Ciao a tutti, grazie delle risposte.
Cosm ha messo a disposizione un nuovo sketch (data gennaio 2013), il quale ti permette di inviare un valore su Cosm, e allo stesso tempo rileggerlo, sempre con il medesimo sketch.
E un punto di partenza, ho provato a smanettarci sopra ieri eliminando la parte di post, utilizzando solo la parte Get , purtroppo ricevo sempre l'errore -403.
Posto qui sotto il Codice originale messo a disposizione da Cosm. Se qualcuno ha qualche idea.
P.S. il valore = 2777 l'ho messo io per testarlo.
Grazie
R.
* Cosm Arduino sensor client example.
* This sketch demonstrates connecting an Arduino to Cosm (
https://cosm.com),
* using the new Arduino library to send and receive data.
* Requirements
* * Arduino with Ethernet shield or Arduino Ethernet (board must use the
* Wiznet Ethernet chipset)
* * Arduino software with version >= 1.0
* * An account at Cosm (
https://cosm.com)
* Optional
* * An analog sensor connected to pin 2 (note we can still read a value from
* the pin without this)
* Created 8th January, 2013 using code written by Adrian McEwen with
* modifications by Sam Mulube
* Full tutorial available here:
https://cosm.com/docs/quickstart/arduino.html *
* This code is in the public domain.
#include <SPI.h>
#include <Ethernet.h>
#include <HttpClient.h>
#include <Cosm.h>
#define API_KEY "xxxxxxxxxxx" // your Cosm API key
#define FEED_ID xxxxxxx // your Cosm feed ID
// MAC address for your Ethernet shield
// Analog pin which we're monitoring (0 and 1 are used by the Ethernet shield)
int sensorPin = 2;
unsigned long lastConnectionTime = 0; // last time we connected to Cosm
const unsigned long connectionInterval = 15000; // delay between connecting to Cosm in milliseconds
// Initialize the Cosm library
// Define the string for our datastream ID
char sensorId[] = "sensor_reading";
CosmDatastream datastreams[] = {
CosmDatastream(sensorId, strlen(sensorId), DATASTREAM_FLOAT),
// Wrap the datastream into a feed
CosmFeed feed(FEED_ID, datastreams, 1 /* number of datastreams */);
EthernetClient client;
CosmClient cosmclient(client);
Serial.println("Cosm Sensor Client Example");
Serial.println("==========================");
Serial.println("Initializing network");
while (Ethernet.begin(mac) != 1) {
Serial.println("Error getting IP address via DHCP, trying again...");
delay(15000);
Serial.println("Network initialized");
Serial.println();
// main program loop
if (millis() - lastConnectionTime > connectionInterval) {
// read a value from the pin
int sensorValue = 2777.25;
// send it to Cosm
sendData(sensorValue);
// read the datastream back from Cosm
getData();
// update connection time so we wait before connecting again
lastConnectionTime = millis();
// send the supplied value to Cosm, printing some debug information as we go
void sendData(int sensorValue) {
datastreams[0].setFloat(sensorValue);
Serial.print("Read sensor value ");
Serial.println(datastreams[0].getFloat());
Serial.println("Uploading to Cosm");
int ret = cosmclient.put(feed, API_KEY);
Serial.print("PUT return code: ");
Serial.println(ret);
Serial.println();
// get the value of the datastream from Cosm, printing out the value we received
void getData() {
Serial.println("Reading data from Cosm");
int ret = cosmclient.get(feed, API_KEY);
Serial.print("GET return code: ");
if (ret > 0) {
Serial.print("Datastream is: ");
Serial.println(feed[0]);
Serial.print("Sensor value is: ");
Serial.println(feed[0].getFloat());
Serial.println();
