Topic: New UTFT Libray with Arduino ARM spport (Read 29527 times) previous topic - next topic
pYro_65
Very nice.
I'm not up with the due yet ( ordered and waiting ), the two ports A & C, I'm assuming are 32-bits wide. If this is the case, does this mean there is around 40 unused pins?
If so are they usable, I'm thinking along the lines of 'probably not' without changing the single write to a mask of bits. Maybe the due has someway of dealing with this.
I'm just wondering as there only appears to be a few port B and D pins left without A & C.
Forum Mod anyone?
https://arduino.land/Moduino/
coldtears
There is a typo, all command lines are routed to PORTD ( PD0-PD3)
and data lines are routed to PORTC
The pins left for use will probably be those on horizontal headers on DUE (just like MEGA2560) where they are not occupied by the shield. Should be around 4x8=32pins left unused
pdwyer
Rather than just refer to a port, can you reference the actual pin numbers (IC and board connection) used for D0-D15 of a display and WR, RD, CS, E, D/C used for LCD control?  Also, does the code employ 8080 or 6800 timing?  I have a new shield on order, but I would still like the pin numbers so that I can start looking at the code and understand the hardware.  Also, if you have the pinout for the touch screen and the SD drive, that will be next.
Thanks!
coldtears
The data pins are routed to PC1-8 (lower 8 bit) and PC12-19 (higher 8 bit), so you probably need to shift your lower 8 bit to the right<<1, and higher 8 bit to the right <<12, and then you can strobe the WR pin. So you will need 3 arduino command for one WR strobe.
Like this:
                REG_PIOC_CODR=0xFF1FE;
      REG_PIOC_SODR=(VL<<1) & 0x1FE;
      REG_PIOC_SODR=(VH<<12) & 0xFF000;
      pulse_WR();
For the 4 command pins, they are routed to PD1-4. This should be straight forward.
This is possible because the creator of DUE has made perfect routing of these lines to the 2x20 header.
SD Card will be directly connected to the SPI interface on the 6pin header in the center of the DUE board(DUE only has SPI access on this 6pin header).
Schematic is http://coldtears.lin3.siteonlinetest.com/files/CTE_DUE_shield.zip  ]:)
cowasaki
Like this:
      pulse_WR();
This is very useful thanks.
Do you have a key to the values of the other components on the board?
TheKitty
Has anyone had luck with a Due compatible library for SPI based displays?  UTFT seems to be only parallel and I2C?
cowasaki
I've just received a 7" SSD1963 based touch screen LCD from china :)
It has a micro SD card slot and two 32 way connectors (both of which have the SAME connections):
GND   3v3
D1     D0
D3     D2
D5     D4
D7     D6
D9     D8
D11   D10
D13   D12
D15   D14
RS     CS
RD    WR
TE    RST
INT   TD0
PWM TD1
PCS   TSCK
SDCS  TCS
5V     GND   (But these two are not connected)
There is a diagram on the back of it that goes like this:
JP1  Back_Light
@    SSD-PWM
     MCU-PWM
JP1 has a SMD resistor soldered across it at the factory and I think that "@   SSD-PWM" is telling me about this model.
Not a bad price for such a large touchscreen with card reader either........
....   now to connect it :D
cowasaki
So just to get this straight....
Does this look right / what about pins 22-32  ??
| PIN   | LABEL | PIN    |  PIN
| NUM | TFT    | DUE   | FUNCTION
| 1      | 3v3    | >>    | 3v3 power
| 2      | GND   | >>    | Ground
| 3      | D0     | 33      |
| 4      | D1     | 34      |
| 5      | D2     | 35      |
| 6      | D3     | 36      |
| 7      | D4     | 37      |
| 8      | D5     | 38      |
| 9      | D6     | 39      |
| 10    | D7      | 40      |
| 11    | D8      | 51      |
| 12    | D9      | 50      |
| 13    | D10    | 49      |
| 14    | D11    | 48      |
| 15    | D12    | 47      |
| 16    | D13    | 46      |
| 17    | D14    | 45      |
| 18    | D15    | 44      |
| 19    | CS      | 27      |
| 20    | RS      | 25      |
| 21    | WR     | 26      |
| 22    | RD      | >>    |  3v3
| 23    | RST    | 28      |
| 24    | TE      | 9        |  Don't know !  ?????????????
| 25    | TD0    | >>    | MISO
| 26    | INT     |          |  Don't know !  ?????????????
| 27    | TD1    | >>    | MOSI
| 28    | PWM   | 9       |  Don't know !  ?????????????
| 29    | TSCK  |          |  Don't know !  ?????????????
| 30    | PCS    | 52     |  Don't know !  ?????????????
| 31    | TCS    | 5       |  Don't know !  ?????????????
| 32    | SDCS  | 4       |  Don't know !  ?????????????  possibly 54??????
cyclegadget
I have this screen and adapter from Sainsmart http://www.sainsmart.com/arduino-compatibles/module/lcd-module/sainsmart-3-2-tft-lcd-display-touch-panel-pcb-adapter-sd-slot-for-arduino-2560.html
Can anyone tell me if I can make the screen work with the Due by removing the resistors from the adapter shield? I am thinking that they used resistors to lower the voltage of the Arduino Mega from 5 volts to 3.3 volts. Therefore, if you have a Due producing only 3.3 volts, then the resistors can be removed to make it work.
Any ideas?
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
pYro_65
@cyclegadget, I remember reading about a pen that contained conductive ink. If you can get one, and its good quality, you might be able to draw a line over the top of the resistors.
Or use a loop of wire over each resistor, some people fixed the SD card connection using this method.
If you have the resources, a little breakout that reconfigures the 40pin header to the LCD format would work, then you don't need the shield.
Forum Mod anyone?
pagoda
The stuff you are looking for used to be marketed in car accessory shops for repairing rear screen heaters.
It is basically like a small bottle of nail varnish - but loaded with either silver or aluminium powder for conductivity.
You can certainly use it to fix damaged pcb tracks (remove varnish from the good area first!!) , so shorting out a couple of SM resistors should be easy.  Just don't splash it around... :)
Graeme
cyclegadget
Thanks for the replies from both of you! I wanted to be sure that I had the correct idea before I did anything drastic. I can solder down to 805 resistors with good results so, I think I will be able to solder out or jumper those resistors.
I will give it a try soon!
jake1981
I have problems accessing DS1307(rtc) on pins 20(sda) and 21(scl). RTC renders un usable right after initializing UTFT.. :/
Any help appreciated..
jchalo99
I have a older shield for the mega, want to make it work the the due. how can i do this, mine the display is soldered on the shield, and there are surfacemount resisters, i can get to the resisters with a soldering iron if need be.
Docedison
I'be been using both the CTE class and the UTFT class on a Digix and both are flawless, The CTE shield and class being noticeably faster compared to the class Mr Karlsen wrote last year. Screamer fast)
Apparently when he rewrote the class to better encompass the Arm Avr and Pic processors he changed a substantial amount of code. I have had.. some code for the class written early last year and the speed differences are substantial... One of the Very few times I've "Donated" to a project and really got my $0.50's worth.. The Manuals... "Manuals"? who ever heard of actually supplying manuals with Arduino code...?  The manuals are an encyclopedia compared to the Arduino Manuals? and are actually useful.
If you use Mr Karlsen's code a donation would be a sign that you appreciate what he has done and how much it's made your own work easier. FWIW I own 3, 3.2" displays (5 if you cound 2, 4D Systems 3.2" displays and an Itead 4.3 which was junk defective out of the box (randomly shows a silver screen and the postage to return it is more than the 'thing' is worth) and a CTE 4.3 which is beautiful.
All in all the best display of it's class I've ever seen.
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
