Topic: Where To Download Stdio.h ?? (Read 14944 times) previous topic - next topic
whitnasty1
Hello everybody,
   I am writing a program that needs to have the Stdio.h header file included in the program, and I have looked everywhere on the internet and have not been able to find where to download the Stdio.h file?
If anyone knows where I can download this file I would be most appreciative. Thanks very much for all of your help and time!
holmes4
What (on the Arduino) do you think that stdio will do for you.
Mark
whitnasty1
I'm using it to interface with an LTC2400 24-bit ADC.
I just asked where I could get it from...
#include <stdio.h>
#ifndef cbi
#define cbi(sfr, bit)     (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit)     (_SFR_BYTE(sfr) |= _BV(bit))
#endif
#define LTC_CS 2         // LTC2400 Chip Select Pin  on Portb 2
#define LTC_MISO  4      // LTC2400 SDO Select Pin  on Portb 4
#define LTC_SCK  5       // LTC2400 SCK Select Pin  on Portb 5
cbi(PORTB,LTC_SCK);      // LTC2400 SCK low
sbi (DDRB,LTC_CS);       // LTC2400 CS HIGH
cbi (DDRB,LTC_MISO);
sbi (DDRB,LTC_SCK);
Serial.begin(57600);
// init SPI Hardware
sbi(SPCR,MSTR) ; // SPI master mode
sbi(SPCR,SPR0) ; // SPI speed
sbi(SPCR,SPR1);  // SPI speed
sbi(SPCR,SPE);   //SPI enable
Serial.println("LTC2400 ADC Test");
float volt;
float v_ref=5.0;          // Reference Voltage, 5.0 Volt for LT1021 or 3.0 for LP2950-3
long int ltw = 0;         // ADC Data ling int
int cnt;                  // counter
byte b0;                  //
byte sig;                 // sign bit flag
char st1[20];             // float voltage text
cbi(PORTB,LTC_CS);             // LTC2400 CS Low
delayMicroseconds(1);
if (!(PINB & (1 << PB4))) {    // ADC Converter ready ?
   //    cli();
   ltw=0;
   sig=0;
   b0 = SPI_read();             // read 4 bytes adc raw data with SPI
   if ((b0 & 0x20) ==0) sig=1;  // is input negative ?
   b0 &=0x1F;                   // discard bit 25..31
   ltw |= b0;
   ltw <<= 8;
   b0 = SPI_read();
   ltw |= b0;
   ltw <<= 8;
   b0 = SPI_read();
   ltw |= b0;
   ltw <<= 8;
   b0 = SPI_read();
   ltw |= b0;
   sbi(PORTB,LTC_CS);           // LTC2400 CS Low
   delay(200);
   if (sig) ltw |= 0xf0000000;    // if input negative insert sign bit
   ltw=ltw/16;                    // scale result down , last 4 bits have no information
   volt = ltw * v_ref / 16777216; // max scale
   Serial.print(cnt++);
   Serial.print(";  ");
   printFloat(volt,6);           // print voltage as floating number
   Serial.println("  ");
sbi(PORTB,LTC_CS); // LTC2400 CS hi
delay(20);
byte SPI_read()
SPDR = 0;
while (!(SPSR & (1 << SPIF))) ; /* Wait for SPI shift out done */
return SPDR;
//  printFloat from  tim / Arduino: Playground
// printFloat prints out the float 'value' rounded to 'places' places
//after the decimal point
void printFloat(float value, int places) {
// this is used to cast digits
int digit;
float tens = 0.1;
int tenscount = 0;
int i;
float tempfloat = value;
// if value is negative, set tempfloat to the abs value
   // make sure we round properly. this could use pow from
//<math.h>, but doesn't seem worth the import
// if this rounding step isn't here, the value  54.321 prints as
// calculate rounding term d:   0.5/pow(10,places)
float d = 0.5;
if (value < 0)
   d *= -1.0;
// divide by ten for each decimal place
for (i = 0; i < places; i++)
   d/= 10.0;
// this small addition, combined with truncation will round our
tempfloat +=  d;
if (value < 0)
   tempfloat *= -1.0;
while ((tens * 10.0) <= tempfloat) {
   tens *= 10.0;
   tenscount += 1;
// write out the negative if needed
if (value < 0)
   Serial.print('-');
if (tenscount == 0)
   Serial.print(0, DEC);
for (i=0; i< tenscount; i++) {
   digit = (int) (tempfloat/tens);
   Serial.print(digit, DEC);
   tempfloat = tempfloat - ((float)digit * tens);
   tens /= 10.0;
// if no places after decimal, stop now and return
if (places <= 0)
   return;
// otherwise, write the point and continue on
Serial.print(',');
for (i = 0; i < places; i++) {
   tempfloat *= 10.0;
   digit = (int) tempfloat;
   Serial.print(digit,DEC);
   // once written, subtract off that digit
   tempfloat = tempfloat - (float) digit;
whitnasty1
If someone could just point me in the correct direction I would greatly appreciate the gesture.
PaulS
Quote
That does not answer the question. The stdio header file defines things related to standard I/O. The Arduino does not have a standard input device or a standard output device. So, what is stdio going to do for you?
Not that it really matters, since stdio.h comes with the C++ compiler. You don't need to go trying to find one.
holmes4
Just remove the include of stdio from your file as your not using anything from it.
stdio is there to deal with files on systems such as linux, unix and windows.
Mark
michinyon
stdio.h   is going to be different for each actual implementation of C or C++.    So just finding a file
for it from somewhere,  is probably not going to work for you.
PeterH
It's included in the AVR libc runtime library contained in the Arduino installation. You don't need to obtain it from anywhere. You need to be aware, though, that the functions declared in this library dealing with I/O streams won't work unless you have done some work behind the scenes to associate these streams with some I/O mechanism on your Arduino.
whitnasty1
I think I have it figured out now... I was getting a compile error regarding PB4 in my loop(), saying that it wasn't declared in the scope....
#ifndef cbi
#endif
#ifndef sbi
#endif
byte PB4;
sbi (DDRB,LTC_SCK);
float volt;
int cnt;                  // counter
byte b0;                  //
  ///byte PB4;
   //    cli();
   ltw=0;
   sig=0;
   ltw |= b0;
   ltw <<= 8;
   b0 = SPI_read();
   ltw |= b0;
   ltw <<= 8;
   b0 = SPI_read();
   ltw |= b0;
   ltw <<= 8;
   b0 = SPI_read();
   ltw |= b0;
   delay(200);
   Serial.print(";  ");
delay(20);
byte SPI_read()
SPDR = 0;
return SPDR;
int digit;
float tens = 0.1;
int tenscount = 0;
int i;
float d = 0.5;
if (value < 0)
   d *= -1.0;
   d/= 10.0;
tempfloat +=  d;
if (value < 0)
   tempfloat *= -1.0;
   tens *= 10.0;
   tenscount += 1;
if (value < 0)
   Serial.print('-');
if (tenscount == 0)
   tens /= 10.0;
if (places <= 0)
   return;
Serial.print(',');
   tempfloat *= 10.0;
I think if I declare it as a byte at the beginning of the sketch it should work, I'll have to wait until I get home to get the hardware and test it though.
