Topic: Arduino Due libraries (official and 3rd party) (Read 252868 times) previous topic - next topic
cmaglie
if you successfully run a library with the Due board, please post here a link to the library and a brief description.
I'll update this post regularly to get a list of available libraries for the Due.
C.
Markus_L811
#1
Jan 23, 2013, 10:15 am Last Edit: Apr 02, 2013, 02:58 pm by Markus_L811 Reason: 1
First release of the RTC Library for the Arduino Due.
2 examples included.
I would call it final for the moment.
And on github: https://github.com/MarkusLange/Arduino-Due-RTC-Library
I hope the library is self explaining.
Markus
Update new library with unixtime and compilertime support
Update Version 1.2 now support for Date & Time in one operation for BKM.
And some changes all in the changelog
Update Version 1.3 now unixtime with timezone support with Example for it, for tevroc
Update Version 1.4 now support for geman timezone with Summertime.
Update Version 1.5 some changes in the Summertime Sketch, and updates at this point only on git
Update Version 1.6 added rtc_clock.timing to detect when the time was set in summer- or wintertime
(mostly helpfully for the german member)
Update Version 1.7 added rtc_clock.date_already_set() to proof if date is allready set, to prevent setting time again for Paul Stoffregen
Update Version 1.8 added rtc_clock.set_clock() to set __Time__,__Date__ in one line fixed bug in unixtime() and summertime() thanks to Paul Stoffregen for the hint
randomvibe
#2
Jan 26, 2013, 09:53 am Last Edit: Jun 14, 2013, 10:00 am by randomvibe Reason: 1
Eigen is a C++ library enabling Matlab and Octave-like matrix programming.  Eigen works very well with the Arduino Due.  As a Matlab user that appreciates minimalism, the Eigen library is written as plain header files. So no makefiles, no binary files, nothing to compile upfront, no headaches.
To make Eigen available for Arduino-IDE-1.5.2 on Windows 7, please follow these instructions and try my example in step-4: (applies to Due board only)
Step-1:
-> As of 4/16/2013, latest stable release is Eigen 3.1.3
-> Download attached ZIP file called "Eigen313.zip"
Step-2:
-> Copy ZIP file to this precise location in the Arduino IDE directory tree:
   C:\Programs\arduino-1.5.2\hardware\arduino\sam\libraries
Step-3:
-> Run virus scanner, just in case.
-> Unzip to directory in step-2; when done, you should see the following directory:
   C:\Programs\arduino-1.5.2\hardware\arduino\sam\libraries\Eigen313
Step-4:
-> Normally open Arduino-IDE as usual.
-> Run example code below demonstrating the Kalman gain equation using 6x6 matrices. Notice the clean and concise prose enabling programmer to "see" Kalman equations.
-> Also notice the ease in inputting matrices.
-> I wrote a function called print_mtxf to serially print matrices; it's included in the example below.
Good luck.
Code: [Select]
// Example By: RandomVibe
// Eigen Doc: http://eigen.tuxfamily.org/dox/
// Quick Reference: http://eigen.tuxfamily.org/dox/QuickRefPage.html
#include <Eigen313.h>     // Calls main Eigen matrix class library
#include <LU>             // Calls inverse, determinant, LU decomp., etc.
using namespace Eigen;    // Eigen related statement; simplifies syntax for declaration of matrices
void print_mtxf(const Eigen::MatrixXf& K);
   // DECLARE MATRICES
   MatrixXf Pp(6,6);   // Produces 6x6 float matrix class
   MatrixXf H(6,6);    // Note: without "using namespace Eigen", declaration would be: Eigen::MatrixXf H(6,6);
   MatrixXf R(6,6);
   MatrixXf X(6,6);
   MatrixXf K(6,6);
   MatrixXf Z(6,6);
   // INPUT MATRICES (so-called comma-initialize syntax)
   Pp << 0.3252,  0.3192,  1.0933, -0.0068, -1.0891, -1.4916,
        -0.7549,  0.3129,  1.1093,  1.5326,  0.0326, -0.7423,
         1.3703, -0.8649, -0.8637, -0.7697,  0.5525, -1.0616,
        -1.7115, -0.0301,  0.0774,  0.3714,  1.1006,  2.3505,
        -0.1022, -0.1649, -1.2141, -0.2256,  1.5442, -0.6156,
        -0.2414,  0.6277, -1.1135,  1.1174,  0.0859,  0.7481 ;
   H << 0.8147, 0.2785, 0.9572, 0.7922, 0.6787, 0.7060,
        0.9058, 0.5469, 0.4854, 0.9595, 0.7577, 0.0318,
        0.1270, 0.9575, 0.8003, 0.6557, 0.7431, 0.2769,
        0.9134, 0.9649, 0.1419, 0.0357, 0.3922, 0.0462,
        0.6324, 0.1576, 0.4218, 0.8491, 0.6555, 0.0971,
        0.0975, 0.9706, 0.9157, 0.9340, 0.1712, 0.8235;
   R << 0.3252,  0.3192,  1.0933, -0.0068, -1.0891, -1.4916,
       -0.2414,  0.6277, -1.1135,  1.1174,  0.0859,  0.7481;
   // Kalman Gain Example; Matlab form:  K = Pp * H' * inv(H * Pp * H' + R)
   X  = H * Pp * H.transpose() + R;
   K  = Pp * H.transpose() * X.inverse();
   // Print Result
    print_mtxf(K);      // Print Matrix Result (passed by reference)
// PRINT MATRIX (float type)
// By: randomvibe
void print_mtxf(const Eigen::MatrixXf& X)
   int i, j, nrow, ncol;
   nrow = X.rows();
   ncol = X.cols();
   Serial.print("nrow: "); Serial.println(nrow);
   Serial.print("ncol: "); Serial.println(ncol);
   for (i=0; i<nrow; i++)
       for (j=0; j<ncol; j++)
           Serial.print(X(i,j), 6);   // print 6 decimal places
           Serial.print(", ");
psgarcha92
the LCDBitmap Library runs flawlessly on the DUE
Located at
http://code.google.com/p/arduino-lcd-bitmap/
titous
ported basic function over for the adafruit stepper shield
the library can be downloaded here
Tom Carpenter
As mentioned in this thread:
http://arduino.cc/forum/index.php/topic,136495.0.html
My gLCD-Library for Nokia 6100 Displays fully supports the arduino due. This means that the Sparkfun Color LCD Sheild is compatible with the Due.
~Tom~
cowasaki
#6
Feb 11, 2013, 12:02 pm Last Edit: Feb 11, 2013, 02:09 pm by cowasaki Reason: 1
UTFT library thread:
http://arduino.cc/forum/index.php/topic,144198.0.html
SDfat library thread:
http://arduino.cc/forum/index.php/topic,135439.0.html
OneWire library thread:
http://arduino.cc/forum/index.php/topic,141030.0.html
AdaFruit RTC library thread:
http://arduino.cc/forum/index.php/topic,143515.0.html
stimmer
Due VGA Library: http://arduino.cc/forum/index.php/topic,150517.0.html
The VGA library lets you connect your Due to a monitor with an analog VGA input. Modes supported include 640x480 and 800x600 in monochrome and 320x240 in colour. Simple drawing functions for pixels, lines, triangles, rectangles, circles and ellipses are included. Full support for Arduino-style print and println functions too.
Schematic is extremely simple - just 3 resistors for monochrome and 10 resistors for colour.
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
josheeg
I am using the Eigen library and want to run it in the arduino due I have posted some of my codeblocks c++ code for my windows machine.
Eigen is a C++ template library for linear algebra: matrices, vectors, numerical solvers, and related algorithms.
http://eigen.tuxfamily.org/index.php?title=Main_Page
Code: [Select]
#include <iostream>
#include <Eigen/Dense>
#include <Eigen/LU>
using Eigen::MatrixXd;
using namespace std;
int main()
cout << "Hello Pattern matching Linear Discriminent Analisis!" << endl;
cout << "" << endl;
cout << "x data" << endl;
//data matrix x row col
MatrixXd x(4,2);
//cur
x(0,0) = 2.95;//g0
x(1,0) = 2.53;
x(2,0) = 3.57;
x(3,0) = 3.16;
//dia
x(0,1) = 6.63;//g0
x(1,1) = 7.79;
x(2,1) = 5.65;
x(3,1) = 5.47;
std::cout << x << std::endl;
cout << "End of x data" << endl;
cout << "" << endl;
cout << "x1 data" << endl;
MatrixXd x1(3,2);
x1(0,0) = 2.58;//g1
x1(1,0) = 2.16;
x1(2,0) = 3.27;
x1(0,1) = 4.46;//g1
x1(1,1) = 6.22;
x1(2,1) = 3.52;
std::cout << x1 << std::endl;
cout << "End of x1 data" << endl;
