Topic: Arduino Due libraries (official and 3rd party) (Read 246543 times) previous topic - next topic
delsauce
I created a simple external memory interface/static memory controller.  Because of some HW limitations, it's not a full bus interface but can be used for interfacing with parallel LCDs.
More info here:
http://arduino.cc/forum/index.php/topic,152644.0.html
ecopoesis
ported Adafruit's sensor framework and TSL2561 (luminosity sensor) lib to the Due:
https://github.com/ecopoesis/Adafruit_Sensor
https://github.com/ecopoesis/Adafruit_TSL2561
dewy721
#17
Mar 09, 2013, 01:09 am Last Edit: Mar 09, 2013, 06:46 am by dewy721 Reason: 1
The AccelStepper library works beautifully with the Due. (Using step/dir based driver board.)
Desc:
High performance Non-Blocking (or blocking if desired).
Stepper library written in C++
Developmental Assets:
Very well documented.
randomvibe
#18
Mar 09, 2013, 10:03 am Last Edit: Jun 14, 2013, 10:01 am by randomvibe Reason: 1
Library:  pwm01.h
Description:  A clean alternate approach for setting up unique PWM frequencies from within a sketch, for any or all PWM pins.  The trick is to utilize the two PWM clocks (CLKA & CLKB) provided by the SAM3X8E chip.
I wrote and enclosed a library (pwm01.h).  It includes 4 user functions to:  1) setup PWM resolution, 2) setup PWM pin, frequency & pick clock, 3) write duty cycle, and 4) stop PWM.  See example code for usage:
Code: [Select]
#include "C:\Programs\arduino-1.5.1r2\hardware\arduino\sam\libraries\Pwm01\pwm01.h"
   uint32_t  pwm_duty = 32767;
   uint32_t  pwm_freq1 = 2;
   uint32_t  pwm_freq2 = 5000;
   // Set PWM Resolution
   pwm_set_resolution(16);
   // Setup PWM Once (Up to two unique frequencies allowed
   pwm_setup( 6, pwm_freq1, 1);  // Pin 6 freq set to "pwm_freq1" on clock A
   pwm_setup( 7, pwm_freq2, 2);  // Pin 7 freq set to "pwm_freq2" on clock B
   pwm_setup( 8, pwm_freq2, 2);  // Pin 8 freq set to "pwm_freq2" on clock B
   pwm_setup( 9, pwm_freq2, 2);  // Pin 9 freq set to "pwm_freq2" on clock B
   // Write PWM Duty Cycle Anytime After PWM Setup
   pwm_write_duty( 6, pwm_duty );  // 50% duty cycle on Pin 6
   pwm_write_duty( 7, pwm_duty );  // 50% duty cycle on Pin 7
   pwm_write_duty( 8, pwm_duty );  // 50% duty cycle on Pin 8
   pwm_write_duty( 9, pwm_duty );  // 50% duty cycle on Pin 9
   delay(30000);  // 30sec Delay; PWM signal will still stream
   // Force PWM Stop On All Pins
   pwm_stop( 6 );
   pwm_stop( 7 );
   pwm_stop( 8 );
   pwm_stop( 9 );
The pwm01.h library and example code were tested in IDE 1.5.1r2.  Additional notes on this library:
- Applies to Arduino-Due board, PWM pins 6, 7, 8 & 9.
- Libary Does not operate on the TIO pins.
- Unique frequencies set via PWM Clock-A ("CLKA") and Clock-B ("CLKB")
 Therefore, up to two unique frequencies allowed.
- Set max duty cycle counts (pwm_max_duty_Ncount) equal to 255 per Arduino approach.
 This value is best SUITED for low frequency applications (2hz to 40,000hz) such as
 PWM motor drivers, 38khz infrared transmitters, etc.
- Future library versions will address high frequency applications.
- Arduino's "wiring_analog.c" function was very helpful in this effort.
pjrc
Encoder has been updated to support Arduino Due.
http://www.pjrc.com/teensy/td_libs_Encoder.html
billroy
Bitlash is confirmed up and running on the Due, thanks to patches submitted by a friendly user.
http://bitlash.net
Regards to all,
-br
LaMega
#21
Mar 20, 2013, 01:52 am Last Edit: Mar 20, 2013, 01:59 am by LaMega Reason: 1
ShiftOutMega.h
http://www.4shared.com/get/QSUfwzo4/ShifOutMega.html
DS1307.h
http://www.4shared.com/get/HIZiPup2/DS1307.html
ivanseidel
Hi!
As i like libraries, i have done one for Timers on the Arduino DUE.
You can check it out here: https://github.com/ivanseidel/DueTimer
All 6 timers are fully implemented, and ready to play with...
Arduino DueTimer | https://github.com/ivanseidel/DueTimer
Arduino Thread | https://github.com/ivanseidel/ArduinoThread
prphntm63
I made a (very basic) library to interface with the FTDI Vdrive2 module. Uses TX1/RX1 for communication with the Vdrive2 and TX0/RX0 to send the responses to the Serial Monitor.
https://github.com/prphntm63/VDRIVE2.git
Improvements welcome ;)
zachtos
I can confirm that the Xbee Library works on DUE.  I ported over my code and tested last night.
http://code.google.com/p/xbee-arduino/
IR Combat laser tag developer/inventor
SomeRandomGuy
Hi!
I have merged all the features of my timer library with his. This is a great timer library, and we would love feedback for any features that people would like to see.
pjrc
The Time library has been updated for compatibility with Arduino Due.
http://playground.arduino.cc/Code/Time
A Due-specific example was added, using Markus Lange's rtc_clock library to access the Due's on-chip RTC.
Kuya Marc
What on-chip RTC? I just built a DS1307 project for Arduino Mini; does the Arduino Due have an internal RTC so a chip like DS1307 is not needed?
I run Xubuntu Linux as my only computer operating system!
Windows does not run here; Only
pjrc
What on-chip RTC?
Due does have an on-chip RTC.  The way the reset signals are wired makes it less useful for many projects, but there is indeed a RTC on the chip.
For more info, please download the new version of the Time library and look at its TimeArduinoDue example.  You'll also need Markus's rtc_clock libary.  Again, see the comments in TimeArduinoDue for more info.
henrimontreal
Hi!
May I ask you how I can use your file? I cannot include any library from out side. Is there anyway to run within one file? I would like to use a timer and change the REG by Serial Monitor.
