Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Best Capacitors  (Read 725 times)
(USA)
Offline Offline
Full Member
View Profile
Thanks! I will buy those values.
Logged
USA, FL
Offline Offline
God Member
A life? Where can I download one of those?
View Profile
https://www.sparkfun.com/products/8571
https://www.sparkfun.com/products/8375
And 1uF is the only ceramic caps I use for general purpose.
For higher voltages and decoupling, use also Electrolytic.
https://www.sparkfun.com/products/523
https://www.sparkfun.com/products/96
4.7uF also.
Or something like this: http://www.ebay.com/itm/Caps-Electrolytic-and-Ceramic-Assortment-3-Qty-610-/310571903629?pt=LH_DefaultDomain_0&hash=item484f872a8d
Logged
//LiNK
Samplefinger
Offline Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
View Profile
Where would you buy from? Spark fun does not have any.
Bought from both of these guys.  Jameco I have bought their transistor, diode, and 74LS kits.  The cheapo chinese dudes, capacitor kits and resistor kits.
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_130232_-1  (Jameco has very fast shipping, typically same day, will get it to you quickly, very reptuable.)
http://www.ebay.com/itm/50value-1000pcs-Ceramic-Capacitors-Disc-50V-Assortment-Kit-/251204208418  (excellent value, low cost barrier, may take 2 weeks to get to you.)
http://www.ebay.com/itm/36value-3600pcs-Ceramic-Capacitors-Disc-50V-Assortment-Box-Kit-/251120210678 (very good value but more expensive for a larger kit, may take 2 weeks to get to you.)
A few other interesting capacitor kits:
http://www.ebay.com/itm/24value-400pcs-Polyester-poly-Film-Capacitors-Assortment-Box-Kit-100V-5-/261075701166
http://www.ebay.com/itm/36value-1000pcs-Electrolytic-Capacitor-Assortment-Box-Kit-/261098612334
http://www.ebay.com/itm/15value-450pcs-50V-Monolithic-Ceramic-Chip-Mono-Capacitor-Assortment-Box-Kit-/261074256547
« Last Edit: January 22, 2013, 12:54:27 pm by JoeN » Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Anchorage, AK
Offline Offline
Sr. Member
View Profile
I use 10, 22, 47, 100, 220, 470uF electrolytics all the time.  For bigger projects (mostly audio amps) I use 2200uF in parallel.  I keep in my stash a complete assortment:  0.1, 1, 4.7, 10, 22, 47, 100, 220, 470, 1000, and 2200uF.  I keep 25v and 50v varieties up to 1000uF, and 35v and 50v for 1000uF+.  Although, due to size and cost, I'll often order the larger ones per-project.  Remember, electrolytic caps age, so order in smallish batches and FIFO them.
The only ceramics I ever seem to use are 100nF for decoupling, 20-27pF for crystal load caps, and 470pF for the timing circuit on a particular switching regulator I use.  I haven't found a need to have an assortment, although that could just be my usual areas of design interest.
I did order a bunch of mains-rated ceramic caps for power switch arc prevention, but I have yet to use any.  I ordered way too many different sizes here.  One or two to pick from would've sufficed.  They just take up space in my kit now.
Logged
(USA)
Offline Offline
Full Member
View Profile
I was about to order, but I did not know what tolerance is good: 1% 5% 10% 20% ?  What would you recommend?
Logged
South England
Offline Offline
Full Member
View Profile
I would think 5-10% tolerance would be ok for general use, tinkering and experimenting. Don't pay over the odds for precision you don't need.
Logged
(USA)
Offline Offline
Full Member
View Profile
Thanks!  I will go for 5%.
Logged
Samplefinger
Offline Offline
God Member
View Profile
Capacitor tolerances are usually way less precise than resistor tolerances and that's OK because generally we are using them to get some decoupling done or to keep a crystal oscillating.  I am not sure you can get 1% except in polystyrene and other exotic construction caps which are limited to pretty small values and expensive.  10% is good unless the circuit calls for a precision part which I have just not seen in digital electronics so far.  Probably there are more applications for it on the analog side.
