Loading...
Pages: [1]   Go Down
Author Topic: MIDI problems with PWM audio generator  (Read 339 times)
Offline Offline
Newbie
View Profile
Hi..
I'm struggling with something - I'm working on an Arduino oscillator.. I'm using Adrian Freed's audio generator code (http://adrianfreed.com/content/arduino-sketch-high-frequency-precision-sine-wave-tone-sound-synthesis
I'm not sure if it's because the interrupt is hogging resources, but I can't seem to receive any MIDI data at the serial port..
I'm using the MIDI library - i've tried parsing MIDI.read in the main loop - and it doesn't work. I also tried it from within the interrupt, and even tried a counter that calls MIDI.read every 'x' number of cycles so the serial buffer has time to fill up, but it's no good.
Does anyone know a way to fix it? Perhaps I need to set up a separate interrupt just for MIDI - I know the audio code uses TIMER2, but I don't know how to make another interrupt..
Any thoughts would be greatly appreciated, I'm pulling my hair out!
Carl
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
While unfortunately I don't know what is wrong, this might help you from barking up the wrong tree:-
Quote
No the MIDI has it's own interrupt that is from the UART and nothing to do with timers.
It could be that the audio generator is spending too long in its Interrupt Service Routine to allow enough time for the serial to catch everything. Are you getting some data back through the MIDI channel even if it is incomplete?
Logged
Offline Offline
Newbie
View Profile
I just tried disabling the interrupt and the MIDI works fine.. Guess I'll have to look at trimming back the interrupt code.. Unless there's a way to buffer the serial data from within the interrupt and check that?
Logged
Greenville, IL
Offline Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
View Profile
 Posting the code might help too.
Logged
Pages: [1]   Go Up
Print
Jump to:
