Topic: Simon Game programming (Read 3464 times) previous topic - next topic
johncc
Vincent19
Mean the player has more than 3s before they fail ? LOL I thought less than 3s before they fail !
johncc
It could be under 3s depending on the accuracy of your particular Arduino crystal or resonator.  Why don't you devise a way to measure it against an atomic clock reference standard and get back to us with the results.
Vincent19
I will record a video later on. :D
Vincent19
https://www.youtube.com/watch?v=huz-WocDfrY
This is the video. You can observe that the timeout is quite fast sometimes..LOL
johncc
#20
Jan 23, 2013, 01:37 pm Last Edit: Jan 23, 2013, 01:44 pm by johncc Reason: 1
Ok, the speeed of the output goes faster. However, based on the full coding, does it means that the time I need to respond also getting faster ? Cause I seems to feel it when playing it ><
I don't think so, because RESPONSETIME is a defined constant and doesn't get changed.
Quote
Ok.  Nice video :)
Since counter is never reset (other than when you fail and start over), it means you have a total of (slightly over :) ) 3 seconds of "decision time" through the whole game (the variable "counter" represents accumulated player response time through the entire "game").
So it's not that you need to speed up your input as the game goes on, rather it means that your input needs to be as fast as possible the whole time!
Have you tried increasing RESPONSETIME to a more reasonable value (say, 10000)?
Cheers,
John
johncc
You would be able to see this happening if you put a print statement in the output function as below and then watch on your Serial Monitor
Code: [Select]
   Serial.println("");
   Serial.print("Turn: ");
   Serial.println(turn);
   Serial.print("Response time millisecond total: ");  // add these two
   Serial.println(counter);
Vincent19
Quote
Ok.  Nice video :)
Cheers,
John
Okay, I think I get you ! TOTAL ACCUMULATED of delay time before the user input throughout the game which will cause sometimes the game to be game over very fast ?  Is it correct ?
Thanks.
Vincent
johncc
Thanks.
Vincent
Yeah, that's the way I am reading it :)
Did you build that from a kit or what?
John
Vincent19
yes, a kit.
Link : http://makeprojects.com/Project/Repeat-After-Me-A-Mintronics-Memory-Game/1933/1
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
