Pages: [1] 2 3   Go Down
Author Topic: Arduino Due libraries (official and 3rd party)  (Read 19890 times)
Forum Administrator
Milano, Italy
if you successfully run a library with the Due board, please post here a link to the library and a brief description.
I'll update this post regularly to get a list of available libraries for the Due.
C.
Germany
First release of the RTC Library for the Arduino Due.
2 examples included.
I would call it final for the moment.
And on github: https://github.com/MarkusLange/Arduino-Due-RTC-Library
I hope the library is self explaining.
Markus
Update new library with unixtime and compilertime support
Update Version 1.2 now support for Date & Time in one operation for BKM.
And some changes all in the changelog
Update Version 1.3 now unixtime with timezone support with Example for it, for tevroc
Update Version 1.4 now support for geman timezone with Summertime.
Update Version 1.5 some changes in the Summertime Sketch, and updates at this point only on git
Update Version 1.6 added rtc_clock.timing to detect when the time was set in summer- or wintertime
(mostly helpfully for the german member)
Update Version 1.7 added rtc_clock.date_already_set() to proof if date is allready set, to prevent setting time again for Paul Stoffregen
Update Version 1.8 added rtc_clock.set_clock() to set __Time__,__Date__ in one line fixed bug in unixtime() and summertime() thanks to Paul Stoffregen for the hint
« Last Edit: April 02, 2013, 07:58:31 am by Markus_L811 » Logged
Good Vibes, Bad Vibes, Random Vibe
Eigen is a C++ library enabling Matlab and Octave-like matrix programming.  Eigen works very well with the Arduino Due.  As a Matlab user that appreciates minimalism, the Eigen library is written as plain header files. So no makefiles, no binary files, nothing to compile upfront, no 20th century nonsense.
Important development regarding Eigen3.  The Arduino/Eigen setup on Windows 7 seems to produce internal compiler errors when using matrices larger than 4x4. After struggling late at night with this, I found a solution.  To add Eigen to the Arduino IDE (1.5.1r2) for Due, follow these instructions and try my example in step-6: (applies to Windows 7)
Step-1:
-> As of 1/25/2013, latest stable release is Eigen 3.1.2
-> Download ZIP from: http://eigen.tuxfamily.org
Step-2:
-> Unzip in temporary location
-> Unzip will create folder containing several files and subfolders.
-> The subfolder "Eigen" is all that is needed.
Step-3:
-> Copy "Eigen" subfolder to this precise location in the Arduino IDE directory tree:
...\arduino-1.5.1r2\hardware\arduino\sam\libraries
Step-4:
-> Eigen is written in C++, so header files do not include the *.h extension.
-> The Arduino IDE expects a *.h extension for it to appear in Sketch/Import Library pull-down menu.
-> So download "Eigen312.h" from this thread and copy to this precise location:
...\arduino-1.5.1r2\hardware\arduino\sam\libraries\Eigen
-> Notice "Eigen312.h" goes in the Eigen subdirectory
-> Normally, all that is needed in "Eigen312.h" is a call to the main Eigen Core header as follows: #include <Core>
However, the Arduino and AVR libraries interfere with Eigen for matrices larger than 4x4; this results in internal compiler errors. So @rpavlik came up with a bunch of #define statements that prevents this, and are conveniently included in "Eigen312.h".
Step-5:
-> Again, make sure you download "Eigen312.h" and copy to the Eigen subdirectory!
Step-6:
-> Run example code below demonstrating the Kalman gain equation using 6x6 matrices. Not as clean as Matlab or Octave, but not too shabby.
-> I wrote a function called print_mtxf that serially prints matrices; it's included in the example below.
Good luck.
// Example By: RandomVibe
// Eigen Doc: http://eigen.tuxfamily.org/dox/
// Quick Reference: http://eigen.tuxfamily.org/dox/QuickRefPage.html
#include <Eigen312.h>     // Calls main Eigen3.1.2 matrix class library
#include <LU>             // Calls inverse, determinant, LU decomp., etc.
using namespace Eigen;    // Eigen related statement; simplifies syntax for declaration of matrices
void print_mtxf(const Eigen::MatrixXf& K);
    // DECLARE MATRICES
    MatrixXf Pp(6,6);   // Produces 6x6 float matrix class
    MatrixXf H(6,6);    // Note: without "using namespace Eigen", declaration would be: Eigen::MatrixXf H(6,6);
    MatrixXf R(6,6);
    MatrixXf X(6,6);
    MatrixXf K(6,6);
    MatrixXf Z(6,6);
    // INPUT MATRICES (so-called comma-initialize syntax)
    Pp << 0.3252,  0.3192,  1.0933, -0.0068, -1.0891, -1.4916,
         -0.7549,  0.3129,  1.1093,  1.5326,  0.0326, -0.7423,
          1.3703, -0.8649, -0.8637, -0.7697,  0.5525, -1.0616,
         -1.7115, -0.0301,  0.0774,  0.3714,  1.1006,  2.3505,
         -0.1022, -0.1649, -1.2141, -0.2256,  1.5442, -0.6156,
         -0.2414,  0.6277, -1.1135,  1.1174,  0.0859,  0.7481 ;
    H << 0.8147, 0.2785, 0.9572, 0.7922, 0.6787, 0.7060,
         0.9058, 0.5469, 0.4854, 0.9595, 0.7577, 0.0318,
         0.1270, 0.9575, 0.8003, 0.6557, 0.7431, 0.2769,
         0.9134, 0.9649, 0.1419, 0.0357, 0.3922, 0.0462,
         0.6324, 0.1576, 0.4218, 0.8491, 0.6555, 0.0971,
         0.0975, 0.9706, 0.9157, 0.9340, 0.1712, 0.8235;
    R << 0.3252,  0.3192,  1.0933, -0.0068, -1.0891, -1.4916,
        -0.2414,  0.6277, -1.1135,  1.1174,  0.0859,  0.7481;
    // Kalman Gain Example; Matlab form:  K = Pp * H' * inv(H * Pp * H' + R)
    X  = H * Pp * H.transpose() + R;
    K  = Pp * H.transpose() * X.inverse();
    // Print Result
     print_mtxf(K);      // Print Matrix Result (passed by reference)
// PRINT MATRIX (float type)
void print_mtxf(const Eigen::MatrixXf& X)
    int i, j, nrow, ncol;
    nrow = X.rows();
    ncol = X.cols();
    Serial.print("nrow: "); Serial.println(nrow);
    Serial.print("ncol: "); Serial.println(ncol);
    Serial.println();
    for (i=0; i<nrow; i++)
        for (j=0; j<ncol; j++)
            Serial.print(X(i,j), 6);   // print 6 decimal places
            Serial.print(", ");
        Serial.println();
    Serial.println();
« Last Edit: March 09, 2013, 04:08:23 am by randomvibe » Logged
the LCDBitmap Library runs flawlessly on the DUE
Located at
http://code.google.com/p/arduino-lcd-bitmap/
ported basic function over for the adafruit stepper shield
the library can be downloaded here
Leeds, UK
Once the magic blue smoke is released, it won't go back in!
As mentioned in this thread:
http://arduino.cc/forum/index.php/topic,136495.0.html
My gLCD-Library for Nokia 6100 Displays fully supports the arduino due. This means that the Sparkfun Color LCD Sheild is compatible with the Due.
