Loading...
Pages: [1]   Go Down
Author Topic: charging sla 6v 4ah by 7v 500ma charger.  (Read 429 times)
isabela, philippines.
Offline Offline
Jr. Member
if you dont go, you will never know.
View Profile
can i charge panasonic sla 6v battery (Panasonic LC-RB064P) by my 7.5v 500mA ac to dc adaptor?
take note that the battery is 4ah and my charger has only 500mA....
Logged
jaylisto
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
This isn't the "answer every question that pops into your head" forum. If you have an Arduino question, this is the place. If you don't, it isn't.
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
C/8 rate is a little high - I'd reduce the current from the charger.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Jr. Member
View Profile
Quote
what do you mean by c/8?..
though the adaptor has a selection from 3, 6, 7.5, 9, and 12v....
what im trying to realize is. the 500mA of the charger and the battery has 4Ah, i thought charger must be higher 4ah..
im a noob and drumb from this kind of basic knowledge. since i dont work with batteries.
Logged
jaylisto
Global Moderator
UK
Online Online
Brattain Member
View Profile
Stop cross-posting - it wastes time.
Last warning.
4Ah is the capacity of the battery, it has little to do with the charging.
C / 8 is a charge rate.
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
OP, Paul is right, you should look up simple questions like this on the web. Also, learn about
different battery chemistrys while you're at it.
AWOL is right - ALWAYS pay heed to the moderators. If you cross them, you're toast. They
never forget, ;-).
C is the capacity of the battery, 4.5 Ah for your case. C/8 is the charging rate = 4.5 Ah/8, in
Amps. AWOL is saying that's a little high, and to reduce it.
"though the adaptor has a selection from 3, 6, 7.5, 9, and 12v...." - this is the voltage out of
your wallwart, not the amperage.
"the 500mA of the charger and the battery has 4Ah, i thought charger must be higher 4ah.." - No,
you use a charging current somewhat less than C, and apply it for some hours to charge the battery.
For example, if you use C/10, or 400 mA, then you would apply this for 11 hours, and it would
move 0.4A * 11 hr = 4.4 Ah of energy into the battery.
But this is all trivial stuff, which you could find on 500 sites by doing a web search.
The one thing the web may not tell you is that a 6V, 300 or 400 mA wallwart will probably charge
your 6V, 4.5 Ah SLA battery fine overnight, without any additional circuitry. This is how many
of the older toys did it, when they still used SLA batteries. For other types, like Nicad, NiMH,
and Li, you need special chargers, and should not use a wallwart directly.
Li batteries, especially, don't like mistreatment,
http://www.businessweek.com/articles/2013-01-18/why-the-batteries-in-boeings-787-are-burning
Logged
Kitchen-Sink Arduino-compatible boards
Pages: [1]   Go Up
Print
Jump to:
