Topic: VirtualWire (Read 9213 times) previous topic - next topic
Vincent19
True or false is different from HIGH or LOW right ?
i
f (variable==true)
Do this
if (variable == false)
Do that
if (variable == HIGH)
Do this
if (variable ==LOW)
{ Do that}
Correct me if I am wrong
PaulS
Yes.
The if(variable == true) test is silly. If variable is true, the test evaluates to true == true, which is true. So, the initial test could simply have been if(variable). That is the convention for testing boolean variables. To do something when the variable contains false, you use if(!variable) (if not true).
For non-boolean variables, the 3rd and 4th examples are correct.
Vincent19
what's the difference between boolean variable and non-boolean ? AND OR ?
PaulS
One is a boolean variable. The other is not. It might be an int, a float, a double, a long, a char, a byte, a long long, etc.
Vincent19
Ok. I think is like this
If (x>y) --> this is example of boolean variable which will return either true or false.
If (variable==HIGH) --> This is non boolean variable..
Am I correct ?
Thanks
PaulS
No, that is an example of two int (I'm assuming) values being compared. Comparing boolean variables using > doesn't make sense.
The statement itself does not provide enough information to answer the question. What is the type of variable? That is what determines how to write the statement. It doesn't make sense to compare a boolean variable (containing true or false) to HIGH or LOW. So, it appears that the statement does not involve a boolean variable.
Vincent19
Can you give me some simple example to illustrate that ?
Thanks
PaulS
Can you learn to ask better questions? To illustrate what?
Vincent19
Illustrate the difference between boolean variable and non-boolean variable :D
PaulS
boolean dense = false;
if(!dense)
   byte IQ = 14;
   byte min = 100;
   if(IQ > min)
      // Smart enough
      dense = true;