~Tom~
UK
UTFT library thread:
http://arduino.cc/forum/index.php/topic,144198.0.html
SDfat library thread:
http://arduino.cc/forum/index.php/topic,135439.0.html
OneWire library thread:
http://arduino.cc/forum/index.php/topic,141030.0.html
AdaFruit RTC library thread:
http://arduino.cc/forum/index.php/topic,143515.0.html
« Last Edit: February 11, 2013, 08:09:22 am by cowasaki » Logged
Due VGA Library: http://arduino.cc/forum/index.php/topic,150517.0.html
The VGA library lets you connect your Due to a monitor with an analog VGA input. Modes supported include 640x480 and 800x600 in monochrome and 320x240 in colour. Simple drawing functions for pixels, lines, triangles, rectangles, circles and ellipses are included. Full support for Arduino-style print and println functions too.
Schematic is extremely simple - just 3 resistors for monochrome and 10 resistors for colour.
Arduino rocks but a Arduno bot can roll!
I am using the Eigen library and want to run it in the arduino due I have posted some of my codeblocks c++ code for my windows machine.
Eigen is a C++ template library for linear algebra: matrices, vectors, numerical solvers, and related algorithms.
http://eigen.tuxfamily.org/index.php?title=Main_Page
#include <iostream>
#include <Eigen/Dense>
#include <Eigen/LU>
using Eigen::MatrixXd;
using namespace std;
int main()
cout << "Hello Pattern matching Linear Discriminent Analisis!" << endl;
cout << "" << endl;
cout << "x data" << endl;
//data matrix x row col
MatrixXd x(4,2);
//cur
x(0,0) = 2.95;//g0
x(1,0) = 2.53;
x(2,0) = 3.57;
x(3,0) = 3.16;
//dia
x(0,1) = 6.63;//g0
x(1,1) = 7.79;
x(2,1) = 5.65;
x(3,1) = 5.47;
std::cout << x << std::endl;
cout << "End of x data" << endl;
cout << "" << endl;
cout << "x1 data" << endl;
MatrixXd x1(3,2);
x1(0,0) = 2.58;//g1
x1(1,0) = 2.16;
x1(2,0) = 3.27;
x1(0,1) = 4.46;//g1
x1(1,1) = 6.22;
x1(2,1) = 3.52;
std::cout << x1 << std::endl;
cout << "End of x1 data" << endl;
cout << "" << endl;
//group adv
cout << "x data adverage ui" << endl;
MatrixXd ui(1,2);//group/feature
ui(0,0)=(x(0,0) + x(1,0) + x(2,0) + x(3,0))/4;
ui(0,1)=(x(0,1) + x(1,1) + x(2,1) + x(3,1))/4;
std::cout << ui << std::endl;
cout << "" << endl;
cout << "x1 data adverage ui1" << endl;
MatrixXd ui1(1,2);//group/feature
ui1(0,0)=(x1(0,0) + x1(1,0) + x1(2,0))/3.0;
ui1(0,1)=(x1(0,1) + x1(1,1) + x1(2,1))/3.0;
std::cout << ui1 << std::endl;
cout << "" << endl;
cout << "x & x1 data adverage u" << endl;
MatrixXd u(1,2);//all group/feature
u(0,0)=(x(0,0) + x(1,0) + x(2,0) + x(3,0) + x1(0,0) + x1(1,0) + x1(2,0))/7.0;
u(0,1)=(x(0,1) + x(1,1) + x(2,1) + x(3,1) + x1(0,1) + x1(1,1) + x1(2,1))/7.0;
std::cout << u << std::endl;
cout << "" << endl;
cout << "mean corrected data xig - u" << endl;
MatrixXd ximinu(4,2);
//cur
ximinu(0,0) = x(0,0) - u(0,0);//f0
ximinu(1,0) = x(1,0) - u(0,0);
ximinu(2,0) = x(2,0) - u(0,0);
ximinu(3,0) = x(3,0) - u(0,0);
//dia
ximinu(0,1) = x(0,1) - u(0,1);//f1
ximinu(1,1) = x(1,1) - u(0,1);
ximinu(2,1) = x(2,1) - u(0,1);
ximinu(3,1) = x(3,1) - u(0,1);
