Pages: [1] 2 3   Go Down
Author Topic: Arduino Uno ds18b20 and sure 2416 dor matrix display  (Read 588 times)
Hi everybody
I'm Daniele from Italy and I'm happy to be here.
I'm tryng to dispaly a temperature by this display ( i've read everything )
but I've got a big problem
I see on dispaly      e127 °C
and if i unplug +5 volts to ds18b20 it become 0 27 °C
this is the code that I wrote
Serial.println(temperature,DEC);
      char buffer[4];
      itoa(temperature,buffer,10);
      ht1632_putchar(0 , 0, buffer[0]);
      ht1632_putchar(6 , 0, buffer[1]);
      ht1632_putchar(12 , 0, buffer[2]);
      ht1632_putchar(18 , 0, buffer[3]);
      ht1632_puttinychar(26 , 0, 'o');
      ht1632_putchar(33 , 0, 'C');
      delay(150);
any idea ???
thank you so much
Daniele
Seattle, WA USA
Seattle, WA USA
Why does that surprise you? If the sensor isn't powered, it can't function. If it can't function, you really can't expect to read a temperature from it, can you?
Of course, it's hard to tell much from your snippet of code.
thank you so much !
of course that if the sensor isn't powered it doesn't works !
i try it to be sure that the input pin was correct and the buffer was filled by data !
I shoult post full code ?
this is the full code
I use pin 13 of atmel ( input 7 of arduino )
Temple, Texas
I think there needs to be a call to "sensors.requestTemperatures()" and "sensors.getTemp..." in there.  Did you look at the sample code for DallasTemperature?
thanks for your answer
"sensors.requestTemperatures()"  ( i forgot to write it on here but is present on sketch )
what and where else exatly ?
char temperature = 0 ;
sensors.requestTemperatures();
      char buffer[4];
      delay(150);
thanks
sorry for multiple post
like this ??
temperature = (sensors.getTempCByIndex(0));
      char buffer[4];
      delay(150);
Temple, Texas
That does look much closer to being right.
getTempCByIndex() does not return a char though, it returns float.
ahhhh so  what i should change ??
float temperature = 0 ??
thanks in advance
Temple, Texas
Actually no, sorry, you were better off with the char, you just won't be getting fractional degrees.
I don't understand.
I' can't convert ?
What's the problem with decimal ?
ie I can't show on this dispaly 22,5 °C ?
Temple, Texas
I think at this point you should just try it and see.
  float temperature=0 ;
      char buffer[4];
      delay(150);
do not works... e127 °C show
Temple, Texas
Which part do you suppose is not working-- the part that reads the temperature from the sensor, or the part that displays the temperature on the LCD screen?
I think that inside buffer there is nothing becouse it write 127. The ds 18b20 works perfectly becouse with lcd skecht show the correct temperature
Pages: [1] 2 3   Go Up
