Loading...
Pages: 1 ... 3 4 [5] 6   Go Down
Author Topic: first pcb try  (Read 3722 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
One last time before i give up smiley-grin
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Ok, copper fill then. Have that and the traces on the same side of the board.
Then you end up like this, where the white is the copper that is removed and the red is the copper that is left.
This is for a surface mount board. You probably want everything on the bottom layer for easier soldering of pins to pads.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I did ground fill instead. see image above
it's that?
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
No, that has a top & bottom layer. You want the ground fill on the same layer as your traces.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
i really cant understand this :x
i've tried to export etch_copper_bottom so you can see the bottom only, but i dont think  that's what you mean
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
That's exactly what I mean! That looks pretty good.
Last thing I would recommend is making the 90 degree corners on traces into a couple of 45 degree corners.
This is important in home etching because often the inside corner can be over-etched  leaving the resulting corner trace on the thin side.
Logged
Offline Offline
Full Member
View Profile
Some nice attempts. Tinning makes a massive difference to the solderbility.
A little while ago, I came across an article, but can't find it right now. It used a CD printer to print the etch resist and the silk screen layers directly onto the board, pretty nifty. I think they used a simple two-edged jig to ensure registration. They were using a non-FeCl etch too (which is a pain to recycle and stains everything around).
Use good quality PCB drill bits and a drill post (dremel et al make them). If you allow the drill to self-centre, drilling is quite easy and can look good. Self centring requires the pad hole to be quite small). The technique is to visually align the drill/work, then as the drill nears the work, allow the work to move, and the hole in the pad will align with the drill, hold firmly and press through. Obviously works with smaller boards. Use of backing board leaves a good finish.
Logged
For whom does the clock pulse? It pulses for you!
Offline Offline
Newbie
View Profile
I have read this post with great interest. I'm new to the PCB layout and design. For those of you who are drilling your own boards. Where do I find a .08 bit in the USA. What size of bit or bits do I need? Where can I get them? I believe .08 is the correct bit size for most leads.
Thanks
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
@  CrossRoads  thanks for the tip, i'm gonna do that smiley
One question, when printing with laser printer, should i print the normal bottom or the mirror one ? I'm confused  smiley-confuse
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Try it both ways on paper, see which comes out the way you want.
The file you posted above is the traces as if looking "thru" the board. You want the one that is looking from the bottom of the board.
Logged
London
Offline Offline
Sr. Member
View Profile
For itead:
http://imall.iteadstudio.com/open-pcb/pcb-prototyping/im120418003.html
Order PCBs, you'll get a Order #  back.
Send the Order # and your zip file to pcb@iteadstudio.com
Do board manufacturers through-hole-plate vias or do I have to solder a wire through them myself?
Logged
St. Leonards-on-Sea, E. Sussex, UK.
Offline Offline
Sr. Member
Ancient developer
View Profile
All board suppliers provide PTH.
Logged
Leon Heller
G1HSM
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Yes, itead takes care of the thru hole plating.
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Thanks
0.08?  Sounds very wrong in mm or in - perhaps you mean 0.8mm?
0.035" or 0.9mm is about right for a range of leads, thin leads and vias can be thinner than this.  eBay has quite a lot
of carbide PCB drills available, but some are ex-industry used drills from the look of things.  For fibre glass carbide bits
are the best.
Logged
BHZ, MG, Brazil
Offline Offline
Sr. Member
Android developer; Arduino enthusiast
View Profile
I have made several PCBs at home and I've been making them for a long time. Everytime I make one, it is better than the one before, because I find ways to optimize the processes involved: what is the best paper for toner transfer, the adequate temperature and time for the transfer, and so on. I like doing them and I enjoy doing them.
All my boards are single-sided, and I take care in revising the routing made by DipTrace (more on that later). I don't trust its auto-router blindly. A good PCB starts in the PCB layout: I know of the limitations of my process and I take care in specifying trace widths and clearance I can handle (18mil). I avoid jumpers. I revise DipTraces autoroutes and end up changing or correcting at least 50% of them.
For drilling the boards I use a Dremel tool exactly like this: http://toolmonger.com/wp-content/uploads/2007/04/post-dremelworkstation.jpg I have drill bits in 0.6, 0.8, 1.0 and 1.2mm.
I know my homemade PCBs could look a lot better if I were using photographic transfer methods, a better etching process and so on, but I like to keep it simple and cheap, so I use toner transfer with glossy magazine paper, transfered with a cloth iron and etched with (warm and filtered) ferric chloride. This is very cheap and very fast. For me, designing the board as well as I can is what gives me high sucess rates.
Here are a couple examples of PCBs I've made. Both are links to Facebook albums, but no facebook account is required:
1) Simduino (Simplified Arduino clone): https://www.facebook.com/media/set/?set=a.3248657275029.110252.1824874327&type=1&l=f89646a4f1
2) Arduino shield (with EEPROM + RTC + dig. temp. sensor): https://www.facebook.com/media/set/?set=a.3191611048909.108905.1824874327&type=1&l=a0e77a5b55
About DipTrace: I like it very much. I does everything I need (my needs are pretty basic and simple). Now that I've learned how to create custom components and patterns on it, there is very little I can't do with it.
Only TODAY I sent my first order to iTeadStudio, because the PCBs had to be double-sided and I needed10 of them.
In short, I find designing and making PCBs a great fun and I really enjoy making them.
Logged
Learn to live: Live to learn.
Showing off my work: http://arduino.cc/forum/index.php/topic,126197.0.html
Pages: 1 ... 3 4 [5] 6   Go Up
Print
Jump to:
