Loading...
Pages: [1]   Go Down
Author Topic: arduino compile error  (Read 295 times)
Offline Offline
Newbie
View Profile
hey i m new to this site......
actually m makin a line follower robot based on d PID algorithm....
m gettin a few compile errors
pid_n_linefollower:78: error: stray '\' in program
pid_n_linefollower:83: error: stray '\' in program
pid_n_linefollower:86: error: stray '\' in program
pid_n_linefollower:-1: error: expected initializer before 'current_position'
pid_n_linefollower:17: error: expected initializer before 'current_position'
ive attached d code ...
plz hlp me
thnxx in advance......  smiley
Logged
Offline Offline
Sr. Member
View Profile
Well, I see funky characters like this:
unsigned int Error = target_pos – current_pos;
so that is probably the problem. Whatever that is, it is not a C operator.
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Code:
unsigned int RPM of Left motor = pwm – (Correction);
unsigned int   RPM of Right motor = pwm + (Correction);
You can't have spaces in variable names.
Code:
calculate current_position ();
What is this supposed to be/do?
Code:
if (error==0)
   analogWrite (RPM of Left motor,3) && analogWrite (RPM of Right motor,5)
  if (error < 0)                                                      // line follower algorithm
    analogWrite (RPM of Left motor,3);
  if (error > 0)
    analogWrite (RPM of Right motor,5);
Putting the arguments in the correct order is useful, too.
Logged
Offline Offline
Newbie
View Profile
thnxx 4 d reply .......
ive jus started with c and arduino n m nt a skilled c programmer.... smiley-sad
bt m learnin frm u ppl thnxx a lot
Code:
itz to calculate the current position of d robot in respect to d line.....
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Is there something wrong with your vowel keys?
Your last post was hopelessly garbled.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
what are those expected initializers before....???
and     stray '\' in program
Logged
New Jersey
Offline Offline
Edison Member
View Profile
It's usually not very helpful to chase down every error the compiler produces - if you fix the first one, others will often vanish too. PaulS has pointed out a number of issues which you would be well advised to fix first. If you still have compiler issues then, post your amended code and the new error messages
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Quote
I'll second that.... so often the case
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Global Moderator
UK
Online Online
Brattain Member
View Profile
Code:
Ignoring, for a moment, the spaces in the variable names, analogWrite doesn't return a value, so putting two in an expression like that doesn't make a lot of sense.
Logged
Offline Offline
Newbie
View Profile
@ AWOL
Code:
[analogWrite (RPM of Left motor,3) && analogWrite (RPM of Right motor,5)]
that was a mistake by me sry  :smiley-red: .........
bt ill try to fix d errors pointed by paulS
Logged
Offline Offline
Newbie
View Profile
sry 4 d typing errors in d forum .....
bcoz m vry new to this forum
Logged
NE PA
Offline Offline
Full Member
View Profile
WWW
O K Doe Kay
Logged
California
Offline Offline
Edison Member
View Profile
Are you very new to typing?
You aren't composing a text message, so don't type like it.
Logged
Offline Offline
Newbie
View Profile
OK
Logged
Pages: [1]   Go Up
Print
Jump to:
