the land of sun+snow
Offline
Edison Member
« Reply #30 on: January 23, 2013, 02:25:32 am » |
Yeah, still doesn't explain, that I can see, the funny business about #elif defined(__AVR_ATmega1284P__) || defined(__AVR_ATmega644P__) if (pin >= 24) pin -= 24; // allow for channel or pin numbers I don't know about Sanguino or 644, as they're not included with the maniacbug mighty-1284P-master files. The files and bootloaders I have are all dated 23 June 2012. Besides the digital and analog pins, I also checked the PWM pins today with analogWrite(), and they all look ok, so I think only the analogPinToChannel(p) declaration was wrong. I just bought some 1284P chips from digikey today, and should arrive on thursday. Yours are no doubt cheaper, but I want to get this darn thing wrapped up already. Sheesh. Thursday, I can check the RX0 sensitivity/download problem using the 1284P chips. On a brighter note, today, my local Coopers hawks returned to their nest in the nearby tree from their winter sojourn. One can only imagine where they've been all winter since they left in the fall after their kids had grown. Probably in San Diego, sitting on the beach.
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #31 on: January 23, 2013, 03:16:05 am » |
On a brighter note, today, my local Coopers hawks returned to their nest in the nearby tree from their winter sojourn. One can only imagine where they've been all winter since they left in the fall after their kids had grown. Probably in San Diego, sitting on the beach. Well for us that means the hawk population will probably start to dwindle to 1/4 of what we see in the winter as they leave for the north. We have local hawks (mostly red-tails) that are year around. If your ever interested in populating any of your boards with a 644P chip, here is the boards.txt entry I setup. ##############################################################
bobuino644.name=Bobuino 644P optiboot bobuino644.upload.protocol=arduino bobuino644.upload.maximum_size=63488 bobuino644.upload.speed=115200 bobuino644.bootloader.low_fuses=0xff bobuino644.bootloader.high_fuses=0xdc bobuino644.bootloader.extended_fuses=0xfd bobuino644.bootloader.path=optiboot bobuino644.bootloader.file=optiboot_atmega644p-4-5.hex bobuino644.bootloader.unlock_bits=0x3F bobuino644.bootloader.lock_bits=0x0F bobuino644.build.mcu=atmega644p bobuino644.build.f_cpu=16000000L #bobuino644.build.core=arduino:arduino bobuino644.build.core=standard bobuino644.build.variant=bobuino
Logged
Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #32 on: January 23, 2013, 10:22:08 am » |
Still waiting for my 1284P chip to show up, I hope it has at least crossed the international date line by now. Is Mouser shipping these from overseas now? With >1700 in stock you'd think they'd arrive pretty quick. http://www.mouser.com/ProductDetail/Atmel/ATMEGA1284P-PU/?qs=sGAEpiMZZMtVoztFdqDXO3QpeG9FlGm9
Logged
Offline
Brattain Member
« Reply #33 on: January 23, 2013, 10:46:20 am » |
Call me a cheapskate but when I click on buy I get this total: MERCHANDISE TOTAL: $8.71 SHIPPING CHARGE: $20.00 ORDER TOTAL: $28.71
That sounds nuts to me? So I ordered from Futurlec for like $10 including shipping. I was aware that they take a long time shipping as I've ordered a couple of things from them before in the past, and being retired I'm almost never in a hurry. And because of being able to use a DIP 644P in your same Demu through hole 1284P board you sold me, it's not been non-constructive time spent waiting. Besides you now have the option of calling your board a 644P/1284P board.  Lefty
« Last Edit: January 23, 2013, 10:47:52 am by retrolefty »
Logged
Offline
Edison Member
« Reply #34 on: January 23, 2013, 12:31:48 pm » |
I always use USPS Priority Mail shipping from digikey and mouser and jameco, and with the order I placed yesterday with digikey, the shipping is $4.91. Priority usually takes 2 days to the west coast. Mouser is a little cheaper than digikey for small quantities, but only digikey had some other parts I needed for this order.
I also ordered a few atmega32A chips to play with. From what I can tell, these have the same pinout as 644/1284, but are essentially a 328 in DIP40, so you get a -UNO with 40-pins. Also 2/3 cheaper than the 644/1284. I don't know if there is a bootloader for the 32A, however.
