SE USA
@ssh0le
« Reply #1 on: January 21, 2013, 07:40:24 pm » |
its sort of standard, but I dont know what its called
« Reply #2 on: January 21, 2013, 07:46:45 pm » |
LED's come in all kinds of shapes and sizes, all you need to worry about is the Current and Voltage of the LED.
Southern California
I like blinky lights
« Reply #3 on: January 21, 2013, 07:50:21 pm » |
Well...voltage and current are important, but if you're making a circuit board I find a physical design footprint comes in handy as well.
SE USA
@ssh0le
« Reply #4 on: January 21, 2013, 07:56:57 pm » |
yea that might be handy + many of those have heat slugs under them which also need to be connected
If you don't get an answer by sometime tomorrow, we use a UV led at work that has that layout, least get you a datasheet with pad info in it and you can make your own
Atlanta
« Reply #5 on: January 21, 2013, 09:13:03 pm » |
looks like a lumiled / K2 package
Southern California
« Reply #6 on: January 21, 2013, 11:23:27 pm » |
It looks like the Eagle Library 'LED' has the part F50380 which is similar. If found the part documented in a PDF at http://www.farnell.com/datasheets/2434.pdf which has the specs for the footprint. It should be enough to get me started. Thanks to all for your help.
