Topic: LPD8806 code and sanity check (Read 1 time) previous topic - next topic
readywater
Hey!
So, I have six lighting fixtures with 3 LPD8806 based LED strips each attached to them.
Because of physical limitations of the fixtures, they are connected in parellel, and I can't chain the strips. Each strip has 20 LEDs on it. They aren't the adafruit LEDs, but a roll I ordered from alibaba.
I'm running everything off of an arduino mega, and don't have any additional circuitry, just basically direct connect from arduino to appropriate LED.
Currently, I'm getting just a string of gibberish LEDs. Really hoping to get a sanity check, as I get demos working previously, and I don't understand what's going wrong now The installation is going up in two days, kinda panicked.  Thanks in advance!
To explain the code a bit:
It sets up all the different strips, and runs a test (currently not working).
The strips should be constrained to a particular colour set based off the the individual power values from the Light struct, so between 0-127 red and 0-60 yellow, creating a range from deep red to orange (it's for a fire light)
But ya, currently nothing is happening.
Here's my code (gist here: https://gist.github.com/4584635)
Code: [Select]
#include "LPD8806.h"
#include "SPI.h"
// Constants
const int NUMLIGHTS = 6;    // Number of lights per arm
const int NUMARMS = 3;      // Number of arms per light
const int LEDPERARM = 20;   // Number of lights
const int testPin = 53;
int dataPins[NUMLIGHTS*NUMARMS] = {
   22,24,26,   // Light 0
   28,30,32,   // Light 1
   34,36,38,   // Light 2
   40,42,44,   // Light 3
   46,48,50,   // Light 4
   4,6,8     // Light 5
/*    2,
   4,
   6,
   8,
   10,
   12 */
int clockPins[NUMLIGHTS*NUMARMS] = {
   23,25,27,   // Light 0
   29,31,33,   // Light 1
   35,37,39,   // Light 2
   41,43,45,   // Light 3
   47,49,51,   // Light 4
   5,7,9     // Light 5
/*    3,
   5,
   7,
   9,
   11,
   13 */
// Light struct
typedef struct {
   int id; // The id must match that of the OF program
   int pwr; // 0-127 val, derived from OF float val
   LPD8806 strip[NUMARMS]; // The three strips
} Light;
Light Lights[NUMLIGHTS]; // Declare lights array
// Serial communication
String inString = "";
int inChar;
int curLight = 0;
//int curArm = 0;
int curPwr = 0;
   // Setup all lights and arms
   pinMode(testPin,OUTPUT);
   for(int i=0;i<NUMLIGHTS;i++) {
       // Set up the Lights with the appropriate objects
       Lights[i].id = i;
       for(int a=0;a<NUMARMS;a++) {
           Lights[i].strip[a] = LPD8806(LEDPERARM, dataPins[i+a],   clockPins[i+a]);
           Lights[i].strip[a].begin();
           Lights[i].strip[a].show();
           testStrip(&Lights[i].strip[a]);
           clearStrip(&Lights[i].strip[a]);
   // Start serial communication
   digitalWrite(testPin, HIGH);
void testStrip(LPD8806 * strip) {
   int i;
   for(i=0; i<strip->numPixels(); i++) {
       strip->setPixelColor(i, 0);
       strip->show();
   // Then display one pixel at a time:
       strip->setPixelColor(i, getColor(127) ); // Set new pixel 'on'
       strip->show();              // Refresh LED states
       strip->setPixelColor(i, 0); // Erase pixel, but don't refresh!
       delay(25);
   strip->show(); // Refresh to turn off last pixel
void clearStrip(LPD8806 * strip) {
   int i;
   for (i=0; i < strip->numPixels(); i++) {
       strip->setPixelColor(i, getColor(0));
       strip->show();
       delay(10);
   if(Serial.available() == 0) {
       digitalWrite(testPin, LOW);
           render(i);
           testStrip(&Lights[i].strip[0]);
void render(uint32_t lightId) {
   int maxPower, minPower, ptr, ledStr, pwr;
       for(int i=0;i<LEDPERARM;i++) {
           maxPower = i / LEDPERARM;
           minPower = 127 - (maxPower * (127-Lights[lightId].pwr));
         //  ptr = i + ( a * LEDPERARM );
           pwr = (byte)Lights[lightId].pwr;
           Lights[lightId].strip[a].setPixelColor(i,getColor(pwr));
       Lights[lightId].strip[a].show();
   delay(10); // holders for 10ms
// Derived from the LPD8806 lib
uint32_t getColor(byte pwr) {
   byte r,g,b;
   r = (byte)(1 + (.5 * pwr));
   g = (byte)(.5 * pwr);
   b = (byte)0;
   return ((uint32_t)(g | 0x80) << 16) |
   ((uint32_t)(r | 0x80) <<  8) |
   b | 0x80 ;
void parseSerial() {
   // Read serial input:
   if (Serial.available() > 0) {
       inChar = Serial.read();
   // Collecting the datas.
   if (isDigit(inChar)) {
       inString += (char)inChar;
   // Iterating through the lights
   if (inChar == ',') {
       Lights[curLight].pwr = inString.toInt();
       inString = "";
       curLight++;
   // Last light
   if (inChar == '\n') {
       Lights[NUMLIGHTS-1].pwr = inString.toInt();
       inString = "";
       curLight = 0;
