Topic: Project iCamper (Read 25195 times) previous topic - next topic
TrailerTrash
#30
Jun 29, 2013, 04:40 pm Last Edit: Jun 29, 2013, 04:50 pm by TrailerTrash Reason: 1
getting crowded on that breadboard so time to find a box. i had an extra one of these from my solar panel kit and gutted it.
TrailerTrash
i stuffed everything into the box and it works but eats allot of juice.
rockwallaby
TrailerTrash wrote:
Quote
Good that you have made progress, though in my initial response I hinted at this, in part;
Quote
One thing that I have concerns for is that all this electronics will consume some amount of electrical power which may or may not be significant for your setup. Have you done the calculations in regard to what your capacity is in terms of what you get in with 255 Watts of solar panel and what you will use for all your existing electrical loads, such as lights, radio or laptop?
Under unfavourable conditions when you have low solar gain, will you have enough battery capacity to operate all these modules?
_____
Paul
Paul - VK7KPA
TrailerTrash
TrailerTrash wrote:
Quote
Quote
_____
Paul
i am going to add battery backup power for the winter. 3 rechargeable 9volt batteries. i was going to use a switch on the panel to switch them on but then i remembered "automation". i will write a code to switch to battery mode by itself.
i also replaced the red/blue leds with red ones and code them to blink every 10seconds to save power.
craigcurtin
TrailerTrash wrote:
Quote
Quote
I dunno if that will give you much power - 3 x 9v - most of the time these are around the 500ma rating.
If you wanted to go down that path i would be doing some AA (best price performance) or some of the more exotic Lithium chemistry batteries - have you worked out the current draw yet ?
Craig
_____
Paul
mirkougolini
#35
Aug 23, 2013, 04:01 pm Last Edit: Aug 23, 2013, 04:03 pm by mirkougolini Reason: 1
Hello all,
I developed a device that allow to control the Truma Combi by IR Remote Control and SMS
that's my web site:
e-domotics.blogspot.it/2013/07/dispositivo-mrc.html
Here are the main features of the MRC device:
1)complete control of Truma Combi by IR remote Control
2)complete control of Truma Combi by SMS
3)notification of the fault status of the Combi by SMS
4)remote inquiry of the state of the TRUMA
5)notification of the opening of the valve ELASI by SMS
6)SMS notification of 220V drop power supply
7)control a Relay by SMS
8)remote inquiry of the state of the relay by SMS
9)SMS notification of alarm camper theft or intrusion
10)24H thermostat or a single activation
11)availability of Android App for control the device
Regards
wrybread
Well it's years later. I'm working on a similar project and wondering how far you got?
