Topic: call of overloaded 'write (int)' is ambigiuos (Read 740 times) previous topic - next topic
i_luv_arduino
When I try to compile I get this error
"call of overloaded 'write (int)' is ambigiuos"
Here is the parts of my code I think the error is in:
Code: [Select]
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
byte paddleup[8] = {
  0b10000,
  0b10000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000
byte paddletwo[8] = {
  0b00000,
  0b00000,
  0b10000,
  0b10000,
  0b00000,
  0b00000,
  0b00000,
  0b00000
byte paddleone[8] = {
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b10000,
  0b10000,
  0b00000,
  0b00000
byte paddledown[8] = {
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b10000,
  0b10000
byte ballone[8] = {
  0b00000,
  0b00100,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000
byte balltwo[8] = {
  0b00000,
  0b00000,
  0b00000,
  0b00100,
  0b00000,
  0b00000,
  0b00000,
  0b00000
byte ballthree[8] = {
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00100,
  0b00000,
  0b00000
byte ballfour[8] = {
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00100
  // set up the LCD's number of columns and rows:
  lcd.createChar(0, ballone);
  // create a new character
  lcd.createChar(1, balltwo);
  lcd.createChar(2, ballthree);
  lcd.createChar(3, ballfour);
  lcd.createChar(4, paddleup);
  lcd.createChar(5, paddletwo);
  lcd.createChar(6, paddleone);
  lcd.createChar(7, paddledown);
And the other part:
Code: [Select]
lcd.setCursor(6, 1);
lcd.write(0);
delay(100);
if (pushButton == HIGH); {
  x = x+1;
pYro_65
It is saying it needs more information.
Code: [Select]
lcd.write(0);
This can match a couple of write methods, provide more context by casting it to what you desire ( have a look at the lcd library and what overloads it provides ).
Code: [Select]
lcd.write( ( byte ) 0 );
lcd.write( int(0) );
lcd.write( 0.0f );
Forum Mod anyone?
https://arduino.land/Moduino/
johnwasser
I think the problem is that 0 can be interpreted as either a byte:
Code: [Select]
virtual size_t LCD::write(uint8_t)
or a null character pointer:
Code: [Select]
size_t Print::write(const char*)
Instead, use '\0' which is a character constant or cast it: (uint8_t)0
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
i_luv_arduino
i_luv_arduino
pYro_65
yes, '\0' is a null character, there is a number of escape characters:
Quote
\a \b \f \n \r \t \v
search google for a full explanation.
Forum Mod anyone?
AWOL
Quote
so I can use '/0'?
No, you cannot - it is a multicharacter literal consisting of the characters '/' and '0'.
You can use '\0'.
OP - stop locking or deleting your threads.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
