Topic: tinyFAT - UTFT_linyFAT libraries (Read 972 times) previous topic - next topic
SteveHi
Hi All,
I am having difficulties getting my SD card reader to work. I am not sure if the libraries are being recognized. The tinyFAT & UTFT_tinyFAT libraries are installed in the Library folder with all the others, and the example sketches compile just fine.
The reason why I am questioning if they are being recognized is because the name of the library does not highlight in orange when being defined. They remain black after the #include<>.
Take it easy on me if this is a dumb question I'm still pretty new to all of this.
Thanks for any direction!
ralphnev
if its being compiled - it is recognized
otherwise you would have a zillion compiler errors ...
have you shut down & reloaded recently ? that sometimes clears the syntax highlighting (the coloured bits ...)
SteveHi
Thanks for the reply!
I have come to find out, or at least believe, it is a hardware issue. It seems the shield with the card reader has a bug, and the pins on the shield do not match up with the pins on the mega.
The fix is to pull a couple of resistors, and cross the wiring.
I just want to make sure this is not a software issue before I try this.
Docedison
Use 10K resistors, not jumpers. The Arduino is a 5 V device and the SD card 3V3, the resistors serve as an interface of sorts because they limit the current that can flow to safe levels.
Bob
--> WA7EMS <--
ghlawrence2000
#4
Jan 25, 2013, 01:49 am Last Edit: Jan 25, 2013, 03:34 pm by ghlawrence2000 Reason: 1
Hold your horses!!!!
Follow this thread before you grab your iron!!!
http://arduino.cc/forum/index.php/topic,138124.0.html
Regards,
Graham
UTFT_SdRaw now included in library manager!! ;) High speed image drawing from SD card to UTFT displays for Mega & DUE.
UTFT_GHL - a VASTLY upgraded version of UTFT_CTE. Coming soon to a TFT near you! 8) Shipping April 1 2016!
