Loading...
Pages: 1 ... 3 4 [5]   Go Down
Author Topic: VirtualWire  (Read 1241 times)
Offline Offline
Full Member
View Profile
True or false is different from HIGH or LOW right ?
i
Code:
f (variable==true)
 Do this
if (variable == false)
Do that
if (variable == HIGH)
Do this
if (variable ==LOW)
{ Do that}
Correct me if I am wrong
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Yes.
The if(variable == true) test is silly. If variable is true, the test evaluates to true == true, which is true. So, the initial test could simply have been if(variable). That is the convention for testing boolean variables. To do something when the variable contains false, you use if(!variable) (if not true).
For non-boolean variables, the 3rd and 4th examples are correct.
Logged
Offline Offline
Full Member
View Profile
what's the difference between boolean variable and non-boolean ? AND OR ?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
One is a boolean variable. The other is not. It might be an int, a float, a double, a long, a char, a byte, a long long, etc.
Logged
Offline Offline
Full Member
View Profile
Ok. I think is like this
Code:
If (x>y)
--> this is example of boolean variable which will return either true or false.
Code:
If (variable==HIGH)
--> This is non boolean variable..
Am I correct ?
Thanks
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
No, that is an example of two int (I'm assuming) values being compared. Comparing boolean variables using > doesn't make sense.
Quote
The statement itself does not provide enough information to answer the question. What is the type of variable? That is what determines how to write the statement. It doesn't make sense to compare a boolean variable (containing true or false) to HIGH or LOW. So, it appears that the statement does not involve a boolean variable.
Logged
Offline Offline
Full Member
View Profile
Can you give me some simple example to illustrate that ?
Thanks
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Can you learn to ask better questions? To illustrate what?
Logged
Offline Offline
Full Member
View Profile
Illustrate the difference between boolean variable and non-boolean variable smiley-grin
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Code:
boolean dense = false;
if(!dense)
   byte IQ = 14;
   byte min = 100;
   if(IQ > min)
      // Smart enough
      dense = true;
Logged
Pages: 1 ... 3 4 [5]   Go Up
Print
Jump to:
