Topic: NewTone Library - Plug-in replacement for Tone library - Better, smaller, faster (Read 38998 times) previous topic - next topic
Vantuil
Hello, I know it's an old topic, but I use the NewTone library a lot, the audio quality is flawless, I'm using it in a project with arduino nano, it's a variometer for flying, but I'm having a problem locking with it, I have only 1 pin available to turn on the speaker, so I did not use the toneAC, with the tone library works however the sound has a poor quality it gets distorted, I believe the problem is with TIMER 1, I would like to know if you have a way to modify the NewTone library to use TIMER 2, I believe this could solve the problem, is it possible?
Why another tone library?
I'd already written a highly optimized toneAC library because I needed higher volume, volume control, higher frequency, and better quality.  However, toneAC uses fixed timer 1 PWM pins so it's not as flexible.  Making toneAC work like tone was simple and there would be several advantages over the tone library, so I spent an hour and made NewTone from the toneAC library.
What does it do better/differently?
  • About 1,200 bytes smaller code size than the Tone library.
  • Faster execution time.
  • Exclusive use of port registers for fastest and smallest code.
  • Higher quality sound output than tone library.
  • Uses timer 1 which may free up conflicts with the tone library.
How do I use it?
It's a plug-in replacement for the standard tone library.  Add the include, use NewTone() instead of tone() and noNewTone() instead of noTone() to enjoy the benefits.  If you're running out of program space or have a timer conflict with the tone library, this is the library for you.  See the sketch below for an example.
Download: NewTone v1.0
If you're looking to save even more space and more features like almost twice as loud output and volume control, check out my toneAC library as well.
Example sketch
Code: [Select]
#include <NewTone.h>
#define TONE_PIN 2 // Pin you have speaker/piezo connected to (be sure to include a 100 ohm resistor).
// Melody (liberated from the toneMelody Arduino example sketch by Tom Igoe).
int melody[] = { 262, 196, 196, 220, 196, 0, 247, 262 };
int noteDurations[] = { 4, 8, 8, 4, 4, 4, 4, 4 };
void setup() {} // Nothing to setup, just start playing!
  for (unsigned long freq = 125; freq <= 15000; freq += 10) {
    NewTone(TONE_PIN, freq); // Play the frequency (125 Hz to 15 kHz sweep in 10 Hz steps).
    delay(1); // Wait 1 ms so you can hear it.
  noNewTone(TONE_PIN); // Turn off the tone.
  delay(1000); // Wait a second.
  for (int thisNote = 0; thisNote < 8; thisNote++) { // Loop through the notes in the array.
    int noteDuration = 1000/noteDurations[thisNote];
    NewTone(TONE_PIN, melody[thisNote], noteDuration); // Play thisNote for noteDuration.
    delay(noteDuration * 4 / 3); // Wait while the tone plays in the background, plus another 33% delay between notes.
  while(1); // Stop (so it doesn't repeat forever driving you crazy--you're welcome).
Tim
teckel
I also have a tone library that doesn't use any timers at all (TimerFreeTone), for just such a situation.
Tim
My platforms Arduino, Teensy 3.2, Arduino Pro Mini, ATmega328
My libraries: NewPing, LCDBitmap, toneAC, toneAC2, NewTone, TimerFreeTone
My projects: https://dogblocker.com & https://baconorbeer.com
My beer: Great Lakes Brewing Co. Lake Erie Monster
iliaka
Dear Tim,
In advance, English is not my native language  :smiley-sad:
First, thanks for sharing the NewTone-code.
One question you might be the perferct person for and you might be able an willing to help:
Do you know how to get a frequency in decimals? For instance 78,5Hz or 7,85Hz
As far as I see with NewTone I can use integer only.
Thanks,
Ed
teckel
Dear Tim,
Thanks,
Ed
Simple answer, you can't, as it's integer-based only.
Tim
