Topic: use ds1813-10 as temperature sensor ? (Read 969 times) previous topic - next topic
sobbat
Hello everyone  :),
I started my arduino learding 15 days ago. I had a little knowledge in eletrotechnic and webdev that helps a bit.
Now I'm trying to have a temperature sensor with the ds1813-10.
I found the datasheet but I'm not able to understand it :
-> http://www.datasheetarchive.com/DS1813-10-datasheet.html
Does this component is usualy used in that purpose ?
if yes, do you know a tutorial or schematic that can help me please ?
Thank you,
Sobbat
johnwasser
The DS1813 is not a temperature sensor.  It is used to reset a system if the power supply goes low.  The -10 model will reset if the voltage goes below about 4.35V.
http://www.mouser.com/ds/2/256/DS1813-93440.pdf
It does include a temperature sensor but that is only to provide internal temperature compensation for the voltage detector.
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
sobbat
#2
Jan 19, 2013, 04:12 pm Last Edit: Jan 19, 2013, 04:15 pm by sobbat Reason: 1
ah ok, so next time in the electronic shop I'll chose the component with the shop owner  :D
thank you for your help !!
last question :) Would you have advices about a website to find good datasheets (as the one you find for ds1813-10) ?
pwillard
johnwasser
#4
Jan 20, 2013, 05:42 pm Last Edit: Jan 20, 2013, 05:45 pm by johnwasser Reason: 1
I type the part number into Google.  My first choice is the manufacturer's official website (Maxim, TI, Microchip...) but if that doesn't show up in the first page of results I will often see one of the major online vendors: DigiKey.com, Mouser.com, adafruit, sparkfun...  They usually have datasheets for chips they sell.
This time it was Mouser that came up first. :)
I HATE the big datasheet aggregators.  They often make you click through several pages and often don't have good search results.  I almost never add the word 'datasheet' to my search because all the aggregators try to be high in the search results for that keyword.
pwillard
while datasheetcatalog is not as complete, it is the friendliest of those available that i have found.  The others, like datasheetarchive.. are maddening.
Docedison
That is the link I use for ALL my first searches try adding /key/Part# (whichever part you're looking for) to the end of the URL posted. That's a great source for ALL data sheets.
Now... Does anyone have a link to the National Semiconductor Linear Application Books (Vol 1 - 3)?
Those were my 'bibles' when learning things... Linear.
Bob
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
sobbat
thank you for all thoses good advices and tips ;) !!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
