
Offline Offline
Jr. Member
View Profile
Damn, bake 'em!? That is a trip! lol
Logged
Denmark
Offline Offline
Full Member
New on the Arduino platform...
View Profile
WWW
Baking is only important if you are doing controlled big production and use automated equipment mounting the components. The only parts i have seen popcorn IRL is BGA's and no home-tinkerer uses BGA's
 //Per.
Logged
Offline Offline
Sr. Member
View Profile
I don't use BGAs but have some SOIC parts I use come in sealed bags complete with the moisture detector.
I just make it a point to use them immediately after opening the bag, and reseal the bag quickly.
I also have a Zephyrtonics ZT-1 hot air bath in my shop http://www.zeph.com/bgs_airbath.htm
I do run a business and have some form of production going on ,and I'd rather take the precautions (which costs nothing or very little) rather than deal with product returns, warranty repairs, free shipping, bad PR when people talk about problems, etc.
If you're just a home tinkerer and using the completed projects for yourself, you probably have nothing to worry about but your own DIY project.
Logged
Pages: [1]   Go Up
Print
Jump to:
