Topic: Arduino Uno ds18b20 and sure 2416 dor matrix display (Read 6904 times) previous topic - next topic
UKHeliBob
Some questions :
What do you get on the screen if you just output buffer[0] ?
Does the same problem occur if you output the temperature to somewhere else on the screen ?
What happens if you output  the temperature twice ?  Output it once then output it again without clearing the screen ?
What does your code do to the screen immediately before showing the temperature ?
What happens if you print some text before the temperature ?
What happens if you put a specific value in the buffer without reading the temperature then output it ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
danielb
this is with the code posted
( fot.jpg)
i tryed to give a value and it put on display it and it show the value
( exaple 22.50 )
sensors.requestTemperatures();
float TempC = 22.50 ;//sensors.getTempCByIndex(0);
Serial.println(TempC,DEC);
      char buffer[4];
      itoa(TempC,buffer,10);
      ht1632_putchar(0 , 8, buffer[0]);
      ht1632_putchar(6 , 8, buffer[1]);
      ht1632_putchar(12 , 8, buffer[2]);
      ht1632_putchar(18 , 8, buffer[3]);
      ht1632_putchar(24 , 8, buffer[3]);
      ht1632_puttinychar(32 , 8, 'o');
      ht1632_putchar(39 , 8, 'C');
      delay(150);
this is the result ( foto22.jpg )
thanks in advance
danielb
if i write float TempC =  2250;
show 22500 °C
in serial monitor
show the temperature in this way :  19.4375000000
I think the problem is the decimal
I must divide 19 from 43 without the dot ( or comma )
put 19 into a buffer and the 43 into another buffer
then show it
Right ???
thanks
johncc
#18
Jan 22, 2013, 02:48 pm Last Edit: Jan 22, 2013, 03:09 pm by johncc Reason: 1
show 22500 °C
in serial monitor
That's strange, I would expect to see: 2250 , wouldn't you?
Quote
then show it
Right ???
thanks
Pretty much.  You will need to adjust your buffer size to 5 and/or adjust your placement on the screen if you want to be able to show "19.43", since that is five characters and your existing code uses four.  Or, you could show it as "19.4" and leave it where it is on the screen.
John
danielb
yes of course
but i can resolve 22500 problem display but not my BIG problem
If I write
float TempC = sensors.getTempCByIndex(0);
I should see something !!! not e127 that is the error when someting goes wrong !!
I need help for this
resolve 22550 end not 22 50 will be able to resolve !!
danielb
hi guys
don't rell me how but now it WORKS !!!
this is the correct code
int temp = sensors.getTempCByIndex(0);
Serial.println(temp,DEC);
      char buffer[4];
      itoa(temp,buffer,10);
      ht1632_putchar(6 , 8, buffer[0]);
      ht1632_putchar(12 , 8, buffer[1]);
//     ht1632_putchar(12 , 8, buffer[2]);
//     ht1632_putchar(18 , 8, buffer[3]);
      ht1632_puttinychar(19 , 8, 'o');
      ht1632_putchar(24 , 8, 'C');
      delay(150);
only one question ( easy i think )
now it show the temperature in this format XX °C
and if I would like to show decimal ?
ie   XX,X °C ?
how I should change it ?
Many thanks
Daniel
PaulS
Quote
Based on snippets? Who knows? Post ALL of your code. Right now, we can only guess what sensors is.
Code: [Select]
Does that method return an int? Or a float?
danielb
Pauls Thank you for your answer
the kind of sensor il write on the topic and on the top post... SENSOR IS DALLAS DS18B20
the entire code was just posted so I repost
Thank you so much
Daniele
PaulS
Code: [Select]
  // returns temperature in degrees C
  float getTempC(uint8_t*);
  // returns temperature in degrees F
  float getTempF(uint8_t*);
  // Get temperature for device index (slow)
  float getTempCByIndex(uint8_t);
  float getTempFByIndex(uint8_t);
So, yes all the methods to get the temperature return a float, not an int.
Your buffer will need to be larger, and you'll need to use ftoa(), instead of itoa(). After that, you'll need to put more characters to the display.
danielb
thanks
so what i change ?
to
float temp = sensors.getTempCByIndex(0);  ???
then ?
( I think I must change sometingh here but how ? )
char buffer[4];
Many thanks
Daniel
PaulS
Quote
Quote
danielb
if i change
to
ftoa(temp,buffer,10);
I receive this error
lcd24x16_base___temperatura.cpp: In function 'void loop()':
lcd24x16_base___temperatura:112: error: 'ftoa' was not declared in this scope
where is the problem ?
PaulS
danielb
lcd24x16_base___temperatura:112: error: invalid conversion from 'char*' to 'signed char'
c:/users/daniele/desktop/varie2/arduino-0023/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:581: error: too few arguments to function 'char* dtostrf(double, signed char, unsigned char, char*)'
lcd24x16_base___temperatura:112: error: at this point in file
PeterH
You aren't passing the correct number and type of arguments to dtostrf(). The documentation tells you what it expects. Only you know what you're actually providing, since we can't see your code, but it's obviously not correct. Change your code so it passes the arguments that the function expects.
