Loading...
Pages: [1]   Go Down
Author Topic: Leonardo & Micro — Changing Timer Pin Mapping Registers: Help needed  (Read 187 times)
Offline Offline
Newbie
View Profile
Hi everyone,
Short version of a long story:
It's about a Arduino Micro (32u4) and I need to change the mapping of the timers to the board pins.
I have read lost of stuff on the internet but the learning curve is too steep!
Quote
Pin D11 can also be set to use timer 1 output (OC1C), but the Arduino library uses it for timer 0 (8-bit). To use it on timer 1, it must be done by setting the appropriate registers.
Pin D10 (PB6) also has a timer 4 output (OC4B), but the Arduino library uses it for timer 1 (16-bit). To use it on timer 4, it must with the registers.
That is exactly what I need.
Pin D11: OC0A => OC1C
Pin D10: OC1B => OC4B
Can somebody give me the code fragment that will accomplish this?
Is it advisable to change the Arduino pin mapping directly in the 'framework'?
Many thanks in advance!
Christophe
Logged
Pages: [1]   Go Up
Print
Jump to:
