Pages: [1] 2   Go Down
Author Topic: 100 LED Matrix Display  (Read 1148 times)
I am trying to figure out what to do with 100 5mm LED's that have a common anode. I thought about making a large dot matrix display that would "hang" on the back of my laptop monitor. It would use some sort of acrylic sheet that would go over the LED's and then have some type of clip to hang on the top of my screen on my laptop. This way I can display letters and words and patterns on the back of my laptop while I DJ.
Right now all I have are the LED's. What would I need to power them and also control them? I am good with software and programming, hardware is where I lack knowledge. I Also do not know how I would power it and I have no issue using an external power supply. Any help in making this project would be appreciated. Thank you.
Manchester (England England)
Online Online
Solder is electric glue
Sorry this does not make sense as a simple LED is not common anything.
Are these RGB LEDs?
In which case you need 300 drivers.
They are RGB LED's so yes. What would you recommend as a driver for them and also what would control the driver?
Eugene, Oregon
There are many ways you can control them, The best way is the way that you like best. You could control them with shift registers, LED drivers, transistors, you could multiplex them (and probably will), you could charlieplex them (another viable option), you could even control them serially with individual ICs on each LED.
Since they are RBG leds, you will probably want to do PWM, or you will be limited to a handful of colors.
The LEDs on the back of the computer display thing is a fun looking project, LadyAda has a tutorial about how to do that. There are tvs that come with that feature, i think its called ambilight.
Well I don't know how to easily do a couple of those options but what would probably be the most compact solution that still includes PWM? I thought of shift registers but I have never used them before, would i use them to control the columns and then by just changing the ground on a single row, i could control an individual led; then I would just use multiplexing to light up multiple columns? Wouldn't I need a bunch considering that I would have RGB LEDS, so 3 shift registers per column or am I over thinking this?
Edit* I was taking a look online at what other people did for making a RGB Led matrix and I found this: http://www.youtube.com/watch?feature=player_embedded&v=5bdozQAv9Yo
Would that be something that could work? I can get a couple Rainbowduinos if I need to, but would that be an easy method to setup?
« Last Edit: January 23, 2013, 12:57:17 pm by hey101 » Logged
Boston area, metrowest
Check out WS2803, can control 6 RGB LEDs each with PWM. (18 IO lines)
You could have perhaps a string of 4 of these controlling 24 RGB LEDs, and multiplex them across 5 rows of LEDs.
Leave each row on for 8mS for 25 Hz refresh rate.
Shift in data stored in an array using SPI.transfer( )s for fast updates.
Available on e-bay from a seller in Niagara Falls.
Wouldn't I only need two of those if I was going to make a 10x10 RGB Led Matrix since I can just use them for the columns and then use multiplexing to control the rest?
Online Online
You can't charleyplexing RGB LEDs, try drawing the circuit and you find it won't work due to the three common connections on each LED.
You could try it with 2 drivers multiplexed across 10 rows.
On time per row will be cut in half to achieve the same 25Hz refresh rate.
Technically If i used two of them and made each control 5 rows would I be able to have two rows lit up simultaneously so I could have a faster refresh rate theoretically?
Also what you guys recommend for powering the whole thing? I assume I will be using an arduino then connect that to the two WS2803 which will power the LED's
What would you recommend for the housing that will hold the leds and such? It will have an acrylic sheet that is the size of my laptop screen which is 14.5in x 9in.
« Last Edit: January 23, 2013, 05:17:24 pm by hey101 » Logged
Eugene, Oregon
Sure you can. The issue is really that there are 3 different forward voltages (blue and green are very close), and that means you you need 3 different resistor sizes if you are sending the same voltage. It means if you try to send 20ma to the red, you wont be able to send 20ma to the blue or green, and or if you try to send 20ma to the blue, you will send way too man ma to the red.
I have many such RGB LEDs charlieplexed right now. They are in sets of 12 LED, that could be laid out in a long row (line), or in 16 columns like a cube, or a variety matrix configurations.
Most if not all the LEDs ive charlieplexed were common cathode, not common anode, and im unsure if it works the same with common anode, but it seems like it should.
I have been meaning to make a schematic for the cube with 64 charlieplexed RGB LEDs, but I havnt yet. I can tell you that the design uses 16 spires of 4 RGB LEDs, and each spire is controlled by 4 lines. Each spire is 12 LEDs controlled by 4 pins, and the 16 spires (64 RGB LED, or 192 LEDs) are actually controlled by 16 pins.
You can't do that - the multiplexing comes from using a PNP transistor/row to drive those anodes with the WS2803's drive the cathodes.
If you want more rows on at one time, you need more groups with more WS2803s.
This is what I was picturing.
What do you guys recommend for placing the leds on? I have a large sheet of perf board but the holes are to far apart so the led can't sit flush on the board.
Online Online
You either bend the wires and get it as close to flush as possible or you make your own PCB. Or you use the other side of the board and use surface mount LEDs.
« Last Edit: January 30, 2013, 05:43:42 am by Grumpy_Mike » Logged
No you can do this. It is possible with AS1119 or AS1130 LED driver (thought they are crossplexing which is an minor extension to charlieplexing it seems):
https://www.youtube.com/watch?v=saonKr4YzI0
around 1:32 they put on a a 5x6 RGB matrix
www.ams.com/AS1130
or here:
http://www.digikey.com/product-detail/en/AS1130-BSST/AS1130-BSSTCT-ND/3028666
Pages: [1] 2   Go Up
