Loading...
Pages: [1] 2 3   Go Down
Author Topic: ATTiny85 tone() core?  (Read 1257 times)
Offline Offline
Newbie
View Profile
This
http://code.google.com/p/arduino-tiny/downloads/detail?name=arduino-tiny-0022-0008.zip&can=2&q=
doesn't seem to work. Nor does this: http://code.google.com/p/arduino-tiny/
Are they just outdated, and if so can I just revert back to an older version of arduino IDE?
Logged
Grand Blanc, MI, USA
Offline Offline
Edison Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
I'm using the latter with v1.0.3, what is the specific problem? ... "doesn't seem to work" is a bit broad.
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Offline Offline
Newbie
View Profile
The entire ATTiny works fine. I can blink an LED. But when I use tone() with a speaker, nothing happens. I'll try it with 1.0.3 now and see if that makes a difference. (I've been using 1.0.1 up until now)
Logged
Offline Offline
Newbie
View Profile
So I re-installed arduino as 1.0.3. Also re-installed the core you used. Built the circuit correctly. Made sure that a normal LED sketch works. (It does.) The tone() still won't work.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Wanna bet?
Logged
Offline Offline
Edison Member
View Profile
WWW
Post your code, I'll have a look and/or give it a try.
Logged
Offline Offline
Newbie
View Profile
I doubt it's actually the code, seeing as how it's just a simple test:
Code:
  tone(3, 2000, 500);
  tone(3, 3500, 500);
I'm thinking something is different about the core, but I followed the readme.txt exactly... :/
Logged
Offline Offline
Edison Member
View Profile
WWW
Works fine here.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Pin 3 is on the left side of the processor one down from the top.  What's connected to it?
Logged
Offline Offline
Newbie
View Profile
The speaker (which I know works) connected to ground.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Quote
...with a speaker...
An 8 ohm speaker?
Logged
Offline Offline
Newbie
View Profile
No, it's a buzzer. I think it's called a piezzo buzzer. And I know it works with the tone() function on the arduino.
Logged
Offline Offline
Edison Member
View Profile
WWW
Hmm. And an LED will blink on the same pin?
Logged
Offline Offline
Newbie
View Profile
Yes.
Logged
Offline Offline
Edison Member
View Profile
WWW
Load the blink sketch, blink an LED on pin 3, say 100ms on and 100ms off. Once that is working, add the piezo to the circuit, from pin 3 to ground (through a small resistor, 100 ohms or so is best if you have one.)
What do you hear from the piezo?
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
