Topic: charging sla 6v 4ah by 7v 500ma charger. (Read 3645 times) previous topic - next topic
jaylisto
can i charge panasonic sla 6v battery (Panasonic LC-RB064P) by my 7.5v 500mA ac to dc adaptor?
take note that the battery is 4ah and my charger has only 500mA....
PaulS
This isn't the "answer every question that pops into your head" forum. If you have an Arduino question, this is the place. If you don't, it isn't.
AWOL
C/8 rate is a little high - I'd reduce the current from the charger.
jaylisto
what do you mean by c/8?..
though the adaptor has a selection from 3, 6, 7.5, 9, and 12v....
what im trying to realize is. the 500mA of the charger and the battery has 4Ah, i thought charger must be higher 4ah..
im a noob and drumb from this kind of basic knowledge. since i dont work with batteries.
AWOL
Stop cross-posting - it wastes time.
Last warning.
4Ah is the capacity of the battery, it has little to do with the charging.
C / 8 is a charge rate.
oric_dan
OP, Paul is right, you should look up simple questions like this on the web. Also, learn about
different battery chemistrys while you're at it.
AWOL is right - ALWAYS pay heed to the moderators. If you cross them, you're toast. They
never forget, ;-).
C is the capacity of the battery, 4.5 Ah for your case. C/8 is the charging rate = 4.5 Ah/8, in
Amps. AWOL is saying that's a little high, and to reduce it.
"though the adaptor has a selection from 3, 6, 7.5, 9, and 12v...." - this is the voltage out of
your wallwart, not the amperage.
"the 500mA of the charger and the battery has 4Ah, i thought charger must be higher 4ah.." - No,
you use a charging current somewhat less than C, and apply it for some hours to charge the battery.
For example, if you use C/10, or 400 mA, then you would apply this for 11 hours, and it would
move 0.4A * 11 hr = 4.4 Ah of energy into the battery.
But this is all trivial stuff, which you could find on 500 sites by doing a web search.
The one thing the web may not tell you is that a 6V, 300 or 400 mA wallwart will probably charge
your 6V, 4.5 Ah SLA battery fine overnight, without any additional circuitry. This is how many
of the older toys did it, when they still used SLA batteries. For other types, like Nicad, NiMH,
and Li, you need special chargers, and should not use a wallwart directly.
Li batteries, especially, don't like mistreatment,
http://www.businessweek.com/articles/2013-01-18/why-the-batteries-in-boeings-787-are-burning