Logged
Anchorage, AK
Offline Offline
Sr. Member
View Profile
My electrolytics are all Nichicon VR -- 20% tolerance.  In most cases, these are bulk supply caps, so anything within a country mile of spec is just fine.  In the cases where they are timing caps, they are timing circuits where the margin for error is likewise large.  Otherwise, I would use a dedicated timer of some sort.  Typically, it's more like an AC loss detector or 555-based flasher.
The ceramics I buy are 5% I think.  For decoupling, it doesn't matter at all.  For crystals, I like to keep them within 10% tops -- less if possible.  In my audio circuits, I use Wima film caps at 5% tolerance, because the 1% parts are more expensive, and in some cases (filters) I would have to use really low values for the precision parts to be available at all.  This leads to higher parasitic capacitance influence, and thus a loss of that perfect 0.1% tolerance I paid so much for.
I buy 1% resistors (except the 1W+ ones) because they're cheap, and then my inventory serves me well for both moderate precision and general-purpose use.
Logged
Offline Offline
Jr. Member
View Profile
best website for cheap shit is www.taydaelectronics.com
standard NPN transistors for 13c, 555 timers for 10c, this place is a goldmine.
I had to buy 600 LEDs for my LED cube. I live in ireland, and to buy them from radionics here it would have cost me 140 euros. From tayda, it only cost 36! and that included shipping from HK!
great website/shop.
Logged
Samplefinger
Offline Offline
God Member
View Profile
Ha. Ha.  What a bunch of tools.
Logged
Samplefinger
Offline Offline
God Member
View Profile
great website/shop.
I love them but they do not do pre-made kits and you can find better buys on the same items sometimes by looking over reputable eBay sellers with 1000+ sales.  I've put together a couple of "kits" of inductors (my two LRC meters says their inductors are pretty loose on their numbers too) and caps with them and it's a bit of a pain.  With that said, they are great, ship out of Colorado, and get it to me in under 7 days usually.  I think they aggregate out there in Colorado so a lot of this is in the USA when they ship.
Logged
Left Coast, CA (USA)
Online Online
Brattain Member
Measurement changes behavior
View Profile
I actually consider many audiophiles (aka golden ears) 'victims' that are feed upon by rather unscrupulous electronic suppliers that know better but can't help relaxing their morals for the temptation of high margins/easy profits that selling to such a population can be had. Many such audiophiles have a high emotional attachment to their love of music and the audio equipment they use to playback their music on.
 As I said they give electronic components and circuits the same emotional attributes one might give to wine or art appreciation. When told about measurements (or even well run double blind hearing tests) not supporting such opinions on such 'magic component' they will just say that you are not measuring the right thing or that measurements can never substitute for one's refined hearing properties.
 But in most cases such people can certainly afford their rather uneducated technical opinions with a higher then normal 'disposable income', so it's not surprising that there are people that will encourage such beliefs just for the easy profits. So as I said they are in many cases as much victims just succuming to other audiophile peer pressure and the technical gobbly gook that certain predatory electronic dealers are happy to feast upon.
Lefty
Logged
Offline Offline
Sr. Member
View Profile
I'm going to be buying some capacitors and was wondering which ones were best. Ceramic or Electrolytic?
Thanks!!!
Depends on what you want to do with them.
Electrolytic caps are usually higher values (in the microfarad to thousands of microfarad range) and are used for low frequency filtering and power supplies. They, however, have a relatively high ESR and are useless at high frequencies, making them worthless for bypass capacitors.
Mylar and ceramic caps are much better as bypass caps, have a much lower ESR and lower leakage, but are only available in the picofarad to fractions of a microfarad range.
Which capacitor you use depends on what you need to do... there is no one "universal" type.
Logged
Offline Offline
Sr. Member
View Profile
Radio Shack. The prices aren't that great, but if you only need a few and you're in a hurry, that's the place to get them.
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
