Topic: VirtualWire (Read 9231 times) previous topic - next topic
Vincent19
Modified ! Thanks . hope you can help me
AWOL
What does it means ?
In a nutshell, see if there's any data to read, read it
if (vw_get_message(buf, &buflen)), and then print it
for (i = 0; i < buflen; i++)
    Serial.print((char)buf[i]);
    Serial.print(" ");
Vincent19
Is this the syntax ? Thanks
Vincent19
    Serial.print(" ");
Then how about vw_have_message()?
AWOL
From the reference:
uint8_t vw_have_message    (       )
Returns:
    true if a message is available to read
Vincent19
OK..so means I can use the idea that vw_have_message () then do something ?
AWOL
If you don't mind blocking, you could just use "vw_wait_rx", or just use "vw_get_message" as you've shown.
Vincent19
Blocking of what ? Blocking of the signal from transmitter ?
AWOL
No, blocking of your code, waiting for a message to arrive.
Vincent19
Oh..it means the code sometimes will fail to execute ? Am I correct ?
AWOL
During development, code will always sometimes fail to execute as we expect it to.
But, no, you are not correct. "Blocking" means the code will loop waiting until a message is received. This may or may not be a problem for you.
The great thing about the Arduino is that you can try things, and if they don't work, try something different.
The frequency of your questions leads me to suspect you're not trying the things you're asking about.
Vincent19
Cool..yea I shall work for it now..thanks so much ..This library is easy to use !
PaulS
So from this can I say uint8_t is like a data type ?
It isn't "like a data type". It IS a data type, just like int, float, byte, char, long, etc.
The u up front indicates unsigned. The int differentiates the type from floating point types. The 8 explicitly defines the size of the variables, in bits. The _t indicates that the type is a standard type. Every compiler is supposed to recognize the type, and allocate the same space for it.
This is not true of types like int. An int can be 16 bits, 32 bits, or 64 bits (or other unusual sizes), depending on the platform. A uint8_t is always 8 bits. A int32_t is always 32 bits. A uint64_t is always 64 bits.
Vincent19
#include <VirtualWire.h>
#undef int
#undef abs
#undef double
#undef float
#undef round
    Serial.begin(9600); // Debugging only
    Serial.println("setup");
    // Initialise the IO and ISR
    vw_set_ptt_inverted(true); // Required for DR3100
    vw_setup(2000); // Bits per sec
    vw_rx_start();       // Start the receiver PLL running
    pinMode(13, OUTPUT);
  uint8_t count;
if(count==true)
  count = false;
  count = vw_wait_rx_max(2000);// Non-blocking
  if (true)
        digitalWrite(13, HIGH); // Flash a light to show received good message
delay(500);// Message with a good checksum received, dump it.
digitalWrite(13, LOW);
  else if(false)
    delay(100);
    digitalWrite(13,LOW);
    delay(100);
I write this code..I want it to be like when it does not receive message for 2s, then it will return false. If it receive message, then return true. Then it will only blink once then the whole system become false again. So what moddification I need to do ?
Thanks
AWOL
#44
Jan 22, 2013, 01:27 pm Last Edit: Jan 22, 2013, 02:36 pm by AWOL Reason: 1
 uint8_t count;
if(count==true)
It doesn't make sense to test an automatic variable like this.
If you want "count" to retain its value, make it "static".
if (true)
Will always be true.
if(false)
Will always be false.
