Pages: [1] 2   Go Down
Author Topic: Simon Game programming  (Read 428 times)
This is the whole coding for the simon game. I am curious about how the code flow since each function do not return anything. And I am curious about this part:
void input()
  for (int x=0; x <= turn;)
    input1 = digitalRead(SWITCHROOT);
    input2 = digitalRead(SWITCHROOT+1);
    input3 = digitalRead(SWITCHROOT+2);
    input4 = digitalRead(SWITCHROOT+3);
    counter++;
    if (counter > RESPONSETIME)
      Serial.println("TIMEOUT!");
      fail(randomArray[x]);
      counter = 0;
      x++;
Does that means that we need to respond faster as the counter increases ?
Thanks
« Last Edit: January 22, 2013, 07:43:31 am by Vincent19 » Logged
Seattle, WA USA
Online Online
Seattle, WA USA
No, it isn't.
The whole code in the text file as it exceed the word limits.
Thanks
Netherlands
you can attach as zip file
Rob Tillaart
Cant be view now ?
Temple, Texas
In certain terminologies, functions which don't return anything are called "procedures".
Your example code is well-written, IMO.
void input()
    counter++;
      counter = 0;
      x++;
No, it means if too much time has elapsed, you lose.  Big clues are: "TIMEOUT!" and "fail" smiley
HTH,
John
But is it true that every turn I have 3s of timeout time ? But it seems to me not on hardware ><
Well, procedures so means once it done execute the output code, then it will automatically go to input code ? Flow according to the code ?
Thanks
Temple, Texas
// Slowly cranks up the pressure
void increaseSpeed()
  if (turn == band)
    beepdelay = 170;
    pausedelay = 80;
    return;
  if (turn == band * 2)
    beepdelay = 150;
    pausedelay = 60;
    return;
  if (turn == band*3)
    beepdelay = 120;
    pausedelay = 40;
 for (int y = 0; y < WINSTATE; y++)
   output();
   input();
   increaseSpeed();  // <---------------------------------- THIS is the part that makes it go faster as the game proceeds
 }                                                               It calls the procedure "increaseSpeed" defined above
 win();
in the "for" loop above, until the player either wins or loses, the output code is executed, then the input code is executed, then increasespeed, and then back to output, etc.
John
Ok, the speeed of the output goes faster. However, based on the full coding, does it means that the time I need to respond also getting faster ? Cause I seems to feel it when playing it ><
Ok, so either the player win or lose, it will follow the sequence : output > input > increase speed. And the final win(); is for what ?
Thanks
Temple, Texas
I don't think so, because RESPONSETIME is a defined constant and doesn't get changed.
Up above is the definition of the win() "procedure".  Looks like it beeps a certain way and flashes all the lights.
The loop() procedure at the bottom of the code is called over and over by the Arduino framework code. Therefore, win or lose, the player gets to keep going (but I think the score is reset once you lose).  http://arduino.cc/en/Reference/Loop
The loop() procedure "high-level" code being at the bottom is typical of c and c++ coding style, with the definitions of the procedures/functions/subroutines above.
Note I am answering these questions from quick, cursory examination of the code because it is well organized, factored, and very good names for the variables.  (But I could have missed something smiley )
Have you programmed in any other languages?  If so, what?
No..just arduino languages. So , win() will only be call once the for loop finish executing in void loop() ?
Temple, Texas
Yes, it will be called after y<WINSTATE becomes false.  WINSTATE is defined as 32 so it appears that the for-loop will loop 32 times.
I am very curious and dont understand for the part if(counter> RESPONSETIME)
How is that ? the counter will increase in every loop, so in every loop it is getting closer to exceed RESPONSETIME isnt ?
Temple, Texas
Yes.  It looks like the player has something slightly over 3 seconds (RESPONSETIME=3000) to push the buttons in proper sequence, or else he fail().
« Last Edit: January 22, 2013, 10:52:23 pm by johncc » Logged
slightly over 3s ? not less than 3s ?
Pages: [1] 2   Go Up
