Loading...
Pages: [1]   Go Down
Author Topic: Is there non-static saran wrap? I've gotten two ebay IC shipments saran wrapped.  (Read 424 times)
Samplefinger
Offline Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
View Profile
Both times this was TQFP type ICs on trays.  They just cut the tray down to the number of ICs that I ordered and then saran wrapped it to keep the ICs in place.  Memory serves, saran wrap is very prone to creating a static field when unwrapped from the roll prior to wrapping something or unwrapped from that something later on.  I cut it off to avoid this, but like I said, saran wrap actually is worst when coming off the roll originally.   Should I be concerned?
The last item I got that was delivered this way was this item:
http://www.ebay.com/itm/10PCS-IC-EPM240T100C5N-TQFP100-ALTERA-NEW-GOOD-QUALITY-/300746279979
Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
If that's how they are being packaged for shipment, I can only imagine all of the horrific things they are doing to them before hand.
Logged
www.cmiyc.com - A guide to being an Enginerd
Anchorage, AK
Offline Offline
Sr. Member
View Profile
That's the best idea I've heard since using magnets to hold your floppy disks to the fridge.
This is why I don't buy any parts from eBay.  Thanks, but I'll spend the extra cash at Digikey and Mouser.
Logged
Samplefinger
Offline Offline
God Member
View Profile
Hmmm, now this makes me want to buy a TQFP-100 socket to make a programmer to test the buggers out a bit.  Add it to the project list...
Logged
Canada
Offline Offline
Sr. Member
Sometimes teaching, always learning,
View Profile
I once ordered some Atmega8 TQFPs from Tayda. They came loose in a little ziploc bag.
Then I ordered some Atmega328 TQFPs from Digikey. They came in a sealed, static-proof bag with the packaged date written on. There was a sticker that said "Use within 24 hours of opening". Inside the bag was a humidity monitor, and bake instructions depending on the relative humidity.
...I thought that was a bit overkill  smiley-eek  The parts work fine from either place.
Logged
Anchorage, AK
Offline Offline
Sr. Member
View Profile
Are you sure they were ATmega328's?  That sounds more like a package of cookie dough.
Logged
Cumming, Ga
Offline Offline
Edison Member
Ultimate DIY: Arduino
View Profile
WWW
I've had the exact same thing come with a TQFP keyboard encoder I purchased from Mouser.
Logged
Samplefinger
Offline Offline
God Member
View Profile
Yeah, some of the surface mount parts make unreliable joints if they take on any appreciable mositure before being reflowed.  So they say keep it in the bag or follow certain directions to gently bake all the moisture out of the parts (low temp long bake) before mounting.  I think for my projects I can safely ignore this, but for commercial products it makes sense.
Some samples I have received have the exact same warnings.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Pink or clear?
Logged
Samplefinger
Offline Offline
God Member
View Profile
OK, I dug it out of the trash can, actually it was at the top, I just didn't want to go out last night since it was 4 degrees fahrenheit here.  It's clear wrap, now cut into two pieces as I didn't unwrap it and instead cut it off.  If you want a picture, I could provide that later tonight or tomorrow morning.  Does that tell you anything?
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Pink is for electronics.  Clear is for the kitchen.
On the plus side, clear is easier to recycle.
Logged
Samplefinger
Offline Offline
God Member
View Profile
Hmm, I remember I had a calendar once with a girl wrapped in pink saran wrap, otherwise not so clothed.  I wonder what her voltage was?
Well, I am irritated with them then.  Maybe I should ask them what the deal was with that.
Logged
Anchorage, AK
Offline Offline
Sr. Member
View Profile
I thought the pink or clear thing was a joke.  I laughed.  Then I remembered getting some pink baggies with parts in them, so now I feel silly.
Quote
The REAL question is, what's her resistance?  smiley-twist
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
A truly serendipitous post: revealing, enlightening, amusing, entertaining, and a source of mild embarrassment.  Too bad my writing in school wasn't like that.
Logged
Anchorage, AK
Offline Offline
Sr. Member
View Profile
I aim to please, good sir.  ;-)
Logged
Pages: [1]   Go Up
Print
Jump to:
