Pages: 1 2 3 [4] 5   Go Down
Author Topic: VirtualWire  (Read 1341 times)
Then how can I implement my that idea ?
Seattle, WA USA
Seattle, WA USA
Seeing as how you are the only one that has a clue what your idea is, I think the answer is "by yourself".
UK
Did you mean
count = vw_wait_rx_max(2000);// Non-blocking
  if (count)
USA
This is a really great thread. However, Wouldnt it be easier for all of us newbs if someone would just take the time to make a document or tutorial of this information (in plain terms)? This seems to be a hot topic. Not only here but also in other forums as well. I have learned a great deal just reading the questions and answers on this thread and like a good movie, I don't want it to end...LOL
Boston area, metrowest
Online Online
Maybe a real world example would be appropriate. I can post my remote control code. It reads a keypad press and sends out 1 character.
On the receive side, it acts on the 1 character received.
Will be later tonight. The code is from the Virtualwire example, with the message sent being a 1 byte array
byte msg[1];
with the byte coming from the keypad.h library.
http://www.open.com.au/mikem/arduino/VirtualWire.pdf
Hmm, looks like the document has been updated to remove the examples!
They look to be online only now
http://www.open.com.au/mikem/arduino/VirtualWire/examples.html
UK
I tend to disagree.
This is the first thread on the topic that I can remember in recent times.
I haven't used the library for at least two years.
Please, feel free to kick it off.
USA
I may. However, I am still trying to understand it myself...LOL For now I will just have to keep bugging everyone here. You guys have great responses and are very responsive so thats not a bad thing.. at least not for me...
Online Online
Here's my loop code for sendinng out keypad presses:
    // go read the keypad
  char key = keypad.getKey();                 // reading the keypad
  if(key)                                     // same as if(key != NO_KEY)- did something change?
    msg[0]=key;                               // load the array with the key character
    // msg[1]=NULL;                           // Rx side seems to work without this
    digitalWrite(ledPin, true);               // Flash a light to show transmitting
    vw_send((uint8_t *)msg, strlen(msg));     // send the character out
//    Serial.println(key);                // for debugging only
    vw_wait_tx();                             // Wait until the whole message is gone
    delay (50);                               // need some delay or seem to miss key presses
    digitalWrite(ledPin, false);              // turn off the flash of LED
  }                                           // end of if(key) & transmitting a character
// do other stuff...
}                                             // end of void loop
and on the receive side
void loop(){
// look for wireless input or for unsolicited message from remote transmitter
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
  int i;
  digitalWrite(ledPin, LOW); // Turn on LED to show working a message
    switch ( buf[0] )
    {    // switch on the first byte in the array for now
    // caes '0':, case'1':,  2,3,4,5,6,7,8,9,A,B,C, thru case 'D':, case '*':, and case '#': sections follow for my 16 button keypad
USA
http://genericnerd.blogspot.com/2012/07/arduino-sending-integers-over-rf-with.html
I found this useful for understanding VW a little better. Just make sure that you match the vw_setup(2000) on the transmitter sketch and the receiver sketch if you download the code from that site because they are mismatched and will not work that way.
  uint8_t count;
if(count==true)
It doesn't make sense to test an automatic variable like this.
If you want "count" to retain its value, make it "static".
if (true)
Will always be true.
]if(false)
Will always be false.
Awh, editted your code. By the way, I do not understand the bolded part.
Thanks
« Last Edit: January 26, 2013, 05:31:12 am by Vincent19 » Logged
UK
If you sort out the tags, I'll be able to see what you mean by the bolded part
Modified !
UK
The constant "true" will always be true, so if you say
if(true)
, whatever follows the experession will always be executed.
If you say
if (false)
, then whatever follows will never be executed.
That's fundamental.
« Last Edit: January 26, 2013, 07:02:59 am by AWOL » Logged
Oh, so it will be a different story if I assigned a variable to be 'true' or ;false' ?
Correct ?
Seattle, WA USA
Seattle, WA USA
Correct ?
The action, based on whether the variable contains true or false, will be the same. Which action is performed will be different IF you assign the value correctly and IF you write the test correctly.
Pages: 1 2 3 [4] 5   Go Up
