« on: January 23, 2013, 11:58:52 am » |
Can anyone recommend a cheap waterproof "plug" to use for wiring an external sensor to a case-enclosed arduino?
I'm planning an outdoor application where the arduino sits in a waterproof case, exposed to the elements, with up to 12 4-pin analog sensors individually extending from the case. The arduino will be wired to 12 female plugs on the inside of the case, and the actual sensor/cable will connect via a male plug on the outside of the case. Not all sensor plugs will be used, so I need to plug to be waterproof even if nothing's plugged into it.
Googling finds tons of plugs, but most are $20-30 a piece and designed for high-end industrial applications. Where would I find something cheaper, geared more towards a consumer application?
Earth
Webmaster
« Reply #1 on: January 23, 2013, 01:20:48 pm » |
theres this new thing out called a tarp........lol
Webmaster living off grid in a camper with 300watts of solar panels charging 9 absorbed glass mat 12V batteries. i own about 40 dot coms. i can read, write and debug HTML, CSS, JSON and PHP. I can understand some javascript. A++ is new to me. i thought it was a dead language. lol! A rogue planet called Nibiru is close by and will cause disasters all over earth including fireballs, earthquakes, meteors and volcanic eruptions. But i will be ready with Project Camper
« Reply #2 on: January 23, 2013, 06:19:09 pm » |
You know how I can tell you've never designed any devices for outdoor use?
Earth
Webmaster
« Reply #3 on: January 23, 2013, 09:59:04 pm » |
You know how I can tell you've never designed any devices for outdoor use? OH YEAH? well only one follows the sun but im not done yet. and i cant get it to turn a corner.
« Reply #4 on: January 23, 2013, 10:08:06 pm » |
You know how I can tell you've never designed any devices for outdoor use? OH YEAH? well only one follows the sun but im not done yet. and i cant get it to turn a corner. That's probably because it's all wet. You forgot the tarp. lol
Earth
Webmaster
« Reply #5 on: January 24, 2013, 11:02:16 am » |
use some chewing gum to fill your holes. or cover the whole thing with spray on foam insulation and paint it to look like a rock. this is my junction box. i even stuck moss on it. i cut out a cupholder in the top corner. someone i know said "why is their a big cement block over there?" i said its a rock. it fooled him...lol
Netherlands
« Reply #6 on: January 24, 2013, 03:25:12 pm » |
There is also sugru - https://sugru.com/ -
Dubuque, Iowa, USA
« Reply #7 on: January 24, 2013, 05:00:39 pm » |
Earth
Webmaster
« Reply #8 on: January 25, 2013, 10:07:30 am » |
but he dont want it permanent, he will want to use the extra holes later
Earth
Webmaster
« Reply #9 on: January 25, 2013, 10:10:20 am » |
cant you just cover it with clear silicone caulking dude?