std::cout << ximinu << std::endl;
cout << "" << endl;
cout << "mean corrected data xi1 - u" << endl;
MatrixXd ximinu1(3,2);
//cur
ximinu1(0,0) = x1(0,0) - u(0,0);
ximinu1(1,0) = x1(1,0) - u(0,0);
ximinu1(2,0) = x1(2,0) - u(0,0);
//dia
ximinu1(0,1) = x1(0,1) - u(0,1);//g1
ximinu1(1,1) = x1(1,1) - u(0,1);
ximinu1(2,1) = x1(2,1) - u(0,1);
std::cout << ximinu1 << std::endl;
cout << " " << endl;
cout << "Transpose matricies" << endl;
cout << "xi - u T" << endl;
MatrixXd ximinut(4,2);
ximinut= ximinu.transpose();
std::cout << ximinut<< std::endl;
cout << "xi1 - u T" << endl;
MatrixXd ximinu1t(3,2);
ximinu1t= ximinu1.transpose();
std::cout << ximinu1t << std::endl;
cout << "Covariance matrix of group ci" << endl;
MatrixXd ci(2,2);
ci = ( ximinut * ximinu ) /4.0;
std::cout << ci << std::endl;
cout << "" << endl;
cout << "Covariance matrix of group ci1" << endl;
MatrixXd ci1(2,2);
ci1 = ( ximinu1t * ximinu1 ) /3.0;
std::cout << ci1 << std::endl;
cout << "" << endl;
cout << "Pooled within group Covariance matrix c" << endl;
MatrixXd c(2,2);
c(0,0) = 4.0/7.0 * ci(0,0) + 3.0/7.0 * ci1(0,0);
c(1,0) = 4.0/7.0 * ci(1,0) + 3.0/7.0 * ci1(1,0);
c(0,1) = 4.0/7.0 * ci(0,1) + 3.0/7.0 * ci1(0,1);
c(1,1) = 4.0/7.0 * ci(1,1) + 3.0/7.0 * ci1(1,1);
std::cout << c << std::endl;
cout << "" << endl;
cout << "inverse of Pooled within group Covariance matrix cinverse" << endl;
MatrixXd cinverse(2,2);
 cinverse=c.inverse();
std::cout << cinverse << std::endl;
cout << "" << endl;
cout << "Probability of a group" << endl;
cout << "x = 4/7 x1 = 3/7" << endl;
//create a vector of a probability...
cout << "" << endl;
//formula for calculatin likelyhood of data in a group...
//fi = uig cinverse xkt - 1/2uig cinverse uitg + ln probability
cout << "End of program!" << endl;
    return 0;
Library for WS2803 LED driver chips.
https://github.com/JamesRMartin/WS2803Due
Finland
DS1307 RTC library: http://arduino.cc/forum/index.php/topic,141233.msg1138572.html#msg1138572
Forum Administrator
Milano, Italy
Library for Due and WiFly GSX Breakout from SparkFun
http://arduino.cc/forum/index.php/topic,151256.msg0.html
C.
Germany
If you believe something is right, you won't see what's wrong (David Straker).
The graphics LCD (ST7565, UC1701, KS0108, ...) and OLED  (SSD1306, ...) library "U8glib" includes support for Arduino Due.
http://code.google.com/p/u8glib/
« Last Edit: March 02, 2013, 04:40:30 pm by olikraus » Logged
Arduino rocks - Yeah Baby!!
Roving Networks RN-XV library.
Basically this is the one from https://github.com/harlequin-tech/WiFlyHQ but modified to work with Arduino Due is at:
https://bitbucket.org/thiseldo/wiflyhqdue
Changes are to remove PSTR and PROGMEM use and to change to hardware serial instead of softserial.
Examples updated.
There may still be issues with this as not fully tested in all situations, but basic client and server actions seem to work.
Full credit to the original authors, Harlequin-tech for their library.
Thanks
Andy
who knows the link of the IRremote.h for the Due
Pages: [1] 2 3   Go Up
