Loading...
Pages: [1]   Go Down
Author Topic: My first sketch. Hello world and Hello Arduino forums  (Read 308 times)
Offline Offline
Newbie
View Profile
This is my first go with the Arduino and my first post here on the forum! I have quite a bit to learn about electronics. The nice thing is that the Arduino feels like legos for electronics. I find that it is very easy and inviting to learn as well as fun and rewarding.
I ordered a starter kit and was able to assemble a small binary counter given the items I had. I'd like to turn this into a binary clock, perhaps with an alarm.
Presently it counts to 31 as I only have 5 LEDS and buzzes when it hits 31. You can control the speed with the potentiometer.
Sketch avail on my github page.
Sketch
Video
Criticism are welcome! I am here to learn. smiley
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Your sketch here:
Code:
// Array of LED PINS. Makes it easy for our binary counter to decide which LEDS to blink.
int PINS[] = {13, 12, 11, 10, 9};
int delayms = 0;
// the setup routine runs once when you press reset:
  // initialize digital pins as outputs.
  for(int led = 8; led < 14; led++){
    pinMode(led, OUTPUT);
//Blinks LEDS in binary
void blink_binary_number(int number, boolean vol=HIGH){
  for(int led = 0; led < number; led++){
    if (bitRead(number, led) == 1){
      digitalWrite(PINS[led], vol); //Here we use our PINS array to decide which LED to blink. Since I wanted 13 to be bit 0, 12 bit 1, etc...
// the loop routine runs over and over again forever:
 for(int x = 0; x < 32; x++){
   delayms = analogRead(0) * 10;
   if (x == 31){
     analogWrite(8, 254);
   blink_binary_number(x);
   delay(delayms);
   if (x == 31){
     analogWrite(8, 0);
   blink_binary_number(x, LOW);
   delay(delayms);
Your array "PINS" seems to have 5 elements, but you are accessing elements 0 to 31, if I am not mistaken.
Logged
Offline Offline
Newbie
View Profile
Ahh yes. I see what you mean. It didn't immediately pop out to me but inside of my blink_binary_number I am iterating over elements that I never initiated.
Logged
Offline Offline
Newbie
View Profile
Is there a sizeof, length, or size method I can use against an array? For example...
Quote
  for(int led = 0; led < PINS.length + 1; led++){
This would allow me to change the size of my pins array without re-writing this method.
Logged
Offline Offline
Newbie
View Profile
Ahh sorry for the noise. I found a good answer here.
Logged
Offline Offline
Newbie
View Profile
Fixed!
Code:
int const PINS[] = {13, 12, 11, 10, 9};
int const PINS_SIZE = (sizeof(PINS)/sizeof(int));
int delayms = 0;
  //Serial.begin(9600);
  for(int led = 0; led < PINS_SIZE; led++){
   if (x == 31){
   delay(delayms);
   if (x == 31){
     analogWrite(8, 0);
   delay(delayms);
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
A generic "size of array" define is this:
Code:
// number of items in an array
#define NUMITEMS(arg) ((unsigned int) (sizeof (arg) / sizeof (arg [0])))
Then you have:
Code:
int const PINS_SIZE = NUMITEMS (PINS);
Logged
Offline Offline
Newbie
View Profile
Yes. Putting it in a method makes a lot more sense. Thanks Nick!
Logged
Pages: [1]   Go Up
Print
Jump to:
