Loading...
Pages: [1]   Go Down
Author Topic: Need to hire someone for a project  (Read 377 times)
Offline Offline
Newbie
View Profile
Hey guys.....I am sure I can eventually figure out how to do this stuff but time constraints are going to limit me making this project work.
what I need to do is pretty simple, I need to make an arduino track the position of a rod and move it with a potentiometer.
basically I have an electro-hydraulic actuator that uses a 12vdc motor to move a rod in and out.....its basically a high speed high force linear actuator. the actuator is setup with 2 leads 1 for power and one for ground, hook it up one way and the shaft moves out and vice versa.
I was thinking of using https://www.sparkfun.com/products/8607 to track the position and then just another pot to move the shaft to the specified position.
I am sure this is a fairly simple setup but like I said I don't have much time to set it up and make it work.
I am willing to "hire" someone to help me out with this because I need it ready to go within a couple months.
you can email me @ r.parson@telus.net
thanks,
Logged
Pages: [1]   Go Up
Print
Jump to:
