Topic: Twittering with Arduino+Ethernet Shield (Read 6793 times) previous topic - next topic
Abelavit
Oh great...so it was posting twice.
Its working perfectly now.
Had to do the posting part in void loop.
Thanks for your help guys.
Frisky
Peter
I think that after the Ardunio programs it resets and runs his code. Then he is watching it via serial monitor to debug and that is why he is double posting or tweeting that will give you a 403 since he is sending the same message. He will need to change his tweet some too since he can't keep sending the same thing.
Maybe read millis
unsigned long time;
time = millis();
 //prints time since program started
client.println(time);
Abelavit
Did the posting bit in void loop
Thanks guys for your help.
mkwired
I am using my universities network so due to restrictions, I cannot use DHCP to automatically assign the IP hence iam doing it manually.
Ok i declared the DNS server IP:
IPAddress myDns(168, 126, 63, 1);
Ethernet.begin(mac, ip, myDns);
It gives the following result:
117.17.80.199
255.255.255.0
117.17.80.1
168.126.63.1
connecting ...
HTTP/1.0 403 Forbidden
Content-Type: text/html; charset=utf-8
Cache-Control: no-cache
Vary: Accept-Encoding
Date: Thu, 24 Jan 2013 01:19:45 GMT
Server: Google Frontend
Error 403 - Status is a duplicate.
failed : code 403
what might be wrong now?
There maybe a problem in the future if some other computer starts using that assigned IP assigned.  It would be nice if the university would give you another IP address for your *second* computer.
Mark-OE
whataslacker
Earlier in the week I had my Arduino Duemilanove with ethernet shield tweeting the SimplePost examlpe from my office PC, Now that I have it at home I cannot get it to work. Have attempted some of the stuff above to try and get reading but nothing. I have made no changes to the SimplePost example other than the IP and OAUTH token. No idea why it would work on one network and not another. Ideas?
Major newbie here.
Any help would be much appreciated.
rpabl001
HI, i am trying to post on my twitter account and I cant, anyone can help me put in this pls.
Delta_G
Should probably start your own thread for your own question.
Have you read and understood what these other posters were doing?  They seem to have it working.  What have you tried?
Ad hoc, ad loc, and quid pro quo.  So little time - so much to know!  ~Jeremy Hillary Boob Ph.D
rpabl001
Thanks for your quick response. Yes I have read everything but i am not being able to post anything on twitter. I have the w5200 ethernet shield, dont know if its the same as the others.
Delta_G
First:  Read this:  How To Use This Forum
Second:  Go start your own thread for this question.  You can provide a link to this one if you want.
Third:  In your new thread, post your code.  All of your code.  Use code tags when you do.  We can't tell what you've done wrong without seeing your code.  (Code tags explained in point 7 of the link in the First step above)
PaulMurrayCbr
Any sort of 'bot activity on twitter means that your account gets blocked. Twitter sort of feels that it is not really in the business of providing a universal info bus to anyone who wants one.
http://paulmurraycbr.github.io/ArduinoTheOOWay.html
zoomkat
Two possible things, 1) I think twitter uses https which the arduino etherent shield setup does not support, and 2) I think the w5200 ethernet shield uses a different library than the w5100 ethernet shield.
Tehnicni
With IDE 160 and 167 I get only connecting ....
with IDE 105 and CodeBlock 13.12 work OK
IDE 160 and 167 use same Ethernet lib as CodeBlock
#if defined(ARDUINO) && ARDUINO > 18   // Arduino 0019 or later
#include <SPI.h>
#endif
#include <Ethernet.h>
//#include <EthernetDNS.h>  Only needed in Arduino 0022 or earlier
#include <Twitter.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 50 };
byte ip[] = {192,168,1,50};
Twitter twitter("______________________");
char msg[] = "Test tweet from Arduino";
  Ethernet.begin(mac, ip);
  Serial.println("connecting ...");
  if (twitter.post(msg)) {
    //int status = twitter.wait();
    int status = twitter.wait(&Serial);
    if (status == 200) {
      Serial.println("OK.");
      Serial.print("failed : code ");
      Serial.println(status);
    Serial.println("connection failed.");
PaulS
What about the currently supported version, 1.6.11?
Well, then, you know what to do.
