Pages: 1 ... 3 4 [5]   Go Down
Author Topic: VirtualWire  (Read 1235 times)
True or false is different from HIGH or LOW right ?
i
f (variable==true)
 Do this
if (variable == false)
Do that
if (variable == HIGH)
Do this
if (variable ==LOW)
{ Do that}
Correct me if I am wrong
Seattle, WA USA
Online Online
Seattle, WA USA
Yes.
The if(variable == true) test is silly. If variable is true, the test evaluates to true == true, which is true. So, the initial test could simply have been if(variable). That is the convention for testing boolean variables. To do something when the variable contains false, you use if(!variable) (if not true).
For non-boolean variables, the 3rd and 4th examples are correct.
what's the difference between boolean variable and non-boolean ? AND OR ?
Seattle, WA USA
Online Online
Seattle, WA USA
One is a boolean variable. The other is not. It might be an int, a float, a double, a long, a char, a byte, a long long, etc.
Ok. I think is like this
If (x>y)
--> this is example of boolean variable which will return either true or false.
If (variable==HIGH)
--> This is non boolean variable..
Am I correct ?
Thanks
Seattle, WA USA
Online Online
Seattle, WA USA
No, that is an example of two int (I'm assuming) values being compared. Comparing boolean variables using > doesn't make sense.
The statement itself does not provide enough information to answer the question. What is the type of variable? That is what determines how to write the statement. It doesn't make sense to compare a boolean variable (containing true or false) to HIGH or LOW. So, it appears that the statement does not involve a boolean variable.
Can you give me some simple example to illustrate that ?
Thanks
Seattle, WA USA
Online Online
Seattle, WA USA
Can you learn to ask better questions? To illustrate what?
Illustrate the difference between boolean variable and non-boolean variable smiley-grin
Seattle, WA USA
Online Online
Seattle, WA USA
boolean dense = false;
if(!dense)
   byte IQ = 14;
   byte min = 100;
   if(IQ > min)
      // Smart enough
      dense = true;
Pages: 1 ... 3 4 [5]   Go Up
