United Kingdom
Online
« Reply #15 on: January 23, 2013, 03:27:21 am » |
isabela, philippines.
if you dont go, you will never know.
« Reply #16 on: January 23, 2013, 07:45:20 am » |
thanks. i will review that link. by the way an out of topic question since you look like an intelligence person. can i charge panasonic sla 6v battery (Panasonic LC-RB064P) by my 7.5v 500mA ac to dc adaptor? take note that the battery is 4ah and my charger has only 500mA....
jaylisto
« Reply #17 on: January 23, 2013, 07:56:48 am » |
i notice in your first link. does it use npn transistors? because i think you can only use npn for switching device by putting the load before pin 2(collectors pin) ... can you put it after the emitter pin?.
jaylisto
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
« Reply #18 on: January 23, 2013, 07:59:46 am » |
The schematic in the first link does use NPN transistors. I've used that design for years, and it does work.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
United Kingdom
Online
« Reply #19 on: January 23, 2013, 09:03:37 am » |
4ah is a measure of capacity, not current. If your 7.5v adaptor has a regulated output, then you can charge your 6V SLA battery through a silicon diode (1N4001 or similar) and small series resistor (I suggest 10 ohms 3W if the battery is really flat, or about 2 ohms if it is still reading 6V). The higher the resistor value, the longer it will take to charge. If it has an unregulated output, you can still charge your battery through a 10 ohm 3W resistor, but you should stop charging it when the voltage reaches the value specified in the datasheet (probably about 6.8V).
UK
Online
« Reply #20 on: January 23, 2013, 09:05:10 am » |
OP PLEASE STOP CROSS-POSTING. This wastes time.
« Reply #21 on: January 25, 2013, 07:59:50 am » |
If your following the first link I gave you then, tip 41, should be fine. But looking at the data sheet, its made for high voltage applications. Kinda overkill for your project. You may just want to get some 2n3904 or 2n3906 NPN transistors from RadioShack, or simply a H-bridge DC Driver IC.
dude! i came from the store from the nearest city, i it is not available. they give me numbers of transistors and i picked 2n551 since its the nearest number from what you have given. the question is do the 2n5551 can handle the 7v? i wried its data shit but i dont understand what it means
jaylisto
Queens, New York
« Reply #22 on: January 25, 2013, 08:16:57 am » |
The 2n5551 is fine, the maximum voltage it can handle is 160 volts, so 7 volts should be nothing to it.
« Reply #23 on: January 25, 2013, 09:12:23 am » |
wow, what did you say? 160vots for that little tiny transistor? absolutely incredible offer.
jaylisto
« Reply #24 on: January 27, 2013, 06:59:48 am » |
the led or the load has no problem switching if its in the collectors pin but when the led is in the emitter, the led will not light. no switching is done.
as well as the hbridge. it seems impossible to make it work. whats wrong with it? connections of pins are correct.
jaylisto
Queens, New York
« Reply #25 on: January 27, 2013, 09:33:25 am » |
Double check your wiring, and make sure only one side of the H bridge is on at a time.
« Reply #26 on: January 27, 2013, 11:04:13 pm » |
 this half of the hbridge didnt also work. as the first transistor doesn't triggered since the load is in the emitter.
jaylisto
Queens, New York
« Reply #27 on: January 27, 2013, 11:42:41 pm » |
I don't think 3.5 volts is enough to drive that circuit. Try 6 or 9 volts, and 5v at the base.
United Kingdom
Online
« Reply #28 on: January 28, 2013, 03:33:09 am » |
That circuit will not work as it stands and may damage the lower transistor because there is no resistor to limit the base current. Put a 100 ohm resistor in series with the base of the upper transistor, and a 470 ohm resistor in series with the base of the lower transistor. Increase both the power supply voltage and the drive voltage to 5V. That will give you about 3V or 3.5V across the load.
« Reply #29 on: January 28, 2013, 08:04:30 am » |
is this what your trying to express?
jaylisto
