Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #45 on: January 24, 2013, 08:31:07 pm » |
Vcc needs to connect ACVV, and connect both to +5V. Put a 0.1uF cap on both pins. Put a 0.1uF cap frpm Aref to Gnd.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #46 on: February 15, 2013, 06:27:00 pm » |
Is this what you mean ?
Logged
Global Moderator
Offline
Brattain Member
« Reply #47 on: February 15, 2013, 06:46:17 pm » |
Almost - don't connect Aref to +5, just a cap to Gnd. It has internal connection to +5, or +3.3, under software control. Connect pin 7 to 20. This where a view of the schematic comes in handy.
If you can do a ground pour, or ground fill, or whatever the program you are using calls it, then you can delete the all over the place ground traces and just connect those pins to the ground plane instead. That will make for quieter signals too.
You have room on the board - I would add a diode in parallel with the reset resistor - anode to the reset pin, cathode to +5. This will keep any spikes that occur from making the chip think its going into High Voltage programming mode (and look liket its just hung up to you). 1N4158 type of diode is sufficient.
Looks like you have 2 regulators? Would recommend caps on the 2nd regulator also. 1uF on input, 0.1uF on the output.
Do you have any plans to add pin names (D0, D1, etc) or part names (C1, C2, etc)? That really helps to make the boards look sharp.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #48 on: February 16, 2013, 08:17:19 pm » |
I've added capacitors to 2nd regulator and added label names for them. you mind checking?
Logged
Global Moderator
Offline
Brattain Member
« Reply #49 on: February 16, 2013, 08:25:03 pm » |
Looks pretty good. Trace for pin 20 is kinda thin compared to the rest. Maybe indicates it has not been routed yet? Schematic turned out pretty good. Still recommend a diode across R4 for reasons described before. At least put pads in for it if you don't want to install it to start.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #50 on: February 16, 2013, 08:34:16 pm » |
I was kinda afraid of modifying the schematics because first i suck at understanding them... but i think i can understand them by now. About the thin wire, yes i didnt double click so it was a rastnest line instead of being a wire (corrected now) diode just like that?
Logged
Global Moderator
Offline
Brattain Member
« Reply #51 on: February 17, 2013, 11:47:48 am » |
Looks good.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #52 on: February 17, 2013, 11:56:52 am » |
No obvious mistakes ? Like wrong connections or such ? i'm ready to try my first pcb etch You mind also take a look at http://arduino.cc/forum/index.php/topic,149447.0.htmlit's related to this pcb i'm making
« Last Edit: February 17, 2013, 12:03:59 pm by Carlcox89 »
Logged
Global Moderator
Offline
Brattain Member
« Reply #53 on: February 17, 2013, 12:40:57 pm » |
None that I see. I still recommend a ground pour - that will save on etching material also as you only etch enough to isolate the pads & traces, and not clear out whole big sections of the board.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #54 on: February 17, 2013, 01:19:30 pm » |
Is this what you are saying ? i've choose GND as a ground seed and then did Ground Fill i cant understand how it works and how i'm gonna etch my pcb like this
Logged
Leighton Buzzard, UK
Offline
Edison Member
« Reply #55 on: February 17, 2013, 01:26:03 pm » |
that doesn't look good the ground fill bit has worked but it seems to have nuked all you lovely traces
Logged
there are only 10 types of people them that understands binary and them that doesn't
0
Offline
Jr. Member
Arduino rocks
« Reply #56 on: February 17, 2013, 01:29:18 pm » |
i really dont know how to do this with fritzing, i think i leave it just like it was before... and maybe in the future use another program like eagle
Logged
Offline
Edison Member
« Reply #57 on: February 17, 2013, 01:47:12 pm » |
I would go for Eagle every time takes a few extra minutes to get up to speed, but it's like moving from crayons to calligraphy (IMHO)
apart from anything else - there are so many people here who can help you with it this problem would have been a doddle!
Logged
Global Moderator
Offline
Brattain Member
« Reply #58 on: February 17, 2013, 01:53:47 pm » |
That's the idea, but it seems to have the ground on one side of the board and the traces on the other, hence the 2 different colors (yellow-ish gnd, and reddish traces); from the jumpers you showed earlier I figured you were making a single sided board. Try it again with the ground pour on the same side as the traces. What you want is to just have the copper removed from next to the traces and around the pins, you can see where that took place arond the pads already.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #59 on: February 17, 2013, 02:11:52 pm » |
Yes the board is single-sided... i really cant do that ground pour with fritzing. i'm trying moving the wires to the other side of board and doing copper fill to see if this is what you mean.
Logged