cout << "" << endl;
//group adv
cout << "x data adverage ui" << endl;
MatrixXd ui(1,2);//group/feature
ui(0,0)=(x(0,0) + x(1,0) + x(2,0) + x(3,0))/4;
ui(0,1)=(x(0,1) + x(1,1) + x(2,1) + x(3,1))/4;
std::cout << ui << std::endl;
cout << "" << endl;
cout << "x1 data adverage ui1" << endl;
MatrixXd ui1(1,2);//group/feature
ui1(0,0)=(x1(0,0) + x1(1,0) + x1(2,0))/3.0;
ui1(0,1)=(x1(0,1) + x1(1,1) + x1(2,1))/3.0;
std::cout << ui1 << std::endl;
cout << "" << endl;
cout << "x & x1 data adverage u" << endl;
MatrixXd u(1,2);//all group/feature
u(0,0)=(x(0,0) + x(1,0) + x(2,0) + x(3,0) + x1(0,0) + x1(1,0) + x1(2,0))/7.0;
u(0,1)=(x(0,1) + x(1,1) + x(2,1) + x(3,1) + x1(0,1) + x1(1,1) + x1(2,1))/7.0;
std::cout << u << std::endl;
cout << "" << endl;
cout << "mean corrected data xig - u" << endl;
MatrixXd ximinu(4,2);
//cur
ximinu(0,0) = x(0,0) - u(0,0);//f0
ximinu(1,0) = x(1,0) - u(0,0);
ximinu(2,0) = x(2,0) - u(0,0);
ximinu(3,0) = x(3,0) - u(0,0);
//dia
ximinu(0,1) = x(0,1) - u(0,1);//f1
ximinu(1,1) = x(1,1) - u(0,1);
ximinu(2,1) = x(2,1) - u(0,1);
ximinu(3,1) = x(3,1) - u(0,1);
std::cout << ximinu << std::endl;
cout << "" << endl;
cout << "mean corrected data xi1 - u" << endl;
MatrixXd ximinu1(3,2);
//cur
ximinu1(0,0) = x1(0,0) - u(0,0);
ximinu1(1,0) = x1(1,0) - u(0,0);
ximinu1(2,0) = x1(2,0) - u(0,0);
//dia
ximinu1(0,1) = x1(0,1) - u(0,1);//g1
ximinu1(1,1) = x1(1,1) - u(0,1);
ximinu1(2,1) = x1(2,1) - u(0,1);
std::cout << ximinu1 << std::endl;
cout << " " << endl;
cout << "Transpose matricies" << endl;
cout << "xi - u T" << endl;
MatrixXd ximinut(4,2);
ximinut= ximinu.transpose();
std::cout << ximinut<< std::endl;
cout << "xi1 - u T" << endl;
MatrixXd ximinu1t(3,2);
ximinu1t= ximinu1.transpose();
std::cout << ximinu1t << std::endl;
cout << "Covariance matrix of group ci" << endl;
MatrixXd ci(2,2);
ci = ( ximinut * ximinu ) /4.0;
std::cout << ci << std::endl;
cout << "" << endl;
cout << "Covariance matrix of group ci1" << endl;
MatrixXd ci1(2,2);
ci1 = ( ximinu1t * ximinu1 ) /3.0;
std::cout << ci1 << std::endl;
cout << "" << endl;
cout << "Pooled within group Covariance matrix c" << endl;
MatrixXd c(2,2);
c(0,0) = 4.0/7.0 * ci(0,0) + 3.0/7.0 * ci1(0,0);
c(1,0) = 4.0/7.0 * ci(1,0) + 3.0/7.0 * ci1(1,0);
c(0,1) = 4.0/7.0 * ci(0,1) + 3.0/7.0 * ci1(0,1);
c(1,1) = 4.0/7.0 * ci(1,1) + 3.0/7.0 * ci1(1,1);
std::cout << c << std::endl;
cout << "" << endl;
cout << "inverse of Pooled within group Covariance matrix cinverse" << endl;
MatrixXd cinverse(2,2);
cinverse=c.inverse();
std::cout << cinverse << std::endl;
cout << "" << endl;
cout << "Probability of a group" << endl;
cout << "x = 4/7 x1 = 3/7" << endl;
//create a vector of a probability...
cout << "" << endl;
//formula for calculatin likelyhood of data in a group...
//fi = uig cinverse xkt - 1/2uig cinverse uitg + ln probability
cout << "End of program!" << endl;
    return 0;
cmaglie
Library for Due and WiFly GSX Breakout from SparkFun
http://arduino.cc/forum/index.php/topic,151256.msg0.html
C.
olikraus
#12
Mar 02, 2013, 10:30 pm Last Edit: Mar 02, 2013, 10:40 pm by olikraus Reason: 1
The graphics LCD (ST7565, UC1701, KS0108, ...) and OLED  (SSD1306, ...) library "U8glib" includes support for Arduino Due.
http://code.google.com/p/u8glib/
AndyL
Roving Networks RN-XV library.
Basically this is the one from https://github.com/harlequin-tech/WiFlyHQ but modified to work with Arduino Due is at:
https://bitbucket.org/thiseldo/wiflyhqdue
Changes are to remove PSTR and PROGMEM use and to change to hardware serial instead of softserial.
Examples updated.
There may still be issues with this as not fully tested in all situations, but basic client and server actions seem to work.
Full credit to the original authors, Harlequin-tech for their library.
Thanks
Andy
LaMega
who knows the link of the IRremote.h for the Due
