hazerty565 merci beaucoup , sur le site que tu donne
http://bildr.org/2012/11/sht15-arduino/ il précise que le sht15 n'utilise pas le protocole i2c est qu'il est possible d'utiliser n'importe quel pin ( digital ) de l'arduino pour la communication. de plus le code fourni sur le site permet de rajouter facilement plusieurs sht15 car il est bien détaillé.
que du bonheur , dommage je me suis tournée vers autre chose comme sonde!!! lool . enfin l'info est la .
//Based of the wiring code at http://wiring.org.co/learning/basics/humiditytemperaturesht15.html
int SHT_clockPin = 3; // pin used for clock
int SHT_dataPin = 2; // pin used for data
void setup(){
Serial.begin(9600); // open serial at 9600 bps
void loop(){
//these can take a bit to get the values (100ms or so)
float temperature = getTemperature();
float humidity = getHumidity();
Serial.print(temperature);
Serial.print(" | ");
Serial.println(humidity);
float getTemperature(){
//Return Temperature in Celsius
SHT_sendCommand(B00000011, SHT_dataPin, SHT_clockPin);
SHT_waitForResult(SHT_dataPin);
int val = SHT_getData(SHT_dataPin, SHT_clockPin);
SHT_skipCrc(SHT_dataPin, SHT_clockPin);
return (float)val * 0.01 - 40; //convert to celsius
float getHumidity(){
//Return Relative Humidity
SHT_sendCommand(B00000101, SHT_dataPin, SHT_clockPin);
return -4.0 + 0.0405 * val + -0.0000028 * val * val;
void SHT_sendCommand(int command, int dataPin, int clockPin){
// send a command to the SHTx sensor
// transmission start
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
digitalWrite(dataPin, HIGH);
digitalWrite(clockPin, HIGH);
digitalWrite(dataPin, LOW);
digitalWrite(clockPin, LOW);
// shift out the command (the 3 MSB are address and must be 000, the last 5 bits are the command)
shiftOut(dataPin, clockPin, MSBFIRST, command);
// verify we get the right ACK
pinMode(dataPin, INPUT);
if (digitalRead(dataPin)) Serial.println("ACK error 0");
if (!digitalRead(dataPin)) Serial.println("ACK error 1");
void SHT_waitForResult(int dataPin){
// wait for the SHTx answer
int ack; //acknowledgement
//need to wait up to 2 seconds for the value
for (int i = 0; i < 1000; ++i){
delay(2);
ack = digitalRead(dataPin);
if (ack == LOW) break;
if (ack == HIGH) Serial.println("ACK error 2");
int SHT_getData(int dataPin, int clockPin){
// get data from the SHTx sensor
// get the MSB (most significant bits)
byte MSB = shiftIn(dataPin, clockPin, MSBFIRST);
// send the required ACK
// get the LSB (less significant bits)
byte LSB = shiftIn(dataPin, clockPin, MSBFIRST);
return ((MSB << 8) | LSB); //combine bits
void SHT_skipCrc(int dataPin, int clockPin){
// skip CRC data from the SHTx sensor
