Topic: I2C bus on multiple BH1750 sensor (Read 9805 times) previous topic - next topic
yaser
Hi all,
I'm currently working on BH1750, http://www.dfrobot.com/wiki/index.php/Light_Sensor_(SKU:SEN0097)
I don't understand, how to using it in multiple I2C address/sensor.
Please give me some input on code reference to changes the address?
Here the current code I used for 1 sensor (from DFrobot):
Code: [Select]
#include <Wire.h> //BH1750 IIC Mode
#include <math.h>
int BH1750address = 0x23; //setting i2c address
byte buff[2];
 Wire.begin();
 Serial.begin(57600);//init Serail band rate
 int i;
 uint16_t val=0;
 BH1750_Init(BH1750address);
 delay(200);
 if(2==BH1750_Read(BH1750address))
   val=((buff[0]<<8)|buff[1])/1.2;
   Serial.print(val,DEC);
   Serial.println("[lx]");
 delay(150);
int BH1750_Read(int address) //
 int i=0;
 Wire.beginTransmission(address);
 Wire.requestFrom(address, 2);
 while(Wire.available()) //
   buff[i] = Wire.receive();  // receive one byte
   i++;
 Wire.endTransmission();
 return i;
void BH1750_Init(int address)
 Wire.send(0x10);//1lx reolution 120ms
Thanks before
afremont
With the ADDR pin grounded, the address is as you have it 0x23, the other address is 0x5C (a simple bit inversion).
Experience, it's what you get when you were expecting something else.
yaser
Hi afremont,
Thanks for respond, still can't works. I think the problem is in my code.
Sorry for my poor writing skills, but I will try to make it work.
This my present code:
Code: [Select]
#include <math.h>
int Sen1 = 0x23; //setting i2c address
int Sen2 = 0x5C;
byte buff[2];
  Wire.begin();
  int i;
  uint16_t val1=0, val2=0;
  BH1750_Init(Sen1);
  delay(200);
  if(2==BH1750_Read(Sen1))
    val1=((buff[0]<<8)|buff[1])/1.2;
    Serial.print(val1,DEC);
  delay(200);
  if(2==BH1750_Read(Sen2))
    val2=((buff[0]<<8)|buff[1])/1.2;
    Serial.print(val2,DEC);
  delay(200);
  int i=0;
    buff[i] = Wire.read();  // receive one byte
    i++;
  return i;
  Wire.write(0x10);//1lx reolution 120ms
Btw, I'm curious how to make that inversion?
ADDR = 'H'  ( ADDR ? 0.7VCC ) ? "1011100" --> 5C
ADDR = 'L'  ( ADDR ? 0.3VCC ) ? "0100011" --> 23
Isn't?
Grumpy_Mike
Quote
By connecting pin 2 to either ground or leaving it unconnected.
yaser
#4
Feb 11, 2013, 12:50 am Last Edit: Feb 11, 2013, 12:53 am by yaser Reason: 1
Thanks Grumpy_Mike,
I run the code above and nothing happen in serial monitor. I used this connection:
Vcc - 5v
Gnd - Gnd
SCL - 10K - Pin 5
SDA - 10K - Pin 4
ADD - 100 ohm - Gnd
#include <math.h>
int Sen2 = 0x5C;
byte buff[2];
 Wire.begin();
 Serial.begin(57600);//init Serial baud rate
 BH1750_Init(Sen1);
 delay(200);
   val1=((buff[0]<<8 )|buff[1])/1.2;
 delay(200);
 BH1750_Init(Sen2);
 delay(200);
   val2=((buff[0]<<8 )|buff[1])/1.2;
 delay(200);
 int i=0;
   buff = Wire.read();  // receive one byte
   i++;
 return i;
 Wire.write(0x10);//1 lux resolution 120ms
ken_chuang
I am using the following connection for Arduino Mega 2560
    VCC       ------        5V
    GND       ------        GND
    SCL       ------        SCL
    SDA       ------        SDA
    ADD       ------        GND
Most of the sample codes from chinese websites worked for me with Arduino Mega 2560 with code change to "wire.read" and "wire.write"
yaser
Hi Ken,
Thanks, I will check that..
Grumpy_Mike
As that address pin can be left unconnected there must be an internal pull up, so don' connect the pin through a 100R but direct.
michinyon
Are you getting any response at all ?    Get the "I2C scanner" program,  which will identify if the
device is responding to any I2C communication.
Mohannad_Rawashdeh
this library support multiple device address
Library download on Github :
https://github.com/Genotronex/BH1750FVI_Master
http://www.instructables.com/id/BH1750-Digital-Light-Sensor/
no thing is impossible except that the state of your mind keeps it so...
