Topic: IDE update screwed up my libraries (Read 1 time) previous topic - next topic
keaton
this is the exact reason i did not want to update my IDE.... after updating form 0.22 to 1.0.3 my CAN bus library quit working and errored out, I'm getting sick of racking my brain on this...
My original Canbus.cpp had this
Code: [Select]
#include "WConstants.h" //for old IDE
#include <stdio.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include "pins_arduino.h"
#include <inttypes.h>
#include "global.h"
#include "mcp2515.h"
#include "defaults.h"
#include "Canbus.h"
Error:
Quote
Canbus.cpp:6:38: error: WConstants.h: No such file or directory
after searching online I was told I needed this
Code: [Select]
//#include "WConstants.h" //for old IDE
#include "Arduino.h" //added for arduino 1.0+
#include <stdio.h>
#include <avr/io.h>
#include "global.h"
#include "Canbus.h"
#include <FILENAME.h> // add this for 1.0+ IDE
the next error pointed to my mcp2515.c
Code: [Select]
mcp2515.c:31:34: error: WConstants.h: No such file or directory
original code
Code: [Select]
#include <avr/io.h>
#include "WConstants.h" //old IDE
#include "global.h"
#include "mcp2515_defs.h"
changed to
Code: [Select]
#include <avr/io.h>
//#include "WConstants.h" //old IDE
#include "global.h"
everything being called in my .pde
Code: [Select]
//#include <NewSoftSerial.h>
#include <SoftwareSerial.h>
#include <Canbus.h>  // my CAN needed.
#include <Wire.h>
//NewSoftSerial mDVRRec(6, 7);  //serial for unit that records ***correct
SoftwareSerial mDVRRec(6, 7);
everything use to work before I upgraded to 1.0.3
I'm using the SPI bus & SCK is connected to pin13 (LED pin) and I can see it blipping on and off so something is trying, but i'm not getting any data on my LCD or Serial port even though the print commands are there
pYro_65
This is a bad choice for a file name if it does exist ( not part of Arduino ) :
Quote
The IDE appears to give warnings/errors on some missing headers but not all, verify the file names are correct. Read the documentation for the new libraries you are using/switching too. Also search the forum for other people with upgrade problems using those libs, good chance by now someone else has encountered the error ( if it is not specific to your code ).
Forum Mod anyone?
https://arduino.land/Moduino/
keaton
Quote
That's weird, now it complies with both of those commented out.... so i took it out the my car and fired it up still not working...
checked the data lines with an Oscope.. and they are wiggling..
here is the function code where i'm getting the data
Code: [Select]
void Get_CAN_Data(long *RPM, int *SPEED, int *EngineTemp, int *TPS, int *Drivers_Torque_Demand, int *Actual_Torque, int *Engine_Torque_Reference,int *Timing_Advance, int *Caculated_Load, int *Maf)
        //CAN Bus data collection
        if(Canbus.ecu_req(ENGINE_RPM,buffer) == 1){
          *RPM=atoi(buffer); //* changes what is stored
        digitalWrite(A0, HIGH);// turns off LED
        if(Canbus.ecu_req(VEHICLE_SPEED,buffer) == 1){
            *SPEED=atoi(buffer); //* changes what is stored
        if(Canbus.ecu_req(ENGINE_COOLANT_TEMP,buffer) == 1){
            *EngineTemp=atoi(buffer); //* changes what is stored
        if(Canbus.ecu_req(THROTTLE,buffer) == 1){
            *TPS=atoi(buffer); //* changes what is stored
        if(Canbus.ecu_req(DRIVERS_TORQUE_DEMAND,buffer) == 1){
            *Drivers_Torque_Demand=atoi(buffer); //* changes what is stored
         if(Canbus.ecu_req(ACTUAL_TORQUE,buffer) == 1){
             *Actual_Torque=atoi(buffer); //* changes what is stored
        if(Canbus.ecu_req(ENGINE_TORQUE_REFERENCE,buffer) == 1){
            *Engine_Torque_Reference=atoi(buffer); //* changes what is stored
        if(Canbus.ecu_req(TIMING_ADVANCE,buffer) == 1){
            *Timing_Advance=atoi(buffer); //* changes what is stored
        if(Canbus.ecu_req(CALCULATED_ENGINE_LOAD,buffer) == 1){
            *Caculated_Load=atoi(buffer);
        if(Canbus.ecu_req(MAF_SENSOR,buffer) == 1){
            *Maf=atoi(buffer);
        digitalWrite(A0, LOW);// turns on LED
main
Code: [Select]
void loop (){
if(CAN_Connect == true)
      Get_CAN_Data( &RPM,  &SPEED,  &EngineTemp,  &TPS,  &Drivers_Torque_Demand,  &Actual_Torque,   &Engine_Torque_Reference, &Timing_Advance, &Caculated_Load, &Maf);// "&" passes the address of input to the function
      //Serial_CAN_Print(RPM,  SPEED, EngineTemp, TPS,  Drivers_Torque_Demand,  Actual_Torque, Engine_Torque_Reference, Timing_Advance, Caculated_Load, Maf); // doesnt need "&" not editing data **** comment out this line later ***
     Wire.beginTransmission(lcd_addr);Wire.write(0xFE); Wire.write(0x45); Wire.write(0x00+4);Wire.write(itoa(RPM,buffer2,10)); Wire.endTransmission();
      /*Wire.beginTransmission(lcd_addr);Wire.write(0xFE); Wire.write(0x45); Wire.write(0x00+14);Wire.write(itoa(TPS,buffer2,10)); Wire.endTransmission();
      Wire.beginTransmission(lcd_addr);Wire.write(0xFE); Wire.write(0x45); Wire.write(0x40+12);Wire.write(itoa(Engine_Torque_Reference,buffer2,10)); Wire.endTransmission();
      delay(100);*/
pYro_65
If data is being sent wrong, the devices may be unresponsive. Maybe the can lib or whatever handles the transmission has extra initialisation steps, or maybe endianness needs switching.
By wiggling do you mean transmitting digital bits, or is it just noise on a voltage ( no discernible voltage changes that would register a 0, or 1 )
Forum Mod anyone?
keaton
the library i made use to work as is on version 0.22... on version 1.0.3 the same libraries, that use to work, don't work anymore..
by wiggling I mean changing state from high to low, low to high...
nickgammon
Quote
Code: [Select]
void loop (){
      delay(100);*/
May I suggest more conventional formatting? This is almost impossible to read.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
keaton
Quote
Code: [Select]
void loop (){
      delay(100);*/
i can change it for the sake of making it more readable for you (and other), but the way it is laid out is easier to read for me as it follows strings of data that make up 1 line...
i2c lines are like:  0x50, 0xFE,0x45,0x00,"data for that line", end... [address][CMD][CMD][parameter][data][end]
I think my problem may be my car... its a CAN car but it may be a special VW protocol where a 0x7DF address might not be the correct address for the ECU. This car has 21 nodes on the CAN bus..
Tomorrow i will test what i have on another CAN car/truck
