the land of sun+snow
« Reply #15 on: January 22, 2013, 05:17:07 pm » |
Would you check whether the problem talked about on this thread is real, or if I only dreamed it?
Eg, put a voltage on one of the A/D channels of the Bobuino 1284 bootloader chip and then try to read it using analogRead().
Left Coast, CA (USA)
Measurement changes behavior
« Reply #16 on: January 22, 2013, 06:18:35 pm » |
Yes, it seems to be messed up with or without the proposed changes to pins_arduino.h file you suggested. I'll post what my pins read Vs what pins they should read a little later, have to go pick up wife at her art lessons. Lefty
« Reply #17 on: January 22, 2013, 07:35:26 pm » |
OK, I'm using a 644P chip with the bobuino variant pins_arduino.h file being used. So using the example sketch Basics/AnalogReadSerial, I tried each analog channel number using both their Ax value and their digital pin alias (14-21) I got the following results: sketch software pin name used valid voltage reading shows up on shield pinA0 (or14) A1 (15) A1 (or15) A0 (14) A2 (or16) A7 (21) A3 (or17) A6 (20) A4 (or18) A5 (19) A5 (or19) A4 (18) A6 (or20) A3 (17) A7 (or21) A2 (16) I tested the digital pin numbers using digitalRead command and sending them out the serial port and manipulated the pins with a ground after having enabled their internal pull-ups, and see no problem, pin mapping is correct for Bobuino D0 through D31 for digitalRead commands. So the problem seems to be in the mapping of the analog channels numbers 0-7 to the correct digital pin numbers. Or maybe the mapping is correct but the analog mux selection bits are backwards or something? Lefty Variant pins_arduino.h file being used #ifndef Pins_Arduino_h #define Pins_Arduino_h
#include <avr/pgmspace.h>
// ATMEL ATMEGA1284P on Bobuino // // +---\/---+ // (D 4) PB0 1 | | 40 PA0 (D 21) AI 7 // (D 5) PB1 2 | | 39 PA1 (D 20) AI 6 // INT2 (D 6) PB2 3 | | 38 PA2 (D 19) AI 5 // PWM (D 7) PB3 4 | | 37 PA3 (D 18) AI 4 // PWM/SS (D 10) PB4 5 | | 36 PA4 (D 17) AI 3 // MOSI (D 11) PB5 6 | | 35 PA5 (D 16) AI 2 // PWM/MISO (D 12) PB6 7 | | 34 PA6 (D 15) AI 1 // PWM/SCK (D 13) PB7 8 | | 33 PA7 (D 14) AI 0 // RST 9 | | 32 AREF // VCC 10 | | 31 GND // GND 11 | | 30 AVCC // XTAL2 12 | | 29 PC7 (D 29) // XTAL1 13 | | 28 PC6 (D 28) // RX0 (D 0) PD0 14 | | 27 PC5 (D 27) TDI // TX0 (D 1) PD1 15 | | 26 PC4 (D 26) TDO // INT0 RX1 (D 2) PD2 16 | | 25 PC3 (D 25) TMS // INT1 TX1 (D 3) PD3 17 | | 24 PC2 (D 24) TCK // PWM (D 30) PD4 18 | | 23 PC1 (D 23) SDA // PWM (D 8) PD5 19 | | 22 PC0 (D 22) SCL // PWM (D 9) PD6 20 | | 21 PD7 (D 31) PWM // +--------+ //
#define NUM_DIGITAL_PINS 32 #define NUM_ANALOG_INPUTS 8 #define analogInputToDigitalPin(p) ((p < NUM_ANALOG_INPUTS) ? 21 - (p) : -1) extern const uint8_t digital_pin_to_pcint[NUM_DIGITAL_PINS]; extern const uint16_t __pcmsk[]; extern const uint8_t digital_pin_to_timer_PGM[NUM_DIGITAL_PINS];
#define ifpin(p,what,ifnot) (((p) >= 0 && (p) < NUM_DIGITAL_PINS) ? (what) : (ifnot)) #define digitalPinHasPWM(p) ifpin(p,pgm_read_byte(digital_pin_to_timer_PGM + (p)) != NOT_ON_TIMER,1==0)
#define digitalPinToAnalogPin(p) ( (p) >= 14 && (p) <= 21 ? (p) - 14 : -1 ) #define analogPinToChannel(p) ( (p) < NUM_ANALOG_INPUTS ? NUM_ANALOG_INPUTS - (p) : -1 )
static const uint8_t SS = 10; static const uint8_t MOSI = 11; static const uint8_t MISO = 12; static const uint8_t SCK = 13;
static const uint8_t SDA = 23; static const uint8_t SCL = 22; static const uint8_t LED = 13;
static const uint8_t A0 = 14; static const uint8_t A1 = 15; static const uint8_t A2 = 16; static const uint8_t A3 = 17; static const uint8_t A4 = 18; static const uint8_t A5 = 19; static const uint8_t A6 = 20; static const uint8_t A7 = 21;
#define digitalPinToPCICR(p) ifpin(p,&PCICR,(uint8_t *)0) #define digitalPinToPCICRbit(p) ifpin(p,digital_pin_to_pcint[p] >> 3,(uint8_t *)0) #define digitalPinToPCMSK(p) ifpin(p,__pcmsk[digital_pin_to_pcint[]],(uint8_t *)0) #define digitalPinToPCMSKbit(p) ifpin(p,digital_pin_to_pcint[p] & 0x7,(uint8_t *)0)
#ifdef ARDUINO_MAIN
#define PA 1 #define PB 2 #define PC 3 #define PD 4
const uint8_t digital_pin_to_pcint[NUM_DIGITAL_PINS] = { 24, // D0 PD0 25, // D1 PD1 26, // D2 PD2 27, // D3 PD3 8, // D4 PB0 9, // D5 PB1 10, // D6 PB2 11, // D7 PB3 29, // D8 PD5 30, // D9 PD6 12, // D10 PB4 13, // D11 PB5 14, // D12 PB6 15, // D13 PB7 7, // D14 PA7 6, // D15 PA6 5, // D16 PA5 4, // D17 PA4 3, // D18 PA3 2, // D19 PA2 1, // D20 PA1 0, // D21 PA0 16, // D22 PC0 17, // D23 PC1 18, // D24 PC2 19, // D25 PC3 20, // D26 PC4 21, // D27 PC5 22, // D28 PC6 23, // D29 PC7 28, // D30 PD4 31, // D31 PD7 };
const uint16_t __pcmsk[] = { (uint16_t)&PCMSK0, (uint16_t)&PCMSK1, (uint16_t)&PCMSK2, (uint16_t)&PCMSK3 };
// these arrays map port names (e.g. port B) to the // appropriate addresses for various functions (e.g. reading // and writing) const uint16_t PROGMEM port_to_mode_PGM[] = { NOT_A_PORT, (uint16_t) &DDRA, (uint16_t) &DDRB, (uint16_t) &DDRC, (uint16_t) &DDRD, };
const uint16_t PROGMEM port_to_output_PGM[] = { NOT_A_PORT, (uint16_t) &PORTA, (uint16_t) &PORTB, (uint16_t) &PORTC, (uint16_t) &PORTD, };
const uint16_t PROGMEM port_to_input_PGM[] = { NOT_A_PORT, (uint16_t) &PINA, (uint16_t) &PINB, (uint16_t) &PINC, (uint16_t) &PIND, };
const uint8_t PROGMEM digital_pin_to_port_PGM[NUM_DIGITAL_PINS] = { PD, // D0 PD, // D1 PD, // D2 PD, // D3 PB, // D4 PB, // D5 PB, // D6 PB, // D7 PD, // D8 PD, // D9 PB, // D10 PB, // D11 PB, // D12 PB, // D13 PA, // D14 PA, // D15 PA, // D16 PA, // D17 PA, // D18 PA, // D19 PA, // D20 PA, // D21 PC, // D22 PC, // D23 PC, // D24 PC, // D25 PC, // D26 PC, // D27 PC, // D28 PC, // D29 PD, // D30 PD, // D31 };
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[NUM_DIGITAL_PINS] = { _BV(0), // D0 PD0 _BV(1), // D1 PD1 _BV(2), // D2 PD2 _BV(3), // D3 PD3 _BV(0), // D4 PB0 _BV(1), // D5 PB1 _BV(2), // D6 PB2 _BV(3), // D7 PB3 _BV(5), // D8 PD5 _BV(6), // D9 PD6 _BV(4), // D10 PB4 _BV(5), // D11 PB5 _BV(6), // D12 PB6 _BV(7), // D13 PB7 _BV(7), // D14 PA7 _BV(6), // D15 PA6 _BV(5), // D16 PA5 _BV(4), // D17 PA4 _BV(3), // D18 PA3 _BV(2), // D19 PA2 _BV(1), // D20 PA1 _BV(0), // D21 PA0 _BV(0), // D22 PC0 _BV(1), // D23 PC1 _BV(2), // D24 PC2 _BV(3), // D25 PC3 _BV(4), // D26 PC4 _BV(5), // D27 PC5 _BV(6), // D28 PC6 _BV(7), // D29 PC7 _BV(4), // D30 PD4 _BV(7), // D31 PD7 };
const uint8_t PROGMEM digital_pin_to_timer_PGM[NUM_DIGITAL_PINS] = { NOT_ON_TIMER, // D0 PD0 NOT_ON_TIMER, // D1 PD1 NOT_ON_TIMER, // D2 PD2 NOT_ON_TIMER, // D3 PD3 NOT_ON_TIMER, // D4 PB0 NOT_ON_TIMER, // D5 PB1 NOT_ON_TIMER, // D6 PB2 TIMER0A, // D7 PB3 TIMER1A, // D8 PD5 TIMER2B, // D9 PD6 TIMER0B, // D10 PB4 NOT_ON_TIMER, // D11 PB5 TIMER3A, // D12 PB6 TIMER3B, // D13 PB7 NOT_ON_TIMER, // D14 PA0 NOT_ON_TIMER, // D15 PA1 NOT_ON_TIMER, // D16 PA2 NOT_ON_TIMER, // D17 PA3 NOT_ON_TIMER, // D18 PA4 NOT_ON_TIMER, // D19 PA5 NOT_ON_TIMER, // D20 PA6 NOT_ON_TIMER, // D21 PA7 NOT_ON_TIMER, // D22 PC0 NOT_ON_TIMER, // D23 PC1 NOT_ON_TIMER, // D24 PC2 NOT_ON_TIMER, // D25 PC3 NOT_ON_TIMER, // D26 PC4 NOT_ON_TIMER, // D27 PC5 NOT_ON_TIMER, // D28 PC6 NOT_ON_TIMER, // D29 PC7 TIMER1B, // D30 PD4 TIMER2A, // D31 PD7 };
#endif // ARDUINO_MAIN
#endif // Pins_Arduino_h // vim:ai:cin:sts=2 sw=2 ft=cpp
« Last Edit: January 22, 2013, 07:41:35 pm by retrolefty »
« Reply #18 on: January 22, 2013, 08:04:33 pm » |
I had earlier checked the signals going to digital pins D0..D31, and they all matched ok. However, try changing to the following line in Bobuino variant pins_arduino.h, #define analogPinToChannel(p) ( (p) < NUM_ANALOG_INPUTS ? (NUM_ANALOG_INPUTS-1) - (p) : -1 ) The original produces 8..1 for p=0..7, while this one produces 7..0 for p=0..7.
« Reply #19 on: January 22, 2013, 09:39:31 pm » |
I had earlier checked the signals going to digital pins D0..D31, and they all matched ok. However, try changing to the following line in Bobuino variant pins_arduino.h, #define analogPinToChannel(p) ( (p) < NUM_ANALOG_INPUTS ? (NUM_ANALOG_INPUTS-1) - (p) : -1 ) The original produces 8..1 for p=0..7, while this one produces 7..0 for p=0..7. That made no change to the results of prior test, same weird ordering. However this ugly hack does fix it if using just the Ax name, but of course doesn't fix using the digital pin number work correctly. static const uint8_t A0 = 15; static const uint8_t A1 = 14; static const uint8_t A2 = 21; static const uint8_t A3 = 20; static const uint8_t A4 = 19; static const uint8_t A5 = 18; static const uint8_t A6 = 17; static const uint8_t A7 = 16;
Lefty
Greenville, IL
Warning Novice on board! 0 to 1 chance of errors!
« Reply #20 on: January 22, 2013, 09:48:43 pm » |
Using this sketch to test my Bobuino analogpins: void setup() { // declare the ledPin as an OUTPUT: Serial.begin(9600); }
void loop() { // read the value from the sensor: for (int i=0; i < 8; i++){ int sensorValue = analogRead(i); Serial.print("A"); Serial.print(i); Serial.print( " = "); Serial.println(sensorValue); delay(500); } } My results: printed name Actual pin A0 A0 A1 A7 A2 A6 A3 A5 A4 A4 A5 A3 A6 A2 A7 A1
« Reply #21 on: January 22, 2013, 10:02:07 pm » |
That appears to work for you. Doesn't for me, Could you post the contents of your Bobuino variant pins_arduino.h file? That is one way of testing I didn't try, using numbers 0 to 7 to refeer to the analog pin names A0 to A7 or by using their digital pin numbers 14 to 21. All forms should work the same. However when I tried your sketch I see 0 reading A7, 1 reading A6, etc, so a symmetrical flip of 0-7 to 7-0. Not the same results I see when I'm using A0 or 14. I'm sure it's Bob's fault for not testing his analog input pins before sending his PCBs out for production.  Lefty
« Last Edit: January 22, 2013, 10:09:13 pm by retrolefty »
Boston area, metrowest
« Reply #22 on: January 22, 2013, 10:27:24 pm » |
Indeed. I only tested for digital functionality, never tried a pot on each analog pin. Maniacbug flipped the analog pin mappings end for end for me, so that ADC7 (near the middle of the chip) went direct to the A0 header near the middle of the board, the way a Duemilanove/Uno has them. (whereas ADC0 is near the middle on a '328). The line identified in pins_arduino.h #define analogPinToChannel(p) ( (p) < NUM_ANALOG_INPUTS ? (NUM_ANALOG_INPUTS-1) - (p) : -1 )
might be the key.
Greenville, IL
« Reply #23 on: January 22, 2013, 10:38:43 pm » |
@retrolefty #ifndef Pins_Arduino_h #define Pins_Arduino_h
#ifdef ARDUINO_MAIN
« Reply #24 on: January 22, 2013, 10:52:15 pm » |
Thanks I see no difference in the contents, must be something else going on.
Lefty
« Reply #25 on: January 22, 2013, 11:38:07 pm » |
So in summation of problems addressing analog input pins of bobuino varieant board, there seems to be two different symptoms: 1. If using analogRead() addressing names of 0 to 7 see a symmetrical reversal to 7 to 0. 2. If using analogRead() addressing names of A0 to A7 or 14 to 21 get: sketch software pin name used valid voltage reading shows up on shield pin
Strange stuff, no? Lefty
« Reply #26 on: January 22, 2013, 11:54:35 pm » |
At least we're making some progress, as it's not just a dream I had. Mine work in perfect order for "both" 0..7 and A0.., although I'm using a loop on A0..., so I don't know what the problem is over there. ??? I'm not using Bob's board, just connecting directly to the pins. Here is my current test. I compiled the code with the Bobuino arduino_pins.h file patched as I indicated above. All ADC Channels are floating here, and I am moving a gnd wire from pin to pin after each set of readings, starting at 33 [AD0]. You see the zero reading follows along exactly correctly. My entire sketch is included below. A0..A7: 0 301 275 290 320 352 360 602 0...7: 0 152 226 272 313 362 365 479 A0..A7: 419 0 138 232 308 384 400 425 0...7: 403 0 103 181 229 261 272 275 A0..A7: 420 428 0 123 243 309 323 304 0...7: 305 319 0 97 166 191 210 254 A0..A7: 306 319 295 0 111 211 266 308 0...7: 339 351 338 0 136 243 307 385 A0..A7: 398 392 360 345 0 166 262 379 0...7: 396 398 382 375 0 149 240 338 A0..A7: 360 370 351 343 346 0 169 271 0...7: 317 338 336 332 335 0 121 204 A0..A7: 370 381 361 348 357 356 0 154 0...7: 235 282 292 294 305 312 0 111 A0..A7: 146 257 306 351 393 476 443 0 0...7: 95 183 227 255 279 295 296 0 A0..A7: 125 223 252 269 293 311 312 0 0...7: 104 196 235 260 286 313 321 0
/********************************************************** file: analog_test1284 revised: 01/22/13, orig 01/21/13. Tests Bobuino-1284 ADC channels. ***********************************************************/
/*****************************************/ void setup() { Serial.begin(57600); Serial.println("\n1284 Analog Test ...");
a_print("defines: A0=",A0); a_print(", A7=",A7); }
/******************************************/ void a_print( char *s, int num ) { Serial.print(s); Serial.print(num); }
/*****************************************************/ void loop() { test_adc(); }
#define INTV 5000 // ADC repeat interval.
/**************************************************/ void test_adc() { static unsigned long prev=0; // last time LED was updated unsigned long current=millis(); static int cnt=0; int i, val=0; if( (current - prev) > INTV) { prev = current; // schedule next tick. nl(); Serial.print("A0..A7: "); for( i=0; i<8; i++) { val = analogRead(A0+i); // val = analogRead(A0+i); a_print(" ",val); delay(100); } nl(); Serial.print(" 0...7: "); for( i=0; i<8; i++) { val = analogRead(i); // val = analogRead(i); a_print(" ",val); delay(100); } } }
void nl() { Serial.println(""); }
« Last Edit: January 22, 2013, 11:56:24 pm by oric_dan »
« Reply #27 on: January 23, 2013, 12:32:14 am » |
Was wiring_analog.c updated from 1.0 to 1.01, .02, .03? Wondering when the 1284 support came in.
« Reply #28 on: January 23, 2013, 12:43:57 am » |
AAMOF, I had already looked at that, but must have been in 1.0 only. However, my sketch from last time gives me exactly the same results with both IDE 1.0 and 1.03. Likewise for ERW 1.03. Go figure. Have you tried running my sketch from last time? Maybe something is weird there. IDE 1.0 int analogRead(uint8_t pin) { uint8_t low, high;
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) if (pin >= 54) pin -= 54; // allow for channel or pin numbers #elif defined(__AVR_ATmega32U4__) if (pin >= 18) pin -= 18; // allow for channel or pin numbers #else if (pin >= 14) pin -= 14; // allow for channel or pin numbers #endif IDE 1.02 int analogRead(uint8_t pin) { uint8_t low, high;
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) if (pin >= 54) pin -= 54; // allow for channel or pin numbers #elif defined(__AVR_ATmega32U4__) if (pin >= 18) pin -= 18; // allow for channel or pin numbers #elif defined(__AVR_ATmega1284P__) || defined(__AVR_ATmega644P__) if (pin >= 24) pin -= 24; // allow for channel or pin numbers #else if (pin >= 14) pin -= 14; // allow for channel or pin numbers #endif IDE 1.03 int analogRead(uint8_t pin) { uint8_t low, high;
« Reply #29 on: January 23, 2013, 01:32:36 am » |
Well I seem to be straighten out finally. What I was fighting I guess is a older or different version of maniacbug's hardware files setup for the sanguino/644P chip which I had downloaded and modified to use the bobuino pins_arduino.h, added a optiboot bootloader file for the 644P, etc. However there seems to be too many differences between some of the hardware core files between the two different maniacbug's hardware folder I had downloaded and installed. So I dumped all the sanguino hardware folders and just added a new bobuino 644P/optiboot board to the maniacbug-mighty-1284p hardware folders. Then I added your suggested fix to the pins_arduino.h and then recompiled/uploaded the various analog test sketches and all is well in bobuino 644P land for me now, yea. Thanks for your help, I had never actually tested out my analog pins for this bubuino/644P setup (just like Bob I guess  ) so it's good to have that checked off. Still waiting for my 1284P chip to show up, I hope it has at least crossed the international date line by now. Lefty
« Last Edit: January 23, 2013, 01:34:15 am by retrolefty »
