Topic: How to connect this stepper motor pin? (Read 3554 times) previous topic - next topic
creativen
I have this kind of stepper motor
the type is PF42-48E5
and here is the data sheet: www.jameco.com/Jameco/Products/ProdDS/171601.pdf
I do not know how to connect this pin, which one is ground, vcc, data, and why so many colouuur???
Any heeelp?
Can I use this stepper motor in Arduino?
Jason2548
http://www.tigoe.com/pcomp/code/circuits/motors/stepper-motors/
Not sure how much this will help you.  I looks like what you have.
larryd
Measure the resistance between each wire to determine the coil setup.
It might be the 2 green wires are commons to the other wires,
If so they would then be connected together, see Jason2548 link.
No technical PMs.
The last thing you did is where you should start looking.
creativen
What do you mean common to other pins?
Where I should connect that green common wires?
Jason2548
http://www.nipponpulse.com/catalog/document/4b16d0783ef33_PF(C)_Unipolar_Wiring.pdf
Ok look at this one. It is for unipolar two phase motor.  I have two of this motors sitting in front of me and I looks to be the same wiring just different colors.  instead of green i have reds in the middle.
Jason2548
The Green wires are going to be Voltage supply and then the other four are the four seperate coils.
creativen
larryd
See Image below
No technical PMs.
creativen
So it means I need to use Darlington array like the shown image?
it there a way directly connect it to arduino pin?
larryd
You can use 4  TIP122 transistors or  4  N channel MOSFETs.
You need external components with these.
However, for your 50 ohm stepper, drivers like ULN2004 or ULN2803 are small packages and easy to work with especially on bread boards.
No technical PMs.
