Topic: using arduino to recognise gestures (Read 7190 times) previous topic - next topic
JimboZA
#15
Jan 19, 2013, 04:13 pm Last Edit: Jan 19, 2013, 04:30 pm by JimboZA Reason: 1
I just looked at a sign language chart, see attached, so here's my off-the-top-of-my-head thoughts as clue to how this could be done. (Assuming that's the sign language you're using, I suspect there's more than one protocol.)
With a quick look at the digits 0-9 on the chart, it seems that each finger (and when I say finger I include thumb) has only two positions- extended and folded.
So for a sensor, treating them exactly like pots as shown in this tutorial calibrate the readings into three zones: extended and folded of course, and also an "unknown".
Then read the glove and decide what position each finger is, and Voila!
Over to you... that should get you going? I probably said too much, and deserve the wrath of other posters.
[rant]As is sooooooo often the case, this is a typical example of someone wanting to dive into code without the slightest thought as to what the hell he's trying to do in the first place.  :smiley-yell: [/rant]
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
wildbill
How many flex sensors are you thinking of using? Apologies if it's explained in your attachment - the Arduino servers don't feel like letting me open it today.
zoomkat
i am trying to learn it by doing it in fritzing... i made a basic circuit ie wen the fkex sensor varies and depending on that the leds will glow... but i dont know how to run it... i have written the code in arduino.... what should i do next...
The link to your project appears to be dead, so not really sure what your project is trying to do. You haven't posted your code. Perhaps you can give a detailed list of the seperate parts of your project, how these parts are expected to work, and what you have accomplished so far in making the parts work.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
JimboZA
Yep error 503 on that link... would be nice to see the ppt presentation.
JimboZA
i will buy the glove and then embed the flex sensors if possible accelorometer....
You haven't mentioned what the purpose of the accelerometer is?
To me, this project isn't about gestures.... to me a gesture implies movement and perhaps that's where the accelerometer would come in. This project is more about poses, in the sense that it needs to read a set of static, pre-defined "finger configurations".
If it's only the digits 0-9 and if it's the language I posted where a finger is either extended or curled (and an illegal no-mans-land in between) it's actually pretty trivial.
Grumpy_Mike
Quote
Exactly.  ]:)
Thinking the project was actually about gestures is what prompted me to write the earlier replies. A crap question always generates a crap reply.
It seem that the project as now framed is much more doable.
Quote
I suspect just to show if the finger is pointing up or down.
That is possible but requires a bit of skill mounting small surface mounting packages on fabric. Then trying to address all five accelerometer without a ton of wiring is tricky. Most accelerometers are I2C devices but with not that many addresses. The analogue output accelerometers have a small output prone to noise pickup.
JimboZA
Quote
Or at least a Grumpy one.....
Grumpy_Mike
Quote
Yes indeed.  ;)
John_Smith
looking at the diagrams posted, you could start off a crude prototype with a glove with 5 microswitches at the base of each digit ( digit bent or straight ) and a contact at the end of the thumb and the tips of the fingers  for 6, 7, 8 ,and 9 .
You could use  10 " if"  statements  ( I am talking crude here )  the contacts would override the microswitch combinations  ?.
Lots of work to do, but it could be a start.
45 years of editing projects with a knife and soldering iron, then I found Arduino !
