United Kingdom
Offline
Faraday Member
« Reply #30 on: January 28, 2013, 08:29:22 am » |
The resistors go the other way round (470 ohm to the lower transistor, 100 ohm to the upper transistor), and both the 1.5V and the 3.5V need to be increased to 5V if you want to feed about 3.5V to the motor.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Queens, New York
Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
« Reply #31 on: January 28, 2013, 08:30:52 am » |
Yes but swap the resistors around, and provide 5volts (not 1.5v) to the base and 6-9volts(not 3.5v) to the actual power source.
Edit: dc42 beat me to it.
Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
isabela, philippines.
Offline
Jr. Member
if you dont go, you will never know.
« Reply #32 on: January 29, 2013, 10:53:31 am » |
thanks for the help, but my problem is in the robots motor. it only has lower than 4v i think for its dc motor, and i want to amplify it to a bigger volts. and replacing its motor to a bigger motor,. 6v motor. pls help me. read my past post for more info. thanks.
Logged
jaylisto
Queens, New York
Offline
Edison Member
« Reply #33 on: January 29, 2013, 11:09:47 am » |
Can you show us a picture? What is this motor in, does it have its own housing, holding it in place. You might not be able to change it.
Post a picture, that way we will have a better understanding of what your trying to do.
Logged
Offline
Jr. Member
« Reply #34 on: January 29, 2013, 10:22:06 pm » |
i want to amplify the volts produced by the line follower to power its dc motor, since its to weak to carry my sla 7v battery so i will modify my dc motor to a bigger and stronger one,. the logic of hbridge is correct but the hbridge wont work at all.     the power source of the robot is also from the sla battery.
« Last Edit: January 29, 2013, 10:24:37 pm by jaylisto »
Logged
jaylisto
Queens, New York
Offline
Edison Member
« Reply #35 on: January 29, 2013, 11:40:01 pm » |
Those motors are going to require a lot of current, your best bet now would be to get a actually Hbridge board. http://item.mobileweb.ebay.com/viewitem?itemId=251080674810&index=1&nav=SEARCH&nid=83702557639
Logged
Offline
Jr. Member
« Reply #36 on: January 30, 2013, 02:57:35 am » |
you know i cant, because im in the philippines, im in the part of the philippines where those items are not available. i would travel far away to the capital manila to get those items. is their any one that can help me using only basic transistors? i think i will not found the answer any more. for ever. i am loosing my hope now
Logged
jaylisto
Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #37 on: January 30, 2013, 03:00:20 am » |
Can you get hold of DPDT relays (or SPDT relays)? Use those instead of the H-bridge. I think I've already suggested this.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
UK
Offline
Tesla Member
« Reply #38 on: January 30, 2013, 08:01:02 am » |
Hardly surprising - that battery is absurdly oversize for a 'bot that small. How many months were you hoping this thing would run between recharges?
Logged
Queens, New York
Offline
Edison Member
« Reply #39 on: January 30, 2013, 08:15:37 am » |
« Last Edit: January 30, 2013, 08:18:19 am by HazardsMind »
Logged
Offline
Jr. Member
« Reply #40 on: January 30, 2013, 10:01:59 am » |
what is the difference between the normal transisotr switch and a darlington connection?
Logged
jaylisto
Global Moderator
UK
Offline
Brattain Member
« Reply #41 on: January 30, 2013, 10:03:03 am » |
what is the difference between the normal transisotr switch and a darlington connection? Much higher gain
Logged
Offline
Jr. Member
« Reply #42 on: January 30, 2013, 10:06:44 am » |
i searched it in google, the dpdt relay. i think that is not possible. the dc motor continues to turn in a direction if there is no voltage in the relay...
Logged
jaylisto
Offline
Jr. Member
« Reply #43 on: January 30, 2013, 10:08:09 am » |
what is the difference between the normal transisotr switch and a darlington connection? Much higher gain thanks for the fast reply. the darlington has no resistor in the base?
Logged
jaylisto
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #44 on: January 30, 2013, 10:10:48 am » |
i searched it in google, the dpdt relay. i think that is not possible. the dc motor continues to turn in a direction if there is no voltage in the relay... You need to use two relays, one DPDT to determine forward/reverse and a one SPST to to perform the stop/go command, this second relay's contacts is simply wired in series with the positive voltage coming from the motor battery. Lefty
Logged
