(USA)
« on: January 21, 2013, 02:28:25 pm » |
I'm going to be buying some capacitors and was wondering which ones were best. Ceramic or Electrolytic?
Thanks!!!
South England
« Reply #1 on: January 21, 2013, 02:30:40 pm » |
Your capacitor selection depends entirely on it's role in the circuit. Different ones are best for different applications, that's why there's so many! I'm sure one of the senior members here would elaborate further on which types are most used for what. What circuit are you using them in?
(USA)
« Reply #2 on: January 21, 2013, 02:31:41 pm » |
I'm using them to filter out noise for an analog input.
South England
« Reply #3 on: January 21, 2013, 02:33:27 pm » |
Given the options I'd go with ceramic there
(USA)
« Reply #4 on: January 21, 2013, 02:34:58 pm » |
Thanks!
(USA)
« Reply #5 on: January 21, 2013, 02:36:34 pm » |
Where would you buy from? Spark fun does not have any.
South England
« Reply #6 on: January 21, 2013, 02:52:21 pm » |
Any of the big-name retailers really... Farnell, RS, DigiKey etc. Or, if I just wanted a cheapo bumper pack of different values I might order from one of eBay's HK-based sellers. You may be able to pick up something like this https://www.sparkfun.com/products/10003 but bigger, for a lot less money, if you don't mind waiting a few weeks for it to arrive.
« Last Edit: January 21, 2013, 02:56:16 pm by BulletMagnet83 »
(USA)
« Reply #7 on: January 21, 2013, 03:04:55 pm » |
Thanks. I think I will look for a kit.
(USA)
« Reply #8 on: January 21, 2013, 04:15:33 pm » |
What size capacitors should I look for?
Thanks, Drew
Anchorage, AK
« Reply #9 on: January 21, 2013, 04:34:07 pm » |
100nF is a good value. It depends on the frequency of the input signal though, since by design it forms a lowpass filter.
South England
« Reply #10 on: January 21, 2013, 04:34:38 pm » |
Just get a ton of different values, then you'll be sorted out for all kinds of experimenting!
(USA)
« Reply #11 on: January 21, 2013, 04:46:07 pm » |
I was looking at digikey, but they had everything from .011uf to 680uf. I would be broke if I ordered some of each! What is the range I would be using for general Arduino use?
Thanks!
Left Coast, CA (USA)
Measurement changes behavior
« Reply #12 on: January 21, 2013, 05:55:29 pm » |
« Reply #13 on: January 21, 2013, 06:05:45 pm » |
I call them audio-phools.
« Reply #14 on: January 21, 2013, 06:09:18 pm » |
I use a lot of 0.1u, 12/15/18/22pf. And once in a blue moon, I use 1n or 11n.