I should have ordered some 644s too, just to play, but forgot.
« Last Edit: January 23, 2013, 12:36:11 pm by oric_dan »
Logged
Offline
Brattain Member
« Reply #35 on: January 23, 2013, 12:37:35 pm » |
So what was the SHIPPING CHARGE: $20.00 That Mouser showed me when I clicked on buy it? Is the default hand delivery by limousine? Or some kind of minimum order size hidden as a shipping charge? Lefty
Logged
Offline
Edison Member
« Reply #36 on: January 23, 2013, 12:40:22 pm » |
Those guys have a dozen or more shipping options, with Fedex overnight at the top of the cost structure, and Fedex or UPS ground near the bottom [and which may take a week]. A guy like you [!!!] should avoid clicking on the upper lines.
Logged
Global Moderator
Offline
Brattain Member
« Reply #37 on: January 23, 2013, 12:49:52 pm » |
$4.99 residential shipping is what I normally see with Mouser. $6.99 for bulkier stuff.
Logged
Offline
Brattain Member
« Reply #38 on: January 23, 2013, 12:54:35 pm » |
But I didn't, I just clicked buy it and that is what popped up. I didn't even go to further screens to see if I had a choice of shipping options. So they in effect 'scared me away' by their choice to default to a or the most costly shipping method. If that had not stated any shipping cost then I might have adventured further into the buying process/screens, to see that options they made available. Just poor web design in my opinion. Lefty
Logged
Offline
Edison Member
« Reply #39 on: January 23, 2013, 01:02:15 pm » |
Looks pretty darn easy to me. I looked at my Mouser cart from yesterday [order not completed], but once I click on "Checkout" from the cart, it takes me to a succession of screens [notice the top line], then 3rd screen is here, CHECKOUT» Addresses» Shipping Method» Payment» Review Shipping Method Please select one of the following:
Shipping cost determined at the time of shipment. UPS Ground UPS 3rd Day UPS 2nd Day UPS Next Day Saver UPS Next Day UPS Next Day Early AM FedEx Ground FedEx 3rd Day FedEx 2nd Day FedEx Standard Overnight FedEx Priority Overnight FedEx Priority Overnight Early AM US Postal Service Priority Mail w/Delivery Confirmation Live wild.
Logged
Offline
Brattain Member
« Reply #40 on: January 23, 2013, 01:11:06 pm » |
Shipping cost determined at the time of shipment. UPS Ground UPS 3rd Day UPS 2nd Day UPS Next Day Saver UPS Next Day UPS Next Day Early AM FedEx Ground FedEx 3rd Day FedEx 2nd Day FedEx Standard Overnight FedEx Priority Overnight FedEx Priority Overnight Early AM US Postal Service Priority Mail w/Delivery Confirmation Live wild. You seem to miss my point. They don't leave the shipping cost as a blank when I first hit buy it for a $8 DIP chip, put rather it displayed a $20 shipping cost that didn't even mention the shipping method or that other shipping methods are avalible further into the checkout process. That's pretty dumb of them and just a poor marketing design, and that was my point. Most mail order companies offer shipping choices as Mouser does, I just choose to not go further into the buying process. Lefty
« Last Edit: January 23, 2013, 01:13:46 pm by retrolefty »
Logged
Offline
Edison Member
« Reply #41 on: January 23, 2013, 01:28:08 pm » |
I think you must have clicked on the famous Twilight Zone button.
Logged
Offline
Brattain Member
« Reply #42 on: January 23, 2013, 02:15:55 pm » |
Just the link Bob posted, give it a try. Lefty
Logged
Global Moderator
Offline
Brattain Member
« Reply #43 on: January 23, 2013, 03:28:39 pm » |
I don't see that shipping is shown until after the address entry page, and then the list of shipping options appears to pick from.
Logged
Offline
Edison Member
« Reply #44 on: January 23, 2013, 03:34:53 pm » |
I don't see that shipping is shown until after the address entry page, and then the list of shipping options appears to pick from. That's what I found too, lefty's in the Twilight Zone.
Logged
