Author Topic: Problem with Ethernet Library and Led  (Read 163 times)
Sorry for my bad English.
I Have a simple code with 1 function.
The function is:
void blinking((int time, int color){
// colore = 1 == Red
   // colore = 2 == Yellow
   // colore = 3 == Red and  Yellow
  pinMode(RED, OUTPUT);
  pinMode(YELLOW, OUTPUT);
   for (int i = 0; i <= quanto; i++) {
     switch (colore) {
        case 1:
          digitalWrite(RED, HIGH);
          digitalWrite(RED, LOW);
          break;
        case 2:
          digitalWrite(YELLOW, HIGH);
          digitalWrite(YELLOW, LOW);
          break;
        case 3:
          break;
        default:
          break;
          // if nothing else matches, do the default
          // default is optional
This function works without problems until I put in my code these lines and after I recall my function "blinking", it doesn't work, but the call before this code it works
while (FLAG == 0){
        if (Ethernet.begin(mac) == 0) {
            Serial.println("Failed to configure Ethernet using DHCP");
          FLAG=1;
Leds don't blink, why? can you help me? smiley-cry
« Last Edit: January 23, 2013, 09:56:24 am by daquili » Logged
East Anglia (UK)
May all of your blinks be without delay
Please can you post your whole program and put it in code tags (# above the smileys)
The problem may not actually be in your function at all but without seeing all of your code it is impossible to help.
There are notes in Italian.
#include <SPI.h>
#include <Ethernet.h>
#include <stdlib.h>
// Definisco il Mac Address della scheda che è stampata sullo shield ethernet
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0xAB, 0x50 };
String mac_string="90:A2:DA:0D:AB:50";
String buffer="";
String newbuffer="";
unsigned long nuovo_ip;
int indice1;
int indice2;
// Definisco ip del server su cui cercare info
IPAddress server;         // Default vuoto
IPAddress IPLocale;       // Default vuoto
const int Rosso = 13;           // LED che indica la connessione ethernet
const int Giallo = 12;           // LED che indica la connessione ethernet
int FLAG_Connessione=0;          // Indica se la connessione è avvenuta o meno
int FLAG_Server=0;               // indica che la connsessione con il server [lato dhcp] è avvenuta
EthernetClient client;
  // Inizializziamo la seriale
  // Inizializziamo i LED
  pinMode(Rosso, OUTPUT);
  pinMode(Giallo, OUTPUT);
  Serial.println("AVVIO PROGRAMMA");
  // Iniziamo la connessione DHCP
  Lampeggio(2,3);  // IT'S OK
  while (FLAG_Connessione == 0){
            // Connessione non riuscita
            Serial.println("Connessione = 0");
          // Connessione riuscita
          FLAG_Connessione=1;
          Serial.println("Connessione = 1");
  Lampeggio(2,2); // IT DOESN'T WORK
  // Stampo ip locale ottenuto
  IPLocale=Ethernet.localIP();
  Serial.println(IPLocale);
  server[0]=IPLocale[0];
  server[1]=IPLocale[1];
  server[2]=IPLocale[2];
  // Richiesta IP PRIVATO newip.php
  // Devo ciclare su tutti gli ip per cercare il server
  if (FLAG_Server == 0) {
      for (int i=42; i <= 254; i++){
          server[3]=i;
          Serial.println(server);
          if (client.connect(server, 80)) {
            Serial.println("connected");
            // Make a HTTP request:
            String prova="GET /newip.php?mac="+mac_string;
            //Serial.println(mac[0],HEX);
            Serial.println(prova);
            client.println(prova);
            client.println();
            Serial.print("Parametro ricevuto: ");
            while(client.connected() && !client.available()) delay(1); //waits for data
            while (client.connected() || client.available()) { //connected or data available
              char c = client.read(); //gets byte from ethernet buffer
              //Serial.print(c); //prints byte to serial monitor
              buffer=buffer+c;
            Serial.println(buffer);
            // Parser del buffer
            indice1=buffer.indexOf('[');
            indice2=buffer.indexOf(']');
            /* converto buffer in numero */
            newbuffer=buffer.substring(indice1+1,indice2);
            for (int i=0; i < newbuffer.length(); i++){
                nuovo_ip=nuovo_ip + 10 - (newbuffer[i] - '0');
            FLAG_Server=1;
            break;
void Lampeggio(int quanto, int colore){
   // colore = 1 == Rosso
   // colore = 2 == Giallo
   // colore = 3 == Rosso e Giallo
     switch (colore) {
        case 1:
          digitalWrite(Rosso, HIGH);
          digitalWrite(Rosso, LOW);
          break;
        case 2:
          digitalWrite(Giallo, HIGH);
          digitalWrite(Giallo, LOW);
          break;
        case 3:
          break;
        default:
          break;
Temple, Texas
What does it display on your Serial Monitor?
Does it ever print "Connessione = 1" ?
Miramar Beach, Florida
If this is an Uno, you can't use D10-13 for LEDS when using the SPI. The ethernet shield uses the SPI bus for both the w5100 and uSD. Use other pins.
tanks, that was the problem!
Where I can read info to understand if a pin it used from w5100?
I use the product schematics. D4 is used by the uSD card if there is one in the slot. D2 is used on some for an interrupt line.
Chicago
Hi
I understand that D4 is used as the chip select for the SD card. what pin is used for the chip select of the W5100 chip?
Thanks
Don
Seattle, WA USA
Seattle, WA USA
Pin 10.
